karimb
LSP_Members
  • Posts
    2,517
  • Joined
  • Last visited
  • Days Won
    33
Everything posted by karimb
  1. Superb weathering and finish Jarda! really love what youve done with the cockpit and the paint patina!
  2. Fantastic work Jaro! Thanks for giving me the privilege of following the build step by step!
  3. Grateful for your kind wishes! Though I've been less active on LSP lately, I'm still around on facebook now and then. I'll aim to stop by here more frequently to say hello! Thanks for your warm wishes again, made my day! Karim
  4. Excellent build on a cool subject bro! Will have to find some sort of solution to the decals on my build!
  5. Definitely would help out organizing my bench space and to be honest the prices are very affordable for what’s on offer, in comparison to some of the stuff i see online (i think there was a post in general section regarding a competitor product). Makes more sense purchasing from the LSP member family when they produce a similar product than putting my cash out in the market. Seiran maybe you should also link your post to the general section! Karim
  6. Chuck thank you very much for the kind comments and thank you for checking in on the post!
  7. Petr thank you very much !
  8. thank you Tom for your kind words It’s a real pleasure to be able to share the build with all you guys on here. The wood brush painted is a technique i have been trying to work on lately its not difficult just takes a bit of practice and sorts out alot of the mess that comes with oils. I like it!
  9. thank you very much Jarda for the kind words !
  10. thank you Andy! It’s a pleasure to have you check in on the post!
  11. Thank you Brian it’s always good to have you check in on my builds and leave such kind comments! the kit is highly recommended!
  12. Thank you very much for your kind words! The kit is alot of fun just be careful with some of the attachment points or lack thereof. The top cowling and tail to cockpit assembly fit needs a bit of work but overall it is a lovely kit and well recommended. You’d be surprised how relatively small the aircraft is comparison with say an Albatros! Thanks for checking in!
  13. Haven't posted anything on LSP in a while as i have been using a different platform of late, so hello again! First go at a CSM kit and i am happy to say they are very well designed. All paints either a mix of Tamiya or simply MRP colors. Wood is all brush painted using Tamiya paints thinned with MLT and using Tamiya retarder to minimize the brush strokes. All markings custom masks. Weathering with AMMO products and pigments, pencils for some of the chipping and Abteilung oils. Turnbuckles by gaspatch and of course the tubing is all from Bob's Buckles regards, Karim
  14. +1 to what Brian said!!
  15. Dave sorry if it feel i hijacked the thread. I will probably start a new one once we get closer to starting the hph build. Sorry again K
  16. thanks @LSP_Ray! thanks @Kagemusha! the problem i meant with regards to fitting the cockpit or gearbays is i will have to cut the space out the find a way to fit the assemblies into a hollow space then have them held back against the surface. I was thinking of cutting the gear bay section out following panel lines then gluing shims on the inside of the wing area. Gluing the bays to the cut out “panel” then regluing this to the shims. I don’t know if the idea is coming across right. in the case of the cockpit if i cut out the area where the canopy is, that area isn’t wide enough for me to slip the cockpit in to glue it to the shell so i will have to find another way to get all those big components slipped into the fiberglass shell and secured in position (this example seems to be clearer). Chain drilling is absolutely fine so would be using my set of micro circular pe disc saws mated to the proxxon. This is basically the major thing that has been keeping me holding back from digging in. Kag, ill take photos of the whole carton content and post them once i am back from vaca! K
  17. pictures below. The kit looks raw in those photos but it is actually much much more refined. Some areas look like they have dents but the reality is the fiber shell is smooth as glass, the areas that look like dents is where the color dye hasn’t spread during the molding process. HPH had to delay the molding because of the heat during summer 2018 in Czech Republic. The molding is through the vertical axis of the aircraft so you are left with a protrusion that needs to be sanded out. The “kit” comes with all the resin goodies in three massive tupperware type boxes. Very nicely detailed bays, cockpit is an excellent base for superdetailing, paint masks, two vac form canopies and the stencils to make a french armée de l’air machine in two tone gray. i am ready to roll on that one once i figure out how i am going to cut the shell to insert the gear bay areas and the cockpit as the shell is a solid continuous surface, albeit hollow. In one of the photos i have placed a wingnut wings Junkers D.1 for size comparison. if this beast is built up to a high standard and you take your time on it it will turn into an epic showstopper! Karim
  18. Planned for this a year ago and went and got a custom made custom produced (#6 produced) 1/18 scale mirage 2000C from HPH which i plan to finish in HAF livery. Unfortunately kh has my choice of scheme in their decal sheet . I’ll pass on the kh offering but i hope you guys enjoy building it! K
  19. Paul thank you very much for the kind comment!
  20. Mr. M it’s always a pleasure to read you. Thanks for stopping by and leaving a word!
  21. Herr Baron. Many thanks my friend!
  22. Tom you’ve hit a chord on that one. I have been eyeing the Hannover for a while because i like complicated paint schemes. I might very well give it a go with a work in progress here
  23. thank you for your kind words!
