Wackyracer Posted December 23, 2017 Share Posted December 23, 2017 (edited) Here's my entry, first in progress work and GB on here so go easy please. Hobbyboss as the main kit and canopy and filter from Hasegawa Selection of decals and masks (kit was second hand and decals missing from box) AM And reference And finally the aircraft Edited January 21, 2018 by Wackyracer Dragon and LSP_Paul 2 Link to comment Share on other sites More sharing options...
Wackyracer Posted December 23, 2017 Author Share Posted December 23, 2017 Started with the pit Yahu instrument panel Couple of hours work to assemble Engine built up just for alignment of prop and exhaust stubs MikeC, BradG, LSP_Paul and 7 others 10 Link to comment Share on other sites More sharing options...
Kagemusha Posted December 23, 2017 Share Posted December 23, 2017 Nice choice! Wackyracer 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 23, 2017 Share Posted December 23, 2017 Nice stsrt on the HB Spit. Looking forward to following your progress Keep ‘em comin Peter Link to comment Share on other sites More sharing options...
Iain Posted December 23, 2017 Share Posted December 23, 2017 I'll be following along on this one - great subject! Malta is special to me - I have a little Maltese ancestry... And reference And that's where my Grandmother, Rosetta, was born (known in the family as 'Rosetta from Valletta') Iain LSP_Paul 1 Link to comment Share on other sites More sharing options...
dennismcc Posted December 23, 2017 Share Posted December 23, 2017 This should be good, will be following this one. Cheers Dennis Link to comment Share on other sites More sharing options...
Guest Posted December 23, 2017 Share Posted December 23, 2017 Noice !!.......Harv Link to comment Share on other sites More sharing options...
Martinnfb Posted December 23, 2017 Share Posted December 23, 2017 Nice choice, in regards of the overpainting. Is there any evidence of that, order etc.? I would say that the surface was just faded by sun. But that is only me I will follow with interest Cheers Martin here is T-H , please note how the colours are blending together and judging by the shine of the surface it was fairly new paint job . 249 Squadron Ta Quali, Malta Link to comment Share on other sites More sharing options...
Wackyracer Posted December 25, 2017 Author Share Posted December 25, 2017 Sunday afternoon bench time. Gave the pit a coat of Mr Surfacer grey then Mr Paint Interior grey green. Instrument panel glued and dials filled with Microclear Other bits of the pit painted PE belts installed Gun covers installed into top wing sections. Fit was nearly perfect on this kit. The Trop version although the same took some filing to get a neat join. Now the biggest challenge for me. Fitting the Hasegawa canopy to the kit. After a couple of hours head scratching I used the incorrect tail sections from my Trop build (the profile was almost a perfect match) to fashion 2 fill-in panels between the pit and the framework. I jointed the fuselage with tape so I could see side to side and also width. The Hasegawa is about 1mm narrow but will 'spread' a touch. And with the canopy Need to let the glue fully cure then I can in-tape the fuselage and refine the joins TorbenD, Dragon, Martinnfb and 5 others 8 Link to comment Share on other sites More sharing options...
TorbenD Posted December 25, 2017 Share Posted December 25, 2017 A flying start for sure! Torben Dany Boy 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 26, 2017 Share Posted December 26, 2017 Great fix on the Windscreen! That's really going to look excellent on there. Keep up the good work! Paul Wackyracer 1 Link to comment Share on other sites More sharing options...
Dragon Posted December 29, 2017 Share Posted December 29, 2017 Nice bit of goodies for your build and a great progress on it too! Mike Link to comment Share on other sites More sharing options...
Wackyracer Posted December 30, 2017 Author Share Posted December 30, 2017 Managed some more bench time. Gave the pit some washes and filters Assembled the wings top and bottom Sorted the Quickboost replacement stabilisers Joined the fuselage and tested the wing joins. Each side had a small gap, so a shim of 0.2mm on one side and 0.3 on the other. Bottom join was almost perfect BradG and Martinnfb 2 Link to comment Share on other sites More sharing options...
Wackyracer Posted December 30, 2017 Author Share Posted December 30, 2017 Then with the engine cowlings in place I grabbed the Hasegawa trop filter to see how it went. I was guessing the kit base would need fitting then the filter part grafted on but it was almost a perfect fit! I chain drilled the front section to match the rest of the kit. Then test fitted Before committing to glue. Very happy with the outcome. With the canopy sorted and this it should be straightforward from now on. LSP_Kevin, Martinnfb, TorbenD and 5 others 8 Link to comment Share on other sites More sharing options...
mark31 Posted December 30, 2017 Share Posted December 30, 2017 great progress looking forward to see more Mark Link to comment Share on other sites More sharing options...
