monthebiff Posted December 18, 2015 Share Posted December 18, 2015 Thank you Iain.... I have always been amazed in Edgar's knowledge and felt very inspired when he commented on my work, I am planning Mk XVI SL721.......as I said, always a sucker for a blue Spit. Regards. Andy Iain 1 Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2015 Share Posted December 18, 2015 I wonder if this conversion is still available? Id like to buy one if it Allycat still sells them and can be found on Ebay, about 50 US dollars....Harvis. Link to comment Share on other sites More sharing options...
Iain Posted December 19, 2015 Author Share Posted December 19, 2015 The Alley Cat PR Mk XI conversion has several different boxings - different decals in each. Alley Cat don't list the conversions on the site list - but a Google came up with this sub-level page for the USAAF version - so possibly not currently in production. Hannants have the 'Captured', Danish and Norwegian boxings. Just dug out both of my 9's from the loft and found some Barracuda stuff that I'd forgotten about - so adding their 'Starboard Cockpit Sidewall', 'Spitfire Cockpit Upgrade Pt II' and the four spoke wheels. Also have two sets of the 'ROLLS-ROYCE' logo'd rocker covers - but don't think these are applicable to wartime engines? Want to do full engine bay on this one. I *may* do a Mk IXc in parallel... Iain MikeC and geedubelyer 2 Link to comment Share on other sites More sharing options...
Iain Posted January 3, 2016 Author Share Posted January 3, 2016 OK - as per other thread I'm now in with a Mk IXc as well - wading into both this evening. Progress pix soon - promise! Iain Link to comment Share on other sites More sharing options...
MikeC Posted January 4, 2016 Share Posted January 4, 2016 ... Also have two sets of the 'ROLLS-ROYCE' logo'd rocker covers - but don't think these are applicable to wartime engines? Want to do full engine bay on this one. ... My understanding was that the logo appeared on RR Merlins and not on Packard Merlins, but that may be my memory at fault. I'll do a bit of searching and come back if I find anything. If anyone else knows the answer do please say! Link to comment Share on other sites More sharing options...
DonH Posted January 4, 2016 Share Posted January 4, 2016 I have a copy of a wartime Merlin 60 engine manual. It shows the logos on the rocker covers, so I think they are appropriate for your build. I know the PRXI didn't use a Merlin 60, but I think it is safe to say that RR put the logos on during the war. MikeC 1 Link to comment Share on other sites More sharing options...
Iain Posted January 4, 2016 Author Share Posted January 4, 2016 Thanks both! Work has started... Iain MikeC 1 Link to comment Share on other sites More sharing options...
Phartycr0c Posted January 5, 2016 Share Posted January 5, 2016 Stick the logo covers on....its your build m8. Look forward to seeing this at..........Cosford? Link to comment Share on other sites More sharing options...
Iain Posted January 5, 2016 Author Share Posted January 5, 2016 We'll see - I should have at least a new Me163 and Mirage IIIC... Fuselage on the PR bird started - with the resin retractable tail wheel parts fitted (these are copies of the Tamiya Mk VIII parts) and fitted well. I've been sidetracked fighting the Mirage which has to get finished - and is proving to be hard work at the mo. Iain monthebiff 1 Link to comment Share on other sites More sharing options...
Iain Posted January 10, 2016 Author Share Posted January 10, 2016 OK - after a delay on other things I bring you some progress on the PR Mk XI... Tail sections to accommodate retractable tail wheel fitted. These are direct copies of the parts Tamiya supply in the Mk VIII kit and, after a little clean-up and trial fitting they fit pretty well. You can just make out a moulding flaw that will be sorted later in the build. Port side opening for camer has been opened up - using the Alley Cat etched template as a guide. Once I was happy with position the hole was marked up, before opening out with a 10A scalpel blade, followed by large round file and 1200 grit wet and dry. On the Mk XI there is an additional access hatch on the starboard side. An etched template is provided and once this was lined-up and taped in place I went around the shape with a scriber. Prepped fuselage halves: Wasn't looking forward to the camera ports in the belly - but once again Alley Cat to the rescue with etched templates that make positioning easy - as long as you take a little time. These were, once again, opened out with a scalpel blade followed by file and wet and dry. OK - so now we're at a stage where I can make a start on the cockpits for this and the parallel Mk IXc. Have fun! Iain geedubelyer and SciFi58 2 Link to comment Share on other sites More sharing options...
Guest Posted January 10, 2016 Share Posted January 10, 2016 Way to go Iain. Watching with interest....Harv Link to comment Share on other sites More sharing options...
dennismcc Posted January 10, 2016 Share Posted January 10, 2016 Looks like your stretched a bit thin Iain, nice work though. Cheers Dennis Link to comment Share on other sites More sharing options...
geedubelyer Posted January 10, 2016 Share Posted January 10, 2016 Neat job on the camera windows Iain. Does the Alleycat conversion provide the cameras or do you need to scratch build them? Cheers. (BTW, very nice blue Spit Andy.) Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 12, 2016 Share Posted January 12, 2016 Neat job on the camera windows Iain. Does the Alleycat conversion provide the cameras or do you need to scratch build them? Cheers. (BTW, very nice blue Spit Andy.) There are no cameras provided in the conversion set. The are several very thick clear resin ports and bezels. If you use the ports as is,I don't think you would be able to see any cameras inside. Here's a couple pics of my build to give you an idea. Carl Iain, geedubelyer and MikeC 3 Link to comment Share on other sites More sharing options...
Phartycr0c Posted January 12, 2016 Share Posted January 12, 2016 Good work thus far Iain . Keep it up Link to comment Share on other sites More sharing options...
