Landrotten Highlander Posted March 10, 2021 Share Posted March 10, 2021 Hi All, this is a provisionary start of a build log on how I work on painting figures. As is mentioned in another thread on ATA pilots, Life miniatures has produced a wonderful resin 3D version based on a picture of Maureen. She was a pilot for the ATA, and her function (amongst others) was to ferry airplanes from factory to front-line services. In the thread I offered on of our forum members to paint his version (seeing he stated he did not feel confident on doing the figure justice), and here we are. I shall attempt to take pictures of the box and its contents when the light is a bit better (it is a bit damp with a breeze, as we say in Scotland - 1.5 mm precipitaion with 12 m/s winds). Ta for now, L.H. xcnickcn, Derek B, Uncarina and 3 others 6 Link to comment Share on other sites More sharing options...
mozart Posted March 10, 2021 Share Posted March 10, 2021 (edited) I started mine yesterday LH, managed to get most of the face, but not the hair completed. I’ll be following along to compare notes and probably steal a few techniques! Edited March 10, 2021 by mozart LSP_K2 1 Link to comment Share on other sites More sharing options...
F2G_lover Posted March 11, 2021 Share Posted March 11, 2021 I'll definitely be following along, as I've just ordered one myself, along with the 1/12 scale version. mozart 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted March 12, 2021 Share Posted March 12, 2021 Looking forward to seeing Maureen being made up. Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted March 14, 2021 Share Posted March 14, 2021 Really looking forward to this. It's a lovely sculpt. Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted March 17, 2021 Author Share Posted March 17, 2021 (edited) Stage1: inspection and clean-up of the parts The figure I have been asked to paint is the 1/16 scale version of Maureen. She is to be displayed on her own in the cabinet (i.e. not used with any aircraft). So she will be placed on a wooden base all of her own First, the contents of the box: As you can see each component has some casting blox that will need removal. The resin is of very good quality and the details are vry crisp indeed. A few close-ups showing this - some pictures are abit blurred as I was taking them freehand (without stand, my bad). Edited March 17, 2021 by Landrotten Highlander Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted March 17, 2021 Author Share Posted March 17, 2021 (edited) And this is how they look when the casting blocks have been removed. This is easily performed with a sharp scalpel, though care should be taken when removing them from the rather thin and fragile looking bits of loose parachute belt. Also make sure that when removing them from curved surfaces (e.g. the elbow at her right arm) that you do not create a flat area but keep the sculpture as much as possible intact. Next step is to figure out how to paint and assemble. While oing so I will be 'pinning' the different components. As you can see in this example of her arms, there is a vry shallow set of matching male/female squared that enable accurate alignment of the components. However, from experience they may not prove sufficiently strong when glued together (this is normally less of an issue in the smaller scales, but I picked up the habit and it has never let me down since. Pictures to follow when this is done (and yes, I shall be using a tripod this time) Edited March 17, 2021 by Landrotten Highlander mozart, Gazzas, Fanes and 3 others 6 Link to comment Share on other sites More sharing options...
mozart Posted March 17, 2021 Share Posted March 17, 2021 Good-oh LH, glad to see you progressing this, even with blurry pictures! The only part that fitted less than satisfactorily on my 1/32 figure was the right arm, the location of the arm base was rather vague and the hand in the hair left quite a gap which I filled with Apoxie Sculpt. Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted March 17, 2021 Author Share Posted March 17, 2021 (edited) 3 hours ago, mozart said: Good-oh LH, glad to see you progressing this, even with blurry pictures! The only part that fitted less than satisfactorily on my 1/32 figure was the right arm, the location of the arm base was rather vague and the hand in the hair left quite a gap which I filled with Apoxie Sculpt. Dry-fitting suggested some minor issues in the same area. However, pinning will solve 90 %of that, the rest of the slack will be easily taken up by some strong glue - just need to figure out in my head the order of gluing and painting things. Edited March 17, 2021 by Landrotten Highlander mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted March 17, 2021 Share Posted March 17, 2021 Yes, I have made life difficult for myself by assembling the whole figure, but it’s not so critical as part of the dio as for a stand alone figure. Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted March 22, 2021 Author Share Posted March 22, 2021 She' pinned (pined....., pinned......, pined ........) using copper wire in 2 sizes: for the heavier pieces I used 1.5mm wire, for the lighter/smaller pieces 0.7mm wire xcnickcn and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted March 22, 2021 Author Share Posted March 22, 2021 And this is how she shall stand. Other than between the feet and legs as well as the looped strap on the parachute there is no glue on the model. Held together only by pins (including her left arm which is hanging down). MikeC, Alain Gadbois, mozart and 3 others 6 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted March 22, 2021 Author Share Posted March 22, 2021 (edited) Some close-up shots to show off the detail in sculpting and casting available at this scale: including the straps of the parachute The painting process will be unusual in that this time I shall start literally from the bottom (the floor ) up. So first the ground (I think I shall include some grasses here to make it more interesting), then the shoes + trousers and strap bits on the bottom part, then the torso with straps on that part, then add the parachute and any additional straps. Head and arms will be the last fitted - but not necessarily the last painted, particularly the face as that shall be the focal point of this figure so it has to be good. Edited March 22, 2021 by Landrotten Highlander mozart, Fanes, MikeC and 3 others 6 Link to comment Share on other sites More sharing options...
xcnickcn Posted March 22, 2021 Share Posted March 22, 2021 This build log is fantastic to have with her! Do you guys call this a build log? mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted March 22, 2021 Share Posted March 22, 2021 6 hours ago, xcnickcn said: This build log is fantastic to have with her! Do you guys call this a build log? It’s as good a term as anything Nick! MikeC 1 Link to comment Share on other sites More sharing options...
