Zero77 Posted February 11, 2016 Posted February 11, 2016 Hi, It's one more build started a longtime ago, but i want to finish it. It's a rather small kit, with not many parts, but some areas need special care to look accurate, or just to look good ! The fit is very good anyway. I will make one of the schemes from the box, the white and yellow swiss aircraft, this one : Those nice pictures just make me want to have a walk in the moutains near a beautiful lake... For the paint, i have ordered some paint from Gravity, a spanish company who produces amazing paints dedicated to (racing) car models. I tried them yesterday and they are great (fast curing, extra smooth, very fine pigment, airbrush ready....). For the yellow i bought a bottle of school bus yellow. The colour is very good, but it doesn't match the Revell decals colour (for the lightning on the floats and the code on the wings. Anyway, we'll sort out that later ! rafju 1
Zero77 Posted February 11, 2016 Author Posted February 11, 2016 (edited) When i get back to that build, i had already made a lot of small subassemblies. The cute little engine : I wont detail it more as i think i am going to build it with all doors closed. The lower engine cowling. I glued and blended the cylindrical cover in the middle, as on the real stuff it seems to be one part (2 parts in the Revell kit), or at least almost no seam is visible. I also carved it, thinned the walls of the cylinder and will add a black sphere inside after the paintjob. The cockpit is straight from the box, i did not add anything. I even used the molded seat belts (they looked good to me) and the dashboard decal. I just added a drop of krystal klear on each instrument to make the glass. I also painted the floor with a wood grain technique. Edited February 11, 2016 by Zero77 rafju 1
Zero77 Posted February 11, 2016 Author Posted February 11, 2016 At the moment, i am detailing the floats. I am going to add all the float rudders control cables. I built small pulleys, and had to redo the rudders themselves. Here is what's from the box : It's a bit too much simplified. Here is the result. I still have to build the other one : They may not be 100% accurate as i did not found real close-up picture. But they look good to me. I still have to add details on the upper part of the axle (i did it yesterday, but have not taken any pictures since then). The brass is cut into 0.15mm brass sheet, then bent and the small rivet added with a scriber : I also had to fill the landing light on the left wing, as the aircraft i'm buidling dont have one ! sax003, Whitey, Anthony in NZ and 1 other 4
Out2gtcha Posted February 11, 2016 Posted February 11, 2016 (edited) Great work Nicolas! I too have this kit in the stash as well. Looking forward to some more progress! (and taking notes too) Edited February 11, 2016 by Out2gtcha Zero77 1
Jack Posted February 11, 2016 Posted February 11, 2016 oh my, this promises to become a great build, i'm sure. Superb start of a neat project, have fun Jack. Zero77 1
Brenhen Posted February 11, 2016 Posted February 11, 2016 very cool project! I've always had issues cutting brass without getting a lot of bending at the edges. What are you using to cut your brass so cleanly? Thanks Zero77 1
Zero77 Posted February 11, 2016 Author Posted February 11, 2016 On 2/11/2016 at 5:36 PM, Brenhen said: very cool project! I've always had issues cutting brass without getting a lot of bending at the edges. What are you using to cut your brass so cleanly? Thanks I use a Xuron sheer cutter (the one with blue handles). But indeed the parts are a bit twisted, so i flatten them with a pair of pliers thereafter.
Ironwing Posted February 11, 2016 Posted February 11, 2016 Zero, This is just too cool. There isn't much prettier than a Cub on floats. I'd love to do this myself. I look forward to seeing you bring this home... Geoff Zero77 1
Guest Peterpools Posted February 12, 2016 Posted February 12, 2016 Nicolas Way to go. Absolutely fantastic Keep 'em coming Peter
LSP_Kevin Posted February 12, 2016 Posted February 12, 2016 Cool project, Nicolas! Very nice work, too. Kev Zero77 1
Zero77 Posted February 19, 2016 Author Posted February 19, 2016 (edited) Thanks guys ! Next step was just surgery. I still have not finished. In fact, i noticed while watching actual pictures that Revell should definitely not have chosen this aircraft, as it is FAR away from what you can build with the kit. Ok, it's not really noticeable on every pictures. But when i found this one, i understood that i was dealing with something non standard. The roof has a large clear area, so it is flater than usual, and in the inside one can see the tubular frame, whereas in the kit there is an interior hiding the tubes. On this picture, one can also see that the tubular frame around the clear roof is not standard either. There is also a black rectangle. I dont know what it is, nor how to deal with. Maybe it's a small window? So i had to cut open that kit roof and destroy all of the interior. Ok. Here is the kit as i built it so far (following the Revell instructions !) : Following the well known technique, first i drilled holes : And then remove the square : ANd clean the cut : I then shaved and sanded it carefully until i only got the plastic thickness. I still need a bit of material to fix the clear roof. Then i destroyed the interior part with a pair of pliers, and here we are : Edited February 19, 2016 by Zero77 Hubert Boillot 1
Zero77 Posted February 19, 2016 Author Posted February 19, 2016 (edited) I then cut a rectangle of quite thick clear plastic (from a packaging), using a template made of tamiya masking tape taped on the roof, so i have an almost exactly dimensionned rectangle. I stripped the paint on the inside but it was not easy and quite coarse. So i just glued a thin plastic sheet cut to the correct dimensions : Now I still have to rebuild the interior tubular frame. Actually it's done, but i still have not taken any pictures. Maybe this evening if i have enough time (i go on vacations tomorrow !). At the same time, i also built the small pulleys that go on the floats to lead the float rudder cables : And add a few millimeters on the bottom engine cowling as the kit one was too short to match what i see in the pictures : When i started this build, i thought it would be fast and straightforward.... Huge mistake ! Edited February 19, 2016 by Zero77 rafju 1
Ironwing Posted February 19, 2016 Posted February 19, 2016 (edited) Zero Im just loving what youre doing. Hurry back from vacation...Cant waait to see more. Cheers Geoff Edited February 19, 2016 by Ironwing Zero77 1
