Rick Griewski Posted February 11, 2021 Author Share Posted February 11, 2021 (edited) The one hole to two hole conversion is complete. The canopies are miss matched; the rear one is a vac part that needs help. I have the pattern so I will have to make another using thicker plastic. The bulkhead/fin behind the instructors seat will be shaped to fit. After really looking at period photos I will need to create top space in front of the instructor's cockpit. The canopy will sit correctly and the instrument panel will fit correctly. The rear canopy should be the same height as the front canopy and just a bit shorter than the bulkhead/fin. The other thing I noticed was that the roll over pylon looks like it was fairly crude and not an airfoil shape. It looks to be made of wood slabs with a hole so that the instructor can see through/under it. See reference photo below. Edited February 13, 2021 by Rick Griewski added pointer to pylon reference BradG, LSP_Kevin, mywifehatesmodels and 1 other 4 Link to comment Share on other sites More sharing options...
dennismcc Posted February 11, 2021 Share Posted February 11, 2021 This is different and looks like it will be pretty unique when finished, reading this also reminded me that I do have a Claude in the stash, I must get round to it one day. Cheers Dennis Link to comment Share on other sites More sharing options...
Rick Griewski Posted February 13, 2021 Author Share Posted February 13, 2021 (edited) I found a reference for the rollover pylon. Note the slab type construction with what appears to be stream line fairing on the top. Edited February 13, 2021 by Rick Griewski clarification BradG 1 Link to comment Share on other sites More sharing options...
Rick Griewski Posted February 13, 2021 Author Share Posted February 13, 2021 Further study of the canopies and the kit revealed that the A5M2b donor kit includes two canopies. One is what appears to be the A5M4 canopy and the other is for the A5M2b that i will use for the rear cockpit. (See Maru Mechanic) The hole in the rear canopy wind screen needs to be dealt with but overall using is will be better than the vac part. The photo above actually shows the two kit canopies in place. BradG 1 Link to comment Share on other sites More sharing options...
