Rick Griewski Posted August 31, 2020 Share Posted August 31, 2020 I will kit bash the Special Hobby A5M4 (or A5M2b) kit with parts from Dave Thomas (Dave and Umi fame) resin trainer kit. Alex, Kagemusha, mozart and 5 others 8 Link to comment Share on other sites More sharing options...
Rick Griewski Posted September 2, 2020 Author Share Posted September 2, 2020 (edited) I put together a composite drawing of the A5M4K superimposed on the A5M2b using Canvas 2D drawing program. The arrows point to the areas of the kit that will be modified. The tricky area is moving the front cockpit forward just 1/8 to 3/16 of an inch. Note the strakes on the fuselage just forward of the fin. Edited September 2, 2020 by Rick Griewski Added comment about the change to the front cockpit Rockie Yarwood, LSP_Kevin, Lothar and 6 others 9 Link to comment Share on other sites More sharing options...
Rick Griewski Posted September 2, 2020 Author Share Posted September 2, 2020 The donor kit and references. The Mushroom book is very good. The drawings in the Maru book are awesome. I will use two PE sets to dress up the cockpit. Rockie Yarwood, Kagemusha and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
Rick Griewski Posted September 2, 2020 Author Share Posted September 2, 2020 Kit box contents Kagemusha, LSP_Kevin and BradG 3 Link to comment Share on other sites More sharing options...
Rick Griewski Posted September 2, 2020 Author Share Posted September 2, 2020 The kit fuselage and the top of the fuselage supplied in the resin kit by Dave Thomas to be used as a reference for kit modifications. I still want to build the resin kit but my tolerance for resin is low so the build drags on. LSP_Kevin, RadBaron, Kagemusha and 3 others 6 Link to comment Share on other sites More sharing options...
Rick Griewski Posted September 2, 2020 Author Share Posted September 2, 2020 The donor kit is not very complicated. Sprue shown below Enough for tonight. Back to work on the Bouton Paul Defiant (Battle of Britain Group Build) BradG, Kagemusha, Rockie Yarwood and 6 others 9 Link to comment Share on other sites More sharing options...
MikeMaben Posted September 2, 2020 Share Posted September 2, 2020 Ahaa, interesting. Certainly a one of a kind. Rick Griewski 1 Link to comment Share on other sites More sharing options...
Rick Griewski Posted October 21, 2020 Author Share Posted October 21, 2020 I assembled the donor kit to assess issues that are coming up. The wing and horizontal tail plane fit is very good. Intersection of the wing and the fuselage will require some sand-to-fit. I have some work to do on the underside of the wing at the rear. Kagemusha, Alain Gadbois, Rockie Yarwood and 2 others 5 Link to comment Share on other sites More sharing options...
Rick Griewski Posted October 21, 2020 Author Share Posted October 21, 2020 I rechecked the outline of the donor kit with the drawing of the trainer. Close enough for now. BradG, LSP_Kevin, Rockie Yarwood and 1 other 4 Link to comment Share on other sites More sharing options...
Rick Griewski Posted October 21, 2020 Author Share Posted October 21, 2020 (edited) The donor kit engine (A5M2b) seems too small compared with the cowl to me. Photos show a close fit inside the cowl. I was then nervous that I used the wrong donor kit. So I pulled out the Craftworks A5M4 kit. The A5MK trainers were built with A5M4s. So then interesting dilemma appeared when I compared the Williams Brothers engine and cowl from the Craftworks A5M4 kit. IIRC the A5M4 included an upgraded engine. I do not think the change would be this large of a size difference. Except for the difference in the size of the opening the two cowls are the same. I will proceed with the Williams Brothers engine in the donor kit so I can have a snug fit. Edited October 21, 2020 by Rick Griewski forgot Craftworks Alain Gadbois, Out2gtcha, mgbooyv8 and 1 other 4 Link to comment Share on other sites More sharing options...
Rick Griewski Posted October 21, 2020 Author Share Posted October 21, 2020 Planning on landing gear strut enhancement and propeller hub enhancement using a copy of the part from the Craftworks kit. BradG, Alain Gadbois, Rockie Yarwood and 4 others 7 Link to comment Share on other sites More sharing options...
Rick Griewski Posted October 21, 2020 Author Share Posted October 21, 2020 (edited) A look at where I will go going with the two seat arrangement. The resin kit provides a hollowed out area. The one seat will have to be replicated. Note the resin bulkheads and the seats with lightning holes (copies from ancient Zero kit?). The kit seat is probably over simplified. I have one full scope PE set. Note that the stringer structure extends behind the cockpit. I will use this as a guide during the build. Edited October 21, 2020 by Rick Griewski speculate about seats Rockie Yarwood, Out2gtcha, mgbooyv8 and 6 others 9 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 22, 2020 Share Posted October 22, 2020 Very interesting conversion project. What are the trainer paint schemes? Alain Link to comment Share on other sites More sharing options...
Rick Griewski Posted October 23, 2020 Author Share Posted October 23, 2020 4 hours ago, Alain Gadbois said: Very interesting conversion project. What are the trainer paint schemes? Alain Orange, green and aluminum. All the color combinations so other pilots stay the heck out of the way of the students. Alain Gadbois and Rockie Yarwood 2 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted October 25, 2020 Share Posted October 25, 2020 Indeed, a very interesting conversion project, Rick! Cheers, Peter Rick Griewski 1 Link to comment Share on other sites More sharing options...
