quang Posted September 10, 2022 Posted September 10, 2022 I don’t know about the Oramask but the MagicTape sticks stronger that one thinks, especially when you buff it afterwards with a toothpick. scvrobeson, mozart and europapete 3
europapete Posted September 11, 2022 Posted September 11, 2022 Will dig a bit deeper into those wing panels Max, they seem rather large for wing strut access but you never know. Regards, Pete in RI
mozart Posted September 11, 2022 Author Posted September 11, 2022 (edited) So the sanding of the plasticard didn't really work very well, so I cut my losses and cut them off and opted for Plan B.....self-adhesive vinyl which is thicker than my usual masking stuff (thanks Quang!) . This photo also confirmed for me that the ribbing extends further forward on the fuselage than on the kit: I wasn't too confident about the best way of achieving the ribbed effect but opted initially for a curved blade and scraping resin away, it seemed to work: and a coat of primer afterwards showed it's OK (a small blemish only to be filled): Really enjoying this kit, such fun!! Edited September 11, 2022 by mozart Greg W, Alain Gadbois, geedubelyer and 12 others 15
mozart Posted September 14, 2022 Author Posted September 14, 2022 (edited) Mea culpa, I'm guilty.....yes I've succumbed to temptation as I inevitably knew that I would: I've put shiny panels on my Gauntlet!! I know (in all probability) that 56 Squadron's Gauntlets had the anodized panels in the same way that I know (in all probability) that their Gauntlets didn't have the chequerboard design on the upper wing.....but mine will.....so there!! It's also got some numbers on the wings: ....and it might have some chequers and roundels on the fuselage tomorrow, who knows? Edited September 14, 2022 by mozart LSP_Kevin, Greif8, Fanes and 10 others 13
quang Posted September 14, 2022 Posted September 14, 2022 I don’t know how anodized panels should look but on your model they look rather good in contrast with the silver doped canvas. jbrennan 1
jbrennan Posted September 14, 2022 Posted September 14, 2022 Most amazing work Mozart. May I ask how did you get the polished affect - I use Metalcote spray then polish it but still cannot get such a high polish effect such as that !? Jon
mozart Posted September 14, 2022 Author Posted September 14, 2022 35 minutes ago, quang said: I don’t know how anodized panels should look but on your model they look rather good in contrast with the silver doped canvas. Should be dull Quang, no shine…..but how boring for a Golden Era aeroplane and the last of the open cockpit fighters! 10 minutes ago, jbrennan said: Most amazing work Mozart. May I ask how did you get the polished affect - I use Metalcote spray then polish it but still cannot get such a high polish effect such as that !? Jon Thank you Jon, it’s not paint at all but Bare Metal Foil, self-adhesive so “easy” to apply though of course there’s a (not very steep) learning curve to getting acceptable results.
jbrennan Posted September 14, 2022 Posted September 14, 2022 13 minutes ago, mozart said: Should be dull Quang, no shine…..but how boring for a Golden Era aeroplane and the last of the open cockpit fighters! Thank you Jon, it’s not paint at all but Bare Metal Foil, self-adhesive so “easy” to apply though of course there’s a (not very steep) learning curve to getting acceptable results. 14 minutes ago, mozart said: Should be dull Quang, no shine…..but how boring for a Golden Era aeroplane and the last of the open cockpit fighters! Thank you Jon, it’s not paint at all but Bare Metal Foil, self-adhesive so “easy” to apply though of course there’s a (not very steep) learning curve to getting acceptable results. Thank you Mozart. You have put me on a learning curve hear in itself. Do you have to scribe around the area required once fitted or is it cut before adhesing etc ? Thanks jon
mozart Posted September 14, 2022 Author Posted September 14, 2022 You can do either way Jon, but on this one I cut each panel slightly oversize, burnished it down with various cotton wool buds and once the panels lines were easy to see, ran a sharp scalpel along to take off the excess. The whole of the front took a couple of hours. Greg W 1
jbrennan Posted September 14, 2022 Posted September 14, 2022 Thank you greatley mozart. One last question from the unitiated. Is it adhesive backed or do you need to add glue. Indeed what is the manufacturers name ? Kindest regards Jon
mozart Posted September 14, 2022 Author Posted September 14, 2022 3 minutes ago, jbrennan said: Thank you greatley mozart. One last question from the unitiated. Is it adhesive backed or do you need to add glue. Indeed what is the manufacturers name ? Kindest regards Jon It’s actually called Bare Metal Foil! It’s adhesive backed so just peels off, but very very thin like gold leaf so can be fiddly! https://www.bare-metal.com
jbrennan Posted September 14, 2022 Posted September 14, 2022 47 minutes ago, mozart said: It’s actually called Bare Metal Foil! It’s adhesive backed so just peels off, but very very thin like gold leaf so can be fiddly! https://www.bare-metal.com 47 minutes ago, mozart said: It’s actually called Bare Metal Foil! It’s adhesive backed so just peels off, but very very thin like gold leaf so can be fiddly! https://www.bare-metal.com 47 minutes ago, mozart said: It’s actually called Bare Metal Foil! It’s adhesive backed so just peels off, but very very thin like gold leaf so can be fiddly! https://www.bare-metal.com Thank you kindley Sir Jon mozart 1
mozart Posted September 16, 2022 Author Posted September 16, 2022 Before moving on too much further forward I need to get to grips with the front starboard side of the fuselage (funny how virtually every drawing shows the port side only!) This is the best photo that I can find of the contentious area, and I've enlarged it and tweaked it to death, but there appears to be five openings/caps/pipes of interest. 1 and 5 appear to be filler/inspection caps (radiator related?), 2 and 3 appear to be drain/vent pipes and 4 possibly an exhaust vent. Any thoughts? R Palimaka and Greg W 2
mozart Posted September 16, 2022 Author Posted September 16, 2022 (edited) Another better shot from a different angle: Also it looks like a pipe running along the lower edge of the oil radiator which is different to the Gladiator where it runs along the top edge or is there another pipe at the top edge too? Rhetorical questions I’m sure. Edited September 16, 2022 by mozart R Palimaka, scvrobeson, Greg W and 1 other 4
