Troy Molitor Posted December 18, 2017 Share Posted December 18, 2017 Looking forward to any update from you Tolga. This one will certainly be another awesome build in the making. Troy Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted December 18, 2017 Author Share Posted December 18, 2017 Looking forward to any update from you Tolga. This one will certainly be another awesome build in the making. Troy Thanks Troy.. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted December 20, 2017 Author Share Posted December 20, 2017 (edited) Some updates Connection area of the fuselage halves needs some works. Putty and sanding Edited December 20, 2017 by Tolga ULGUR Martinnfb, sandokan, Gazzas and 3 others 6 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted December 20, 2017 Author Share Posted December 20, 2017 And the wings: Kagemusha, Martinnfb, monthebiff and 3 others 6 Link to comment Share on other sites More sharing options...
nmayhew Posted December 20, 2017 Share Posted December 20, 2017 Cool Glad this is back on track Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 15, 2018 Author Share Posted January 15, 2018 (edited) Some progress Edited January 15, 2018 by Tolga ULGUR Kendzior, Martinnfb, Seversky and 1 other 4 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 20, 2018 Author Share Posted January 20, 2018 Gunsight installed Martinnfb 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 20, 2018 Author Share Posted January 20, 2018 And the Hasegawa s windscreen, painted and installed. Trak-Tor and Martinnfb 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 20, 2018 Author Share Posted January 20, 2018 Ready for painting after sanding. MikeMaben, Martinnfb and Shaka HI 3 Link to comment Share on other sites More sharing options...
Plm Posted January 20, 2018 Share Posted January 20, 2018 Nice built. Don't forget that Trumpeter has not represent the new wheel well wall on the fuselage side, due to the extension of the wing span by adding a part at the wing root. Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 20, 2018 Author Share Posted January 20, 2018 Nice built. Don't forget that Trumpeter has not represent the new wheel well wall on the fuselage side, due to the extension of the wing span by adding a part at the wing root. Thanks Yes I know it. There was a gap in the wheel well wall of fuselage side. I filled the gap in the wall and decided to continue as it is. I do not want to give more effort to this area Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 20, 2018 Share Posted January 20, 2018 Very cool! Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Plm Posted January 20, 2018 Share Posted January 20, 2018 (edited) Yes I know it. There was a gap in the wheel well wall of fuselage side. I filled the gap in the wall and decided to continue as it is. I do not want to give more effort to this area What I mean is that the wall should not be near the fuselage but at the vertical of the inner door. The wheel well has the same size on P-47N as on P-47D. It should not be deeper as the wing extension is for a tank. Below a picture of my Trumpeter P-47N, I used the Eduard undercarriage set where you can find the new wall. Edited January 20, 2018 by Plm Troy Molitor, Kagemusha, MikeMaben and 2 others 5 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 21, 2018 Author Share Posted January 21, 2018 What I mean is that the wall should not be near the fuselage but at the vertical of the inner door. The wheel well has the same size on P-47N as on P-47D. It should not be deeper as the wing extension is for a tank. Below a picture of my Trumpeter P-47N, I used the Eduard undercarriage set where you can find the new wall. Aha.. Thanks for the information Eduard s set is a good solution but it should be better if it s used before this stage. I will get one and try to install it . Merci Martinnfb 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted January 23, 2018 Author Share Posted January 23, 2018 (edited) Well, I have just ordered Eduard undercarriage set from Hannants. Waiting time is around 10 days. We will see applicability of the set at this stage. Thanks again to Plm for the warning. On the other hand while waiting for the set, I turned to the engine area. I will post some pictures soon Edited January 23, 2018 by Tolga ULGUR Troy Molitor 1 Link to comment Share on other sites More sharing options...
