Pete Fleischmann Posted June 19, 2020 Author Share Posted June 19, 2020 18 minutes ago, brahman104 said: Love the rivet work Pete! I did the same with my CH-47 a few years ago; big job but worth it!!! What did you use to fill the existing rivets? Craig Thanks Craig- this stuff: Martinnfb and brahman104 2 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted June 19, 2020 Author Share Posted June 19, 2020 2 hours ago, scvrobeson said: Such awesome work. I can only imagine how tedious it is measuring out each rivet line, but the result is definitely worth it. Matt Thanks Matt- definitely tedious. I use a very good set of architects proportional dividers to measure- helps a lot! cheers Pete scvrobeson 1 Link to comment Share on other sites More sharing options...
Timmy! Posted June 19, 2020 Share Posted June 19, 2020 Gunna be worth it when the horror ends! A-10LOADER and Pete Fleischmann 1 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted June 19, 2020 Author Share Posted June 19, 2020 46 minutes ago, Timmy! said: Gunna be worth it when the horror ends! You kinda have to say that...(which I appreciate) seeing as you were the guy that talked me into doing it, ‘member? A-10LOADER 1 Link to comment Share on other sites More sharing options...
Timmy! Posted June 19, 2020 Share Posted June 19, 2020 I mamember. Just adding emphasis to how I convinced you before! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Basta Posted June 19, 2020 Share Posted June 19, 2020 4 hours ago, Pete Fleischmann said: Hey all- slow and steady progress cheers Pete You missed one. Just kidding, been following this in admiration, and now commiseration. Fantastic work! Pete Fleischmann and F`s are my favs 2 Link to comment Share on other sites More sharing options...
Jim27F Posted June 19, 2020 Share Posted June 19, 2020 Excellent job !!!!!!! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted June 24, 2020 Author Share Posted June 24, 2020 Pressing on! having good luck so far. I measure each run with the dividers, then transfer that measurement to the decal. I trim the decals pretty tight. Solvaset has all but eliminated the carrier film. I avoid the temptation to do one long continuous run- it is much easier to keep every rivet line straight if you butt shorter lengths. cheers Pete chuck540z3, Starfighter, Fvdm and 17 others 19 1 Link to comment Share on other sites More sharing options...
Timmy! Posted June 24, 2020 Share Posted June 24, 2020 Dividers? So you're not ACTUALLY counting rivets? scvrobeson, Neo, Pete Fleischmann and 3 others 1 1 4 Link to comment Share on other sites More sharing options...
easixpedro Posted June 24, 2020 Share Posted June 24, 2020 Dude. That's a LOT of work. But it's going to look amazing under a coat of paint with your painting skills! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted June 24, 2020 Author Share Posted June 24, 2020 39 minutes ago, Timmy! said: Dividers? So you're not ACTUALLY counting rivets? I lose count over like...seven. Link to comment Share on other sites More sharing options...
Timmy! Posted June 24, 2020 Share Posted June 24, 2020 2 hours ago, Pete Fleischmann said: I lose count over like...seven. How many fingers have you lost? The average male should be able to count to eleven.. Dutch Man 1 Link to comment Share on other sites More sharing options...
Nick Posted June 24, 2020 Share Posted June 24, 2020 Great build Pete. I have truly enjoyed it. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted June 25, 2020 Author Share Posted June 25, 2020 1 hour ago, Timmy! said: How many fingers have you lost? The average male should be able to count to eleven.. or 10 and a half- Dutch Man 1 Link to comment Share on other sites More sharing options...
brahman104 Posted June 25, 2020 Share Posted June 25, 2020 Sooo good!!! Craig Link to comment Share on other sites More sharing options...
