RLWP Posted July 14, 2020 Share Posted July 14, 2020 57 minutes ago, LSP_K2 said: I actually considered making an entire section from brass or copper sheet, then mashing it out of shape/adding bullet/shrapnel damage, but haven't decided to pursue that approach,... yet. I have no earthly idea what the gauge of the actual material used was, but I'm reasonable sure that it wasn't too stout. 10ga would probably be a close guess. It won't be too thin, it has to be soldier-proof. I'm not talking about the enemy either - squaddy-proof is a pretty high level of indestructibility Richard LSP_Matt, LSP_K2 and chrish 2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 14, 2020 Author Share Posted July 14, 2020 I'd love to see some details of the mudguard connector strips, but that's been one detail that has eluded me for years. Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 14, 2020 Author Share Posted July 14, 2020 After debating this at length last night, I've decided to resume work on this Dragon Bf 109E, but not until this model is absolutely finished. The '109 is mostly complete already, and all AM needed is accounted for, so it seems a logical choice for completion as another entry in our 2021 regional. Ultimately I'd like to complete three or four kits for entry, but I'm in no way confident that will happen. Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 15, 2020 Author Share Posted July 15, 2020 2 hours ago, RLWP said: It won't be too thin, it has to be soldier-proof. I'm not talking about the enemy either - squaddy-proof is a pretty high level of indestructibility Richard 10ga. is pretty stout stuff. For mudguards, unlike the protective plates around a StuG or Panzer IV, thinner is usually the norm. Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 15, 2020 Author Share Posted July 15, 2020 New gusset added to light support. I'm very happy to get one more small, yet needed item, out of the way. Gazzas and Greg W 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 15, 2020 Author Share Posted July 15, 2020 I found a method I very much like for representing fine cast texture, so here I've added it to upper hull face. I may subdue this a tad, once it's thoroughly dry. Greg W, chrish, LSP_Ray and 1 other 4 Link to comment Share on other sites More sharing options...
Juggernut Posted July 15, 2020 Share Posted July 15, 2020 Were these plates cast or rolled armor plate? Anyway, it looks like you've used the Mr. Surfacer 500 trick to represent that detail. LSP_Matt 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 15, 2020 Author Share Posted July 15, 2020 4 minutes ago, Juggernut said: Were these plates cast or rolled armor plate? Anyway, it looks like you've used the Mr. Surfacer 500 trick to represent that detail. The front plate was definitely cast. I suppose it needed to be to accommodate the large expanded/flared area around the gun. And yes, surfacer daubed with a Scotch-Brite pad is what produced that result. Gazzas and Juggernut 2 Link to comment Share on other sites More sharing options...
Juggernut Posted July 15, 2020 Share Posted July 15, 2020 (edited) 30 minutes ago, LSP_K2 said: The front plate was definitely cast. I suppose it needed to be to accommodate the large expanded/flared area around the gun. And yes, surfacer daubed with a Scotch-Brite pad is what produced that result. I guess it would have to be cast with that bulbous gun opening in it. Well done, sir, well done. Edited July 15, 2020 by Juggernut LSP_K2 and Ryan 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 16, 2020 Author Share Posted July 16, 2020 7 hours ago, Juggernut said: I guess it would have to be cast with that bulbous gun opening in it. Well done, sir, well done. It's sort of odd, but kit has nice texture on the raised area, but none on the face itself, so I'm adding my own. chrish 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 16, 2020 Author Share Posted July 16, 2020 Tomorrow I'll be gluing all three engine deck pieces onto the hull, so I used tonight to wrap up some details with all three. All welds now done, and small P.E. piece (it fits perfectly), added to engine deck. Juggernut, Troy Molitor, LSP_Matt and 3 others 6 Link to comment Share on other sites More sharing options...
Troy Molitor Posted July 16, 2020 Share Posted July 16, 2020 Looking forward to seeing the smaller bits added to the bigger (much bigger) BITS! LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 17, 2020 Author Share Posted July 17, 2020 One small thing that I don't like, is the additional post for mounting the sledge. While I understand why they did it this way, it's still annoying. Post will be removed and handle cleaned up. Post mounting hole plugged and will be obliterated with some sanding. Gazzas 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 17, 2020 Author Share Posted July 17, 2020 While these depressions around the hatch are present on the real deal, they're much more subdued (shallow) than kit depicts them, so here they've received the first of what will end up being two or three applications of surfacer. Gazzas and LSP_Matt 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 17, 2020 Author Share Posted July 17, 2020 Front right fender segment is now ready for installation, which will come much later. Gazzas 1 Link to comment Share on other sites More sharing options...
