The base was an oil wash. On top of that I applied MiG Pigments overall the build, a little heavier on areas where foot traffic and work was done. After that, I took Windex and from a distance of 3ft, I sprayed a fine mist over the build, letting it fall in a fine mist. This settled the Pigments in a way that it looked like dirt/staining in high travel area. I use Acrylic based clearcoats, and I think the Windex also etches the clearcoat. Thanks for the warm welcome, guys!!
Don
Wow, thanks for the explanation! Very effective, and a technique I plan to try out. Well done!
I did a short tutorial on another forum for this. This shows how i weathered the bombs on my P-47 build but most applies to an overall finish.
This is a 500lb that i did for a P-47. It looks heavily weathered, but after seeing a video on Youtube on how these were handled i fell OK with it.
To start, i painted, decalled and sealed the bomb. You need to end with a dull/flat coat.
Next, i took Tamiya makeup kit A and using all three shades i smeared the bomb all over.
Take a wide brush and blend the shades together.
Next, i loaded up the bomb with MiG Pigments
Now, taking Windex and from a distance of 3-4 ft spray a fine mist upwards above the bomb so it falls in a fine mist, you don't want a direct spray or excess puddling.
What you will end up with is this. Now this is far too harsh for a bomb, would look good for rusty tanks/equippment.
Finally, taking the wide brush and some more MiG Pigments, blend the staining in.
For wing upper surfaces, i didn't blend at the end. I just relied on the fine mist and color of pigment to give the desired effect. Obviously this will take experimentation and practice. I use Acrylic clearcoats and i think the ammonia in the Windex adds to the effect by etching into the clearcoat. I don't know how this would work on enamel paints. If you coated your clear parts/canopies with Future, BE AWARE THAT THE WINDEX WILL RUIN THE FUTURE COATING!!!! . Either keep masks on or leave clears off if you try this. HTH
Don
Whoa, that is way cool! The Tony has always been what I consider to be the best looking WWII Japanese fighter. You've definitely done it justice. Love the weathering tutorial too. I'm gonna have to try that on my next build.
Cheers,
Wolf
Oh yeh bombs get dirty as they were stored outside int he bomb dump and in some cases were man handled or simply rolled out to the aircraft through the mud or whatever. Nice stuff.
Great tut, and a great looking model Don! You really dont see the Has Tonys built enough..........tiz a very cool looking plane, and a pretty decent fitting kit IMHO.
Welcome to da forums btw!
This is a kit that i would like to do again. I have another one in the stash along with some aftermarket. Hoping to get to it next year. Thanks again for the encouragement, guys.
Don
Hey Don, remember your stuff from ARC, great work!
Hello Mikester!! Still hang around ARC, but LSP seems to be a better fit with 1/32 all the time. will probably spend more time here.
Don
