Antonio Argudo Posted May 2, 2021 Share Posted May 2, 2021 great results, perfect craftsman skills, keep up the amazing work on this! cheers Antonio airscale and 109 1 1 Link to comment Share on other sites More sharing options...
109 Posted May 2, 2021 Author Share Posted May 2, 2021 18 minutes ago, Antonio Argudo said: great results, perfect craftsman skills, keep up the amazing work on this! cheers Antonio Hope you get started on your Bf109 soon! Antonio Argudo 1 Link to comment Share on other sites More sharing options...
109 Posted May 14, 2021 Author Share Posted May 14, 2021 Hi all, has anyone a cross section of the cockpit area showing the angles of the side consoles, pls? TIA :-) Link to comment Share on other sites More sharing options...
dodgem37 Posted May 15, 2021 Share Posted May 15, 2021 This is what I have. Hope they're helpful. Sincerely, Mark 109, Model_Monkey, HerculesPA_2 and 2 others 4 1 Link to comment Share on other sites More sharing options...
109 Posted May 15, 2021 Author Share Posted May 15, 2021 1 hour ago, dodgem37 said: This is what I have. Hope they're helpful. Sincerely, Mark Thanks a lot! Anthony in NZ 1 Link to comment Share on other sites More sharing options...
airscale Posted May 17, 2021 Share Posted May 17, 2021 On 5/14/2021 at 5:14 PM, 109 said: Hi all, has anyone a cross section of the cockpit area showing the angles of the side consoles, pls? TIA :-) I did some decal & PE artwork for my V18 that was from some factory drawings - the consoles match to either side of the bottom instrument panel so can be seen here - this is the revised panel for a D model I was going to send you Peter D.B. Andrus, Anthony in NZ, Model_Monkey and 3 others 5 1 Link to comment Share on other sites More sharing options...
109 Posted May 25, 2021 Author Share Posted May 25, 2021 On 5/17/2021 at 4:28 PM, airscale said: I did some decal & PE artwork for my V18 that was from some factory drawings - the consoles match to either side of the bottom instrument panel so can be seen here - this is the revised panel for a D model I was going to send you Peter Thanks Peter! Link to comment Share on other sites More sharing options...
109 Posted May 25, 2021 Author Share Posted May 25, 2021 Hi all, I am doing the armor behind the pilot´s seat: This is the config of the A-8 and therefore I think for early D-9, too. Is this correct? Also: the green lower plate: is this the correct orientation or do I have to rotate it by 180° counter clockwise? I have the spare part list of the A-8 and D-9 and a photo of a restored A-8 that shows this plate in both orientations ... either the spare part list is wrong or the restoration work .... TIA :-) Derek B, Trak-Tor, Anthony in NZ and 2 others 5 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted May 25, 2021 Share Posted May 25, 2021 wonderful job, maybe this is interesting for you , cheers http://arsenal45-shop.de/product_info.php?info=p898_----spant-5-rechts---focke-wulf-fw190-a-d-f-g-und-ta152-h----.html http://arsenal45-shop.de/product_info.php?info=p917_----spant-5-links---focke-wulf-fw190-a-d-f-g-und-ta152-h----.html http://arsenal45-shop.de/product_info.php?info=p916_----panzerung-linke-seitenwand-fuehrerraum---focke-wulf-fw190-a-d-f-g-und-ta152-h----.html Trak-Tor 1 Link to comment Share on other sites More sharing options...
109 Posted May 25, 2021 Author Share Posted May 25, 2021 2 minutes ago, Antonio Argudo said: wonderful job, maybe this is interesting for you , cheers http://arsenal45-shop.de/product_info.php?info=p898_----spant-5-rechts---focke-wulf-fw190-a-d-f-g-und-ta152-h----.html http://arsenal45-shop.de/product_info.php?info=p917_----spant-5-links---focke-wulf-fw190-a-d-f-g-und-ta152-h----.html http://arsenal45-shop.de/product_info.php?info=p916_----panzerung-linke-seitenwand-fuehrerraum---focke-wulf-fw190-a-d-f-g-und-ta152-h----.html Thanks, interesting stuff. I will try to contact them Any source shows some different plate outlines Link to comment Share on other sites More sharing options...
dodgem37 Posted May 26, 2021 Share Posted May 26, 2021 This is what I have: What do the colors represent? Thank you. Sincerely, Mark 109 1 Link to comment Share on other sites More sharing options...
109 Posted May 26, 2021 Author Share Posted May 26, 2021 1 hour ago, dodgem37 said: This is what I have: What do the colors represent? Thank you. Sincerely, Mark Hi, Thanks! Have that info, too. D-9 and A-8 Spare Parts List. Colors are just to sperate the plates visually for me. Link to comment Share on other sites More sharing options...
109 Posted June 1, 2021 Author Share Posted June 1, 2021 (edited) Hi, some progress... I made a jig for mounting the seat rails from MDF and a styrene strip that slides into the C-profile: Dry fitting of parts is actually quite okay.... I cut paper templates of the armor plates to get the diminsions right ... I then cut the plates from 0.5 mm alu sheet, the alu is quite soft which makes it tricky to cut and drill. Parts need to be polished and cleaned... dryfitting: Time to make the Käsespätzle for tonights dinner..... Edited June 1, 2021 by 109 Antonio Argudo, LSP_Kevin, HerculesPA_2 and 10 others 13 Link to comment Share on other sites More sharing options...
airscale Posted June 1, 2021 Share Posted June 1, 2021 wonderful - it's like taking a seat in the factory in Bremen Peter Derek B and 109 1 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 2, 2021 Share Posted June 2, 2021 Seriously amazing work going on here! Kev 109 1 Link to comment Share on other sites More sharing options...
