Fanes Posted February 7, 2019 Author Share Posted February 7, 2019 I'm not entirely sure on the interior colour. Since I want to depict 5F+YK, there is a little problem of which airframe exactly wore that code. There's one in overall RLM78/79 (W.Nr. 2408) which was photgraphed in 1942. I guess the cockpit would have been RLM02? Then there seems to be another airframe in RLM78/79/80 (W.Nr.3454) without a particular date on the photo, but I guess it should have a RLM66 cockpit. The closer I look, the more confusing it gets! Link to comment Share on other sites More sharing options...
Sepp Posted February 7, 2019 Share Posted February 7, 2019 Well, aircraft get moved around, reassigned, shot down and codes get reused, so I guess it's not too unusual to find two different airframes with the same code. 5F+YK was also worn by a Fi 156, for instance. Maybe you could start a shelf dedicated to that one code Fanes 1 Link to comment Share on other sites More sharing options...
Fanes Posted February 7, 2019 Author Share Posted February 7, 2019 2 hours ago, Sepp said: Maybe you could start a shelf dedicated to that one code Indeed a build of a Storch in desert scheme is on my list! I've seen pictures of the Fi 156 as 5F+YK before, but thanks for the reminder. This Storch wore the markings in 1941, the Bf 110 W.Nr.2408 (previous 2.F/123) wore it in 1942 which leaves only a later date for W.Nr.3454. I really like the RLM78/79/80 scheme on a Bf 110, but on the other hand there are builds of a Bf 109F-4 and Fw 190F-8 painted RLM79/80 in the pipeline, too. Out2gtcha, Shawn M, mozart and 1 other 4 Link to comment Share on other sites More sharing options...
mozart Posted February 7, 2019 Share Posted February 7, 2019 Do it whatever colour you wish Joachim, nobody's going to tell you it's wrong. RLM02 sounds right for the date, and it gives a more interesting interior in my experience. Shawn M 1 Link to comment Share on other sites More sharing options...
Fanes Posted February 10, 2019 Author Share Posted February 10, 2019 The interior colour question is delayed until my camera frame arrives! SInce I needed a little break from painting my smalls cale 109, I revisited the cockpit. The instrument panel looks quite nice, but painting the instruments itself may be quite fiddly. I don't think that decals will work on the raised details. Compared to the pictures in John Vasco's book the kit panel seems nearly complete. Two little things are missing: the Revi power plug (will be added together with the Quickboost Revi 12) and the two small lamps above the IP. On to the left side of the cockpit: Pretty sparse! The distinctive map case (n.11 in the picture), the rivets on the c shaped profile and again the lamp (n.3) are missing. But worst of all: The wing root opening will be visible after closing up everything. The right side of the cockpit recieved more attention from the Dragon designers. There's just some small stuff on the console missing. Another small glitch: the opening for the pipe/cable from the oxygen regulator (right of n.3) is in the wrong place. Nothing too hard to fix, except the valves (?) marked as n.9 in the picture. I have no idea how to scratch those! So I put some elbow grease, lots of swearing and searching for small parts in and here's the result so far: Looking at the picture I realized that the map case needs some attention and the lightening hole in the left console some cleanup. Still thinking about the two small valves (or whatever those are).. Since I had my favourite copper wire out, I went on adding cables to the rear cockpit. The instrument housings aren't perfect but they won't be visible since a cover will be added later on. The rightmost instrument was faired over because it represents a shot counter for the MG FF not necessary for a recon bird. Thats's it for today. Joachim mpk, Erwin, mozart and 6 others 9 Link to comment Share on other sites More sharing options...
Azgaron Posted February 10, 2019 Share Posted February 10, 2019 Looking good! Nice with the pics too! Håkan Fanes 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 10, 2019 Share Posted February 10, 2019 Nice work, Joachim! Kev Fanes 1 Link to comment Share on other sites More sharing options...
Shawn M Posted February 10, 2019 Share Posted February 10, 2019 the hole in your throttle quadrant is actually a stamped depression or maybe a cover. That said, nice work in there! Link to comment Share on other sites More sharing options...
mozart Posted February 10, 2019 Share Posted February 10, 2019 I hope this is all just dry fitted......if not I don't envy you having to paint it!! Super work Joachim. Link to comment Share on other sites More sharing options...
Fanes Posted February 10, 2019 Author Share Posted February 10, 2019 35 minutes ago, Shawn M said: the hole in your throttle quadrant is actually a stamped depression or maybe a cover. That said, nice work in there! Do you have a clear picture from the side? I didn't find any and went with the impression from the first picture in my post where it looks like a hole. Closing the hole from behind shouldn't be a big problem either! 19 minutes ago, mozart said: I hope this is all just dry fitted......if not I don't envy you having to paint it!! Super work Joachim. That would be a mess - so far everything except the right console is just dry fitted. I gently ripped of the throttle quadrant to ease up painting. Link to comment Share on other sites More sharing options...
MikeMaben Posted February 11, 2019 Share Posted February 11, 2019 (edited) 3 hours ago, Fanes said: Do you have a clear picture from the side? I didn't find any and went with the impression from the first picture in my post where it looks like a hole. Looks like a hole ... hth Edited February 11, 2019 by MikeMaben florin13, mpk and Fanes 2 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted February 11, 2019 Share Posted February 11, 2019 Nice detail work! Fanes 1 Link to comment Share on other sites More sharing options...
Fanes Posted February 11, 2019 Author Share Posted February 11, 2019 7 hours ago, MikeMaben said: Looks like a hole ... hth Thanks Mike! One more thing came to my mind: if it's a hole, the levers and linkage behind should be visible - more scratch building! mpk 1 Link to comment Share on other sites More sharing options...
Shawn M Posted February 11, 2019 Share Posted February 11, 2019 (edited) thats a very unique photo, notice the floor board is missing, early style rudder pedals and the yoke boot is also missing. I will try to find a pic for you if you'd like, the above clearly shows a hole so either way could be right! Yet another '110 mystery Edited February 11, 2019 by Shawn M Link to comment Share on other sites More sharing options...
Fanes Posted February 11, 2019 Author Share Posted February 11, 2019 44 minutes ago, Shawn M said: thats a very unique photo, notice the floor board is missing, early style rudder pedals and the yoke boot is also missing. I will try to find a pic for you if you'd like, the above clearly shows a hole so either way could be right! Yet another '110 mystery You're absolutely right about the uniqueness of the photo. The numbering of the parts in Mike's picture makes it likely to be from W.Nr.2831, too. This particular 110 (a C-1) was shot down by swiss Bf 109s in 1940 and was inspected by their authorieties. This would justify the missing yoke boot, cockpit floor and of course an inspection panel (?) on the throttle quadrant. So a picture from another plane is highly welcome to clear this matter! Link to comment Share on other sites More sharing options...
