Zero77 Posted January 6, 2016 Share Posted January 6, 2016 (edited) THat's just outstanding.... A real lesson about weathering and decaying, material by material. Even the small brass plate is oxyded with green copper oxyde, i love this kind of details ! Edited January 6, 2016 by Zero77 TonyT 1 Link to comment Share on other sites More sharing options...
tucohoward Posted January 6, 2016 Share Posted January 6, 2016 Tony, that is brilliant!!! Love it. Jay TonyT 1 Link to comment Share on other sites More sharing options...
TonyT Posted January 6, 2016 Author Share Posted January 6, 2016 (edited) Thanks guys, I'm blown away by all the kind comments, to be honest they have taken me back a bit, rusting is easier to do than a normal paint schemes, you just have to be brave and plow in, unlike a normal camouflaged finish there are no rules, and no set pattern to the corrosion, it's a simple case of applying it and seeing how it works and in that context you are free to experiment. A normal paint scheme is harder to apply and weather as it is the norm and can be difficult to apply well, that and the viewers have a preconceived conception on how it should look, rust in comparison is easy, you just need to work at it, and follow basic rules, metal tends to corrode from certain points, moisture traps, fastener areas, points of high wear and edges etc, the rest follows suit. When this is done I intend to try and do a little guide on how I do my corrosion and believe me it is easy, I can do the basic corrosion on some of the panels in minutes, though to be honest I do go back and tweak it a bit, the most successful part in my opinion ( which I personally like ) is the corrosion on the brass / copper plate, and I will try to add that to the guide..... Edited January 6, 2016 by TonyT LSP_Ron and Iain 2 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted January 7, 2016 Share Posted January 7, 2016 (edited) This build, and the quality of the original kit could almost make me want to have a go at a tank, and it would be the Renault ... However, I am sure I could never match your talent. Hubert Edited January 10, 2016 by MostlyRacers Link to comment Share on other sites More sharing options...
karimb Posted January 10, 2016 Share Posted January 10, 2016 Fantastic,,! Looking forward to the guide to rusting lol Link to comment Share on other sites More sharing options...
TonyT Posted January 13, 2016 Author Share Posted January 13, 2016 (edited) My apologies for the delay, work has got in the way so progress has slowed, I will try to get both the guide and the model done.. . Edited January 13, 2016 by TonyT Link to comment Share on other sites More sharing options...
DrDave Posted March 6, 2016 Share Posted March 6, 2016 Great stuff mate Link to comment Share on other sites More sharing options...
TonyT Posted March 6, 2016 Author Share Posted March 6, 2016 (edited) I need to get on with this, I just have a lot on at the moment, thanks for the comments Edited March 6, 2016 by TonyT Link to comment Share on other sites More sharing options...
TonyT Posted June 28, 2016 Author Share Posted June 28, 2016 Well I have started again, base is started and racks have been dumped inside the tank, will try to get some progress pictures done Link to comment Share on other sites More sharing options...
TonyT Posted June 30, 2016 Author Share Posted June 30, 2016 (edited) Finally got back into it Second ever attempt at doing a proper base for my 1/16 FT-17, this is about a weeks tinkering in the evenings so far, not a lot to see as I need to spend more time photographing it.Base is a picture frame packed with polystyrene sheet, coloured plaster added too that, then a couple of sand pigments added with acrylic resin, I then gathered some ground down pebbles come grit off a cinder path and using the resin painted over the top to add the stones, home made rust was added in places and some pigment and home made rust too add some detail. some resin 45 gallon drums and various bits of plastic tubes, grass etc were added along with some 1/16 bits left over from another tank.. will update as I work on it Any shiny bits are were I still need to flat coat the resin used to bond parts to the base. All hand painted BTW over an aerosol black primer coatHope you like it so far.Afghan FT-17 scrap by Tony Taylor, on FlickrAfghan Ft-17 Main by Tony Taylor, on Flickr Edited July 7, 2016 by TonyT Zero77 and Hubert Boillot 2 Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2016 Share Posted June 30, 2016 My god thats good !!........Harv Link to comment Share on other sites More sharing options...
Shawn M Posted July 1, 2016 Share Posted July 1, 2016 didn't think this could get any better, but I was wrong. TonyT 1 Link to comment Share on other sites More sharing options...
TonyT Posted July 1, 2016 Author Share Posted July 1, 2016 The pictures are a bit dark on my work monitor, I will have a play tonight if I get time on taking some more, thanks for the kind comments, Zero77 1 Link to comment Share on other sites More sharing options...
TonyT Posted July 2, 2016 Author Share Posted July 2, 2016 (edited) Ok try this, see if it shows better to you guys, as said still work in progress Ft-17 Afghanistan Rear by Tony Taylor, on Flickr Edited July 2, 2016 by TonyT Shawn M and Zero77 2 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted July 2, 2016 Share Posted July 2, 2016 Still dark with the black background. Absolutely gorgeous nevertheless Tony Hubert TonyT and Zero77 2 Link to comment Share on other sites More sharing options...
