I am continuing with my journey in building some WWI aircraft with the WNW Albatros DV "Wooden Wonders" kit.  I chose this kit because I wanted to try my hand at replicating unpainted wood using one of the Uschi van der Rosten decal sets made for that purpose.  I usually let my little girl pick the scheme of the aircraft that I build and this one is no different.  She is still deciding between Han Waldhausen's aircraft or the one flown by Adolf Schreder.  She likes both the moon and star motif on Waldhausen's bird, but is also quite taken by the red lightning bolt arrow of the Schreder DV.  She solemnly told me in her five year old way that she will have a decision tomorrow. B)
The two main differences between this aircraft and the DVII kit is that you can't see the cockpit area as well due to the curvature of the fuselage, much like the F4F Wildcat or F6F Hellcat.  So I did not go wild with detailing only adding control cables which you can barely see, the rest is straight oob.  On the other hand, the engine is far more exposed than on the DVII so I am doing some scratch building on it; we shall see how it turns out.
IMG_1475
 The completed cockpit area.  I did not bother to eradicate the pin marks or remove seams from areas that will not be seen once everything is closed up.
IMG_1478
Another shot of the pit.  The gauges are pretty nice and fit well.
IMG_1485
Engine compartment.  I did do a bit of wood graining on the dark wood pieces, though I highly doubt they will be seen when the kit is finished.
IMG_1474
I am using some Taurus Models AM on the engine.  The springs were a challenge to install and I did not get everything 100% perfect.
IMG_1481
But once all the pieces were in place it looks pretty presentable.
IMG_1487
I am also using a few of the ANYZ fittings for some scratchbuilt lines I intend to run.  You can see two of the fittings in this shot, one at the front of the engine block and
one just to the right of the rear engine mount.
IMG_1483
Finally I tried to replicate the asbestos wrapping with Teflon tape.  It turned out fairly well and hopefully will paint up nice.
Edited by Greif8
Grammer
I finished the engine today.  As it appears that more of the engine will be visible than on the D VII I decided to add some Taurus AM spark plugs and lifters with valves.  I did not get everything perfect with those parts, but the end result turned out presentable.  I also added a few copper lines that I ran between drilled out locations to some ANYZ fittings that I thought looked the part.  I could not get a good focus on the parts I wrapped in teflon tape and will try to get a good shot of that when I post the weathered engine.
IMG_1490
Starboard side overall photo.  The spark plugs were fiddly to get lined up, a mounting stub at the rear would have made the job easier, but they look pretty decent once painted.  You can also see that I forgot to remove the seam from the water pipe.  As I highly doubt it will be seen once the engine is in the plane I decided to leave it as is; wont make that mistake again though.
IMG_1491
Port side showing a couple of the lines I made and the plug wiring.
IMG_1497
Close up shot, spark plugs look good seam not so much!
IMG_1502
Extreme close up showing one of the valves and lifters and a spark plug.
IMG_1504
One of the ANYZ fittings, with line fitted, still need to clean up the join, macro photography captures the good the bad and the ugly!
On 1/25/2020 at 1:25 PM, Greif8 said:
                                ... the WNW Albatros DV "Wooden Wonders" kit.
Got one of those in the mail a coupla days ago.  :popcorn:
Nice work so far.
On 1/28/2020 at 5:17 AM, Dpgsbody55 said:
Looks fantastic.  Your engine detailing is great.  :goodjob:
:popcorn:
Michael
Nice work so far.
On 1/29/2020 at 4:51 AM, Out2gtcha said:
Great start!
Thank you guys!
I airbrushed the base "wood" color on the fuselage yesterday.  I tried to get a fairly light color but also get a warm tone by mixing a few of my Tamiya colors.  It looks fairly accurate, but of course the proof will be when I apply the van der Rosten wood grain decals.  Having never done that before, it will be a tense undertaking to say the least.  Hopefully I can do it justice and not botch the job; we will know by tomorrow evening!
IMG_1509
An uninspiring photo of the fuselage before a sprayed the gloss coat.  More to follow once I start decaling.
Making progress with the van der Rosten "wood veneer" decals.  Very concentration intensive work!  I have to get rid of a couple of small air bubbles yet, but things are progressing well thus far.  Of course I have yet to get to the difficult areas.
IMG_1510
Still need to eradicate some small air bubbles behind the cockpit, but its coming along.  I am varying the decals to avoid too much "sameness".
As he wrote above,  he use "Woodgrain" decals from "Uschi van de Rosten" company...I thougt, there is only one version "woodpattern" availiable? :huh:
Edited by Knightofthesky
A few more photos of the progress.  As expected the areas around the tail fin with their somewhat compound curves were a challenge.  Looks like I'm a bit over half way with this little decaling project.  They do require a great deal of patience and concentration, and also a very steady hand with a scalpel - but look pretty good once in place.  The glare is due to the harsh direct light on my bench, and I am hoping that once I gloss coat the decals they will come to life.
IMG_1512
IMG_1513
IMG_1514
I finished putting on the van der Rosten wood decals and gloss coated the fuselage.  This was a learning experience and one of the most intense decaling jobs I have ever done.  The end result is pretty decent but it was a lot of work to get to the finish line on this "sub-assembly".  The decals are excellent but are definitely not for beginners.  By necessity they are very thin and as a result the corners tend to fold over on themselves if you are not very careful when placing them.  They work well and are a bit elastic which helps to avoid any bad wrinkles and to get the decal snug against things like service hatches.  I still have to buff the gloss coat once it cures, but I think the effect looks pretty good right now.  I will use the decals again, and may give the one of the HGW sets a try on a future build to see if they are as good in quality as the VdR set.
IMG_1515
IMG_1519
IMG_1516
IMG_1521
I decided to put the fuselage decals on as I thought it would be easier to do so before I stalled the engine, tail plane, wings, etc.  The decals that came with the "Wooden Wonder's" kit are very nice and went down very well though I cheated with the horizontal black line on both sides.  I airbrushed that as I generally detest "walkway" type decals as I can almost never get them straight.  I will let them cure overnight and airbrush a final gloss coat tomorrow.  After that I plan to install the engine and put the engine panels in place after painting them.  This build is coming along a bit better than the D VII, though that was a very nice kit that built up without a fight as well.  I bought some Aviattic decals for the wings and rudder and hope I can install them better than I managed with the D VII - we shall see.  Enjoy the photos.
IMG_1524
IMG_1527
IMG_1525
