Shaka HI Posted May 13, 2017 Share Posted May 13, 2017 I can hardly wait till you hit a nice and satisfying primer coat on this thing! Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Guyman1 Posted May 13, 2017 Share Posted May 13, 2017 Very nice Alain, The detail is really coming through on this one. Guy Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted May 16, 2017 Author Share Posted May 16, 2017 Hi all! Thank you Kev, Shaka and Guy! Here is what I managed to do in the last few days: First, work on the cockpit sill, which is very important to get the cockpit transparencies in the correct position on the fuselage. A bit of structural detail on the underside of the part. Two strips forward will extend all the way to the instrument panel. I added some styrene bits under the rear section to help set it in the right angle relative to the opening canopy section, and to help the anchor epoxy putty that will be added to complete the fairing-fuselage joint. Somehow, some extra thin got under my fingers and on the clear plastic, and created a faint foggy effect... I didn't mind really, as there was small scratch to remove in the same spot! The styrene sill, painted and glued in place, and the clear part, sanded to remove the defects. While this dried, I cut apart the gear doors, adding marks to facilitate the orientation of the cut sections. Now I'm going to go add the epoxy putty on the fairing. Results tomorrow I hope! Alain Shaka HI, BradG and BiggTim 3 Link to comment Share on other sites More sharing options...
Shaka HI Posted May 16, 2017 Share Posted May 16, 2017 Looks great! Keep going, but don't rush! Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted May 16, 2017 Author Share Posted May 16, 2017 Right, Shaka! The trick is not to rush, but to keep at it a bit every day! On my phone now but photos of the fairing later.... Shaka HI 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted May 16, 2017 Author Share Posted May 16, 2017 Hi all, Here are the photos showing the fairing in Apoxie Sculpt: First, I mixed a batch of epoxy and added a small amount under the rear section, insuring it adheres well to the plastic. I added some CA glue to be sure it does not come off. The part is now in place, everything aligned and secured with tape. Material is now added in small amounts, checking to be sure it is well pushed in. I also verified that the canopy doesn't shift under the pressure. After waiting overnight, the part is pushed out very gently from the inside. After a few minutes of trimming, this is the result, although I will remove more material for a sharper look. The front windscreen will be from a piece of 1/16 acrylic (protected by paper) and side panels from CD clear plastic from the $ store! More soon! Alain Out2gtcha, BradG, Shaka HI and 3 others 6 Link to comment Share on other sites More sharing options...
Shawn M Posted May 16, 2017 Share Posted May 16, 2017 killer work on the canopy! Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 16, 2017 Share Posted May 16, 2017 Love it! Alain Gadbois 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 16, 2017 Share Posted May 16, 2017 Terrific work, Alain! This build is such a pleasure to follow. Kev Alain Gadbois 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted May 16, 2017 Share Posted May 16, 2017 Brilliant stuff, Alain ... really love your putty work at the rear canopy. Jim Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted May 17, 2017 Share Posted May 17, 2017 Ya, good stuff...I ordered some of that apoxie putty-thingy..not sure if I'll ever use it, but it looks like something you should have it in your arsenal! Alain Gadbois 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted May 17, 2017 Share Posted May 17, 2017 This is a wonderful build to follow, I'm learning so much. You're making terrific progress! Richard Alain Gadbois and Shaka HI 2 Link to comment Share on other sites More sharing options...
marauderdriver Posted May 18, 2017 Share Posted May 18, 2017 Alain, This is some RIGHTEOUS WORK! You keep blowing me away with your talent.a As long as you have a plan that works for you . CAN"T WAIT!! Shaka HI and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Guyman1 Posted May 18, 2017 Share Posted May 18, 2017 Very nice Alain, This is great to watch unfold the detail will really make this unique build stand out Guy Shaka HI and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted May 20, 2017 Author Share Posted May 20, 2017 Wow guys! Thank you all for your encouragements! This is really helping me to keep focused on this project. I had been interested in this version of the 262 for a long time but never had the occasion to start doing the conversion. Here is what I managed to do this week. I made a little template to cut out the side winsdcreen panels. It will allow me to make 2 identical parts that will fit in place almost perfectly. The windscreen, being so fragile, will be one of the last parts fixed to the fuselage. So I have to see to the last details under the fuselage. The front landing gear and wheel well. I replaced the retraction strut with aluminium tubing and styrene parts. A section of bent copper wire links the strut to the gear leg. That strut seemed too big to me as it was the same size as the nose gear one, so I found a piece of hollow stainless steel tube (no clue where I got that from...) and replaced the alu part with it. It is loose in this photo but I wrapped a bit of Tamiya tape inside and made the fit centered and tight after. The effect is much better now. A great source of different sized tubing is this pack of K&S bits I bought many years ago! Here are the sections I will use to replace the meagre main gear legs. I will keep the kit wheel axles to simplify the construction of the parts.. This afternoon I have some modeling time and I hope I can get much done in those last construction details. Alain BradG, 109, mgbooyv8 and 3 others 6 Link to comment Share on other sites More sharing options...
