zak Posted November 19, 2016 Share Posted November 19, 2016 Hi folks. Im racking my brain on how to create the canopy seals on my current AH-1W build. Im specifically talking about the black/grey rubber seals on the interior of the canopy (see photo) I'd rather not paint them on as I'm after a more 3d effect so any ideas/suggestions on what material to use would be helpful Zak Zero77, BiggTim and F`s are my favs 3 Link to comment Share on other sites More sharing options...
Guest Posted November 19, 2016 Share Posted November 19, 2016 No idea, but if you pull it off, it would really pop.....Harv Link to comment Share on other sites More sharing options...
zak Posted November 19, 2016 Author Share Posted November 19, 2016 No idea, but if you pull it off, it would really pop.....Harv Yea i think it would Harv. Im thinking maybe milliput black rolled and carefully attached on? May also mean I won't need to glue it on to the canopy as it's sticky whilst it's curing....🤔 Link to comment Share on other sites More sharing options...
Guest Posted November 19, 2016 Share Posted November 19, 2016 HMMM, its worth a try. Have to be a very small roll........Harv Link to comment Share on other sites More sharing options...
Timmy! Posted November 19, 2016 Share Posted November 19, 2016 For the record, and just for something of an edjumacation point, the "seal" is not a seal. It is explosive cord for emergency egress. You might try thin black vinyl tape, then seal it in with Future and add a layer of dark gray paint to finish the effect. Tricky to mask but doable. Timmy! BiggTim, zak and Zero77 3 Link to comment Share on other sites More sharing options...
Bill_S Posted November 19, 2016 Share Posted November 19, 2016 Small gauge wire insulation? zak 1 Link to comment Share on other sites More sharing options...
GrahamF Posted November 19, 2016 Share Posted November 19, 2016 What about that thin rubber you get inside fabric elastic material? Although I'm not sure if it comes in black. zak 1 Link to comment Share on other sites More sharing options...
Jeff Posted November 19, 2016 Share Posted November 19, 2016 cut a rubber band ( elastic band) ?? Just a random thought Jeff zak 1 Link to comment Share on other sites More sharing options...
Mister J Posted November 19, 2016 Share Posted November 19, 2016 EZ Line? zak 1 Link to comment Share on other sites More sharing options...
BiggTim Posted November 19, 2016 Share Posted November 19, 2016 A very thin strip of black electrical tape might do it. It's already adhesive, the right finish, and would look the part stuck to the clear canopy. You could even paint it gray on the inside. Tim Jeff and zak 2 Link to comment Share on other sites More sharing options...
wunwinglow Posted November 19, 2016 Share Posted November 19, 2016 (edited) There is a silicone rubber material called 'SUGRU' which comes in tear open pouches. You knead it to shape and it sets over the following day or so. comes in a variety of colours. Have used it for various bike repairs etc, but rolled out into thin worms, might do the trick? Sticks like the proverbial, by the way..... Usual disclaimers, no commercial links. www.sugru.com Edited November 19, 2016 by wunwinglow zak 1 Link to comment Share on other sites More sharing options...
F`s are my favs Posted November 19, 2016 Share Posted November 19, 2016 The electrical tape is elastic and when its adhesive layer makes contact with glass surface - it provides some kind of a "wet" effect, but there may also appear bubbles or wrinkles or tiny areas that can`t adhere to the glass, and they will look not good. Or, the elastic effect of the tape could make it peel off or fall off from the glass surface after a few days. I would prefer long thin pieces of painted paper tape. It`s easier to follow the curves of the frame and you can paint it with the exact color. zak 1 Link to comment Share on other sites More sharing options...
Joe66 Posted November 19, 2016 Share Posted November 19, 2016 If it were me, I would probably try a combination of very small diameter brass wire and thin strips, bent to shape, and soldered, then paint and attach with white glue. The advantage is that the brass can be worked and shaped for an exact fit separately then attached. -Joe zak 1 Link to comment Share on other sites More sharing options...
zak Posted November 20, 2016 Author Share Posted November 20, 2016 For the record, and just for something of an edjumacation point, the "seal" is not a seal. It is explosive cord for emergency egress. You might try thin black vinyl tape, then seal it in with Future and add a layer of dark gray paint to finish the effect. Tricky to mask but doable. Timmy! Thanks for the edjumacating Timmy! Yes I'm considering vinyl tape, good call Link to comment Share on other sites More sharing options...
jenshb Posted November 20, 2016 Share Posted November 20, 2016 Thin lead wire (forms more easily than copper or brass) painted black or very dark grey held in place with Future would be my first thought... Jens Link to comment Share on other sites More sharing options...
