F`s are my favs Posted June 29, 2016 Author Share Posted June 29, 2016 ))) Btw the pylon is done: There is a huge pin running from rail to rail for greater structural support: Because it will be with mountable loadouts - with magnets, and should be very strong. And the best thing is that even test fitted looks prepped and ready for painting. Yet the painting will be along with the model itself, quite later. I have the pylons of the C in 1/48 dismantled - so a quick comparison ) LSP_Paul, Zero77 and allthumbs 3 Link to comment Share on other sites More sharing options...
F`s are my favs Posted June 29, 2016 Author Share Posted June 29, 2016 I realize now that these pylons are so huge that they play a role as "small" vertical stabilizers as well. Link to comment Share on other sites More sharing options...
Luca Posted June 29, 2016 Share Posted June 29, 2016 great job on those pylons sir... and great rails. F`s are my favs 1 Link to comment Share on other sites More sharing options...
F`s are my favs Posted June 29, 2016 Author Share Posted June 29, 2016 PS: the quality of the pics is such cause i forgot to switch on the lights... scuse me I noticed that 2 small "casters" should be added near the tip of each rail, then - hm, okey, let`s prime it, and after a very thin layer of surfacer: LSP_Paul and Daniel Leduc 2 Link to comment Share on other sites More sharing options...
F`s are my favs Posted July 4, 2016 Author Share Posted July 4, 2016 I filled the panel lines of the CFTs: And I started with some "texturising" of the bottom fuselage and i`m very happy indeed. I think to continue with the entire plane. Here is the fuselage before, like mirror flat: Only the area of the heat shield is done and only from the one side of the engine starter (i forgot the exact name). It`s barely visible and only at this angle: LSP_Paul, Deadpool, allthumbs and 2 others 5 Link to comment Share on other sites More sharing options...
Deadpool Posted July 4, 2016 Share Posted July 4, 2016 Hey F, Sweet work so far mate. Detail is sickening. Awesome stuff. F`s are my favs 1 Link to comment Share on other sites More sharing options...
allthumbs Posted July 4, 2016 Share Posted July 4, 2016 (edited) That skin rippling looks great Favs...can you share with us your technique? Rich Edited July 4, 2016 by allthumbs F`s are my favs 1 Link to comment Share on other sites More sharing options...
F`s are my favs Posted July 4, 2016 Author Share Posted July 4, 2016 Thanks It`s just a knife with a curved blade, of which actually i handle only the blade, and i make very subtle scratches. Not once, but usually >10 repeats of the same area (ripple is an awesome word). Because of the curvature of the blade, the indentations stay curved too, with almost no visible edges like scratching with a pointed blade. After a few tries it appears like the more chaotically - the better. Usually it`s following the panel lines and the rivet lines. The big panels also look good if texturised entirely and not only along the edges. And that`s it, of course after that i sand over the areas with around 800 grit and then with 1500 grit sandpapers, which "restores" the gloss shine of the surfaces. Absolute no loss of panel lines or rivets, because the scratching is very very subtle... i don`t know... like to remove a few shavings or the flash from a detail. And in this kit the panel lines are veeery deep and thick too. This exercise even makes them look a little bit more delicate and normal. NavyF4s and allthumbs 2 Link to comment Share on other sites More sharing options...
F`s are my favs Posted July 4, 2016 Author Share Posted July 4, 2016 The lower fuselage is texturised: Now some extended riveting. Iain, LSP_Paul, ghatherly and 3 others 6 Link to comment Share on other sites More sharing options...
Iain Posted July 4, 2016 Share Posted July 4, 2016 Looks great! Iain F`s are my favs 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted July 4, 2016 Share Posted July 4, 2016 Ambitious start! Keep up the good work. Paul F`s are my favs 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 4, 2016 Share Posted July 4, 2016 That looks BRILLIANT. I am most impressed, I'm about to start a 1/32 hornet and may have to do something like this! Jim NavyF4s and F`s are my favs 2 Link to comment Share on other sites More sharing options...
Shawn M Posted July 5, 2016 Share Posted July 5, 2016 oil canning looks great, really adds another dimension F`s are my favs 1 Link to comment Share on other sites More sharing options...
Chek Posted July 5, 2016 Share Posted July 5, 2016 The skin texture looks very good Fs. You might find that some of the effect disappears once a matt finish is applied, but hopefully not too much. It's certainly more realistic than a mirror-flat surface. F`s are my favs 1 Link to comment Share on other sites More sharing options...
F`s are my favs Posted July 5, 2016 Author Share Posted July 5, 2016 ... some of the effect disappears once a matt finish is applied, but hopefully not too much... Yes definitely, that`s exactly what happened with the underwing pylon after surfacer 1200. Yet the texture is there and should get back after all. Link to comment Share on other sites More sharing options...
