sandbagger Posted April 21, 2019 Author Posted April 21, 2019 (edited) Hi all, Tachometer drive added from gun synchronization mechanism. The two carburetor fuel feed pipes from the gallery behind the instrument panel, The two machine gun trigger cables from the control column to the gun synchronization mechanism, Mike Edited April 21, 2019 by sandbagger Fvdm, LSP_Kevin, Tnarg and 1 other 4
sandbagger Posted April 22, 2019 Author Posted April 22, 2019 Hi all, Leads fitted from the magneto starter behind the instrument panel to both engine driven magnetos, Mike Greg W and LSP_Kevin 2
sandbagger Posted April 22, 2019 Author Posted April 22, 2019 Hi all, 'Spark Advance' control (Ignition Timing) fitted from cockpit lever to engine magnetos linkage rod. Made from 0.3 mm brass tube, 0.1 mm Nickel-Silver rod and scratch link. Mike Whitey, Fvdm, Model_Monkey and 3 others 6
sandbagger Posted April 23, 2019 Author Posted April 23, 2019 Hi all, Throttle control run added from pilot's throttle lever to the linkage on the dual carburettors. Scratch made from 0.1 mm Nickel-Silver rod and 0.3 mm brass tube with the pivot lever created from 'spare' photo-etch, Mike Greg W, Tnarg and LSP_Kevin 3
sandbagger Posted April 23, 2019 Author Posted April 23, 2019 Hi all, Control cable for the hand operated throttle added. Lead wire 0.2 mm diameter, from hand throttle on the control column, down and under the floor, up side frames and across the throttle quadrant. Then down the other side, under the floor and back up to the hand throttle. Mike MikeMaben, John1, LSP_Kevin and 3 others 6
sandbagger Posted April 24, 2019 Author Posted April 24, 2019 Hi all, Generator lead and seat connector fitted. Generators were not standard fit, but were installed to some aircraft to power heated flying suits later in WW1 and if carried, wireless transmitters. Made from 0.4 mm diameter Nickel-Silver micro-tube and 0.148 mm diameter match line. Mike Model_Monkey, Out2gtcha, TorbenD and 3 others 6
sandbagger Posted April 26, 2019 Author Posted April 26, 2019 Hi all, Radiator with photo-etch front and rear cooling core and scratch made pilot operated flap (to control engine cooling), Mike TorbenD, Tolga ULGUR, bstachel and 4 others 7
Fvdm Posted April 26, 2019 Posted April 26, 2019 That's great looking radiator. I think i know what you do for a living, you must be a plumber.
sandbagger Posted April 27, 2019 Author Posted April 27, 2019 Heh he - close - RAF Propulsion Technician of 27 years followed by 20 years writing military aircraft maintenance manuals.
sandbagger Posted April 27, 2019 Author Posted April 27, 2019 Hi all, Radiator flap control now fitted. Made from micro-tube (0.4 mm and 0.1 mm diameter), photo-etch pulley and 0.125 mm copper wire for the loop handle, Mike Greg W, LSP_Kevin and Model_Monkey 3
sandbagger Posted April 27, 2019 Author Posted April 27, 2019 Hi all, Radiator side stays fitted, Mike LSP_Kevin, Fvdm, Model_Monkey and 1 other 4
spacewolf Posted April 28, 2019 Posted April 28, 2019 OMG this is stunning !! Brilliant work.. one would think that radiator was real...
sandbagger Posted April 29, 2019 Author Posted April 29, 2019 Hi all, The front end gas been weathered up a bit to keep it aligned with the associated Fokker D.VII model. It's ready now for cross brace rigging and the fitting of the twp machine guns with their synchronization drive cables, Mike Model_Monkey, LSP_Kevin, Tolga ULGUR and 2 others 5
