DirkE Posted April 11, 2016 Author Share Posted April 11, 2016 Thanks Brian and Tom! Link to comment Share on other sites More sharing options...
DirkE Posted April 12, 2016 Author Share Posted April 12, 2016 (edited) First paint on. I tried a different approach. First I used a light coat white Alclad primer. Then I got this Gundammarker for the panel lines. After that the Tamiya weatheringset 87088 (hier the oil stain) and applied a bit around the panel lines. Finally I used Mr.Color (mixed with 50% Mr.Thinner) around 20 psi. Not that bad I think. (hmm..I think I need to adjust my white balance on the camera again) Main reason I did that, is that I don´t fill up all the rivets with primer, paint, varnish and then have to try to highlight the fine rivets and panel lines. Edited April 12, 2016 by DirkE Harold and Uncarina 2 Link to comment Share on other sites More sharing options...
DirkE Posted April 12, 2016 Author Share Posted April 12, 2016 finished the cowling. jgrease, Uncarina, rafju and 2 others 5 Link to comment Share on other sites More sharing options...
DirkE Posted April 13, 2016 Author Share Posted April 13, 2016 Update. I decided to close the speed brake, but to open the cargo hatch. But the speed brake needs to be sanded. It isn´t designed to be shown closed. Wings or on. Fitting from the wings to the fuselage is extremly good. Little filling needed. The landing lights on the port side must be closed if you want to model a T-28B Navy version.Overall, a big bird! Harold, Out2gtcha, sandokan and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 13, 2016 Share Posted April 13, 2016 That looks LOVELY! I really like it. Im hoping mine will start to look like a T-28 soon. I bow to you guys who paint parts before they glue them in! Id have glue on, or in some way have messed up that paint and decals if I painted before installation for SURE. Uncarina 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 14, 2016 Share Posted April 14, 2016 This is looking great! Kev Link to comment Share on other sites More sharing options...
Shawn M Posted April 14, 2016 Share Posted April 14, 2016 great work on the red! Link to comment Share on other sites More sharing options...
Uncarina Posted April 14, 2016 Share Posted April 14, 2016 That looks LOVELY! I really like it. Im hoping mine will start to look like a T-28 soon. I bow to you guys who paint parts before they glue them in! Id have glue on, or in some way have messed up that paint and decals if I painted before installation for SURE. Same with me! Your red, as Shawn wrote, looks authentic, which is not easy! Cheers, Tom Out2gtcha 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted April 14, 2016 Share Posted April 14, 2016 Very fine work in this thread, I like it a lot . Cheers M. Link to comment Share on other sites More sharing options...
DirkE Posted April 14, 2016 Author Share Posted April 14, 2016 I have never seen pictures of a Marine bird, just the Navy ones. The Navy brass would go insane seeing their trainers all dirty like that. Great subject, awesome job so far. I just hope you used LOTS of additional weight inside the fuselage. It needs every single ounce you can cram in there, Ernie The weights that come with the kit are 60 Gramm. I figured, that the assembled kit (without gear and paint) is around 130 Gramm. Now I just need the weight of the front and the back part of the plane, do a little mathematics and voila... no, I just use everything I have.... Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 14, 2016 Share Posted April 14, 2016 I have never seen pictures of a Marine bird, just the Navy ones. The Navy brass would go insane seeing their trainers all dirty like that. Great subject, awesome job so far. I just hope you used LOTS of additional weight inside the fuselage. It needs every single ounce you can cram in there, Ernie Did you ever figure out how much extra beyond the OOB weight you needed to make yours sit on all three legs Ern? Link to comment Share on other sites More sharing options...
Shawn M Posted April 14, 2016 Share Posted April 14, 2016 someone needs to make a steel prop bullet and a set of weights to go inside the motor DirkE 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 14, 2016 Share Posted April 14, 2016 Ive calculated Ive got roughly an extra 1.6 Oz above and beyond the two 2.1 Oz OOB weights. DirkE 1 Link to comment Share on other sites More sharing options...
DirkE Posted April 14, 2016 Author Share Posted April 14, 2016 I will attach the engine and the cowling after painting the rest. I hope that gives me enough "help" to estimate the necessary weight. Link to comment Share on other sites More sharing options...
Guest Posted April 14, 2016 Share Posted April 14, 2016 Coming along nicely. When I get around to starting mine I'll be able to come back and check yours and Clunkmeister's builds so I don't make too many mistakes, etc. I'm anticipating some nice PE from Eduard and already have some beautiful resin pieces from Harold at AMS. Also awaiting the upcoming decal sheet from AOA. Keep up the good work! Link to comment Share on other sites More sharing options...
