Simmo.b Posted February 2, 2021 Posted February 2, 2021 I purchased the new Italeri GR4 Kit however have always wanted to build a Gulf War GR1. Like many of us I have the old Revell Kit plus all of the aftermarket goodies and thought to myself, will the Aries resin pit fit into the Italeri kit? The Italeri kit contains all of the parts to build a GR1 (extra gun etc) so the conversion should be easy, however the Italeri pit is not only a soft part of an otherwise excellent kit, it is also a GR4 pit (though not exactly accurate for that type either). My first job was to see if it was even viable to fit the Aries item. I was encouraged by the first test fit, the kit hud would have to be carefully removed but everything looked like it may fit. I used my trusty Trumpeter scriber to scribe out the plastic part but kept the removed parts so that they could be put back on if things went pear shaped. This is an expensive kit after all!! With the hud removed I was encouraged. A test fit revealed a gap forward of the resin hud and the need to thin the Italeri fuselage parts. I was confidant enough to begin the painting process, SMS Gull Grey and MRP Tyre Black. As you can see from the photos above the gap up front is significant, I glued in sections of evergreen strip and sanded them to shape, blending everything together with Mr Surfacer. Success!! After lots of sanding, filling and sanding it fits! I will add that I thinned the kit parts quite a bit but that's normal when fitting Aries pits right?? And I can confirm that the front gear bay fits with no modification needed. I think the Aries wheels and engines should fit as well but we will see. Thanks for looking JayBee, Starfighter, Uncarina and 19 others 22
Stokey Pete Posted February 2, 2021 Posted February 2, 2021 Excellent work shoehorning the Aires parts in. I’m sure there’ll be many folk out there considering similar work (myself included).
Uncarina Posted February 2, 2021 Posted February 2, 2021 Great start and very encouraging! I will be following along with great interest. Cheers, Tom
ericg Posted February 2, 2021 Posted February 2, 2021 Great start mate. Good to see you progressing with this project.
jimbo59 Posted February 2, 2021 Posted February 2, 2021 I just ordered this kit and i have that cockpit in my stash. Thanks for posting
Mark M Posted February 2, 2021 Posted February 2, 2021 have you checked the nose gear bay fit with the pit, the tolerance in the revell kit is tight, im not 100% the aries resin wont foul the nose gear bay
Simmo.b Posted February 3, 2021 Author Posted February 3, 2021 5 hours ago, Mark M said: have you checked the nose gear bay fit with the pit, the tolerance in the revell kit is tight, im not 100% the aries resin wont foul the nose gear bay Yes mate, the nose gear bay fits with no issues Kagemusha and Mark M 2
Mark M Posted February 3, 2021 Posted February 3, 2021 cool, question as ive not quite got there yet, is it possible to build the nose bay without the landing gear or do you HAVE to install it
Simmo.b Posted February 3, 2021 Author Posted February 3, 2021 48 minutes ago, Mark M said: cool, question as ive not quite got there yet, is it possible to build the nose bay without the landing gear or do you HAVE to install it Hi Mark, If you are doing the kit wheels up you can indeed leave out the bay. Cheers Brent Mark M 1
Mark M Posted February 3, 2021 Posted February 3, 2021 no sorry i ment for wheels down can you leave out the leg until the end, or does it have to go in during the build, i always end up breaking things
Simmo.b Posted February 3, 2021 Author Posted February 3, 2021 15 minutes ago, Mark M said: no sorry i ment for wheels down can you leave out the leg until the end, or does it have to go in during the build, i always end up breaking things Spencer Pollard left his off until completion, cut one of the lugs off I think. I'm leaving mine off too Mark M 1
Mark M Posted February 3, 2021 Posted February 3, 2021 cool ill go for that then, cos you know ill end up breaking it!
LSP_Kevin Posted February 3, 2021 Posted February 3, 2021 Good to see you back with another build, Brent! Kev
Zola25 Posted February 3, 2021 Posted February 3, 2021 10 hours ago, Simmo.b said: Yes mate, the nose gear bay fits with no issues I am just putting the finishing touches on my 1/32 Italeri GR.1 conversion - and I also included the Aires Cockpit for the Revell kit. It fits really nicely (with the usual sanding for a resin cockpit) but you do really have to take care about the clearance of the nose gear well. There is no room to spare at all - but you can turn that into an advantage when gluing the whole thing together as the cockpit tub can rest securely on top. Kagemusha and Anthony in NZ 2
Zola25 Posted February 3, 2021 Posted February 3, 2021 10 hours ago, Mark M said: cool, question as ive not quite got there yet, is it possible to build the nose bay without the landing gear or do you HAVE to install it You can leave it out until the end - no problem at all Mark M and Kagemusha 2
