Derek B Posted November 22, 2013 Share Posted November 22, 2013 Lovely work Rainer I really like the frames that you have made. I know exactly what you mean about constant refinement of shape of the airframe, which is why, like you, I attempt to get the shape as accurate as I can before I start anything. However, as we both know too well, hardly any drawing in existence shows truly accurate cross sections, so we have no option but to correct and develop as we go along. Where you lead, I shall follow (unless it is a cliff edge of course)... Derek Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted November 22, 2013 Author Share Posted November 22, 2013 great work nice to see some progress. keep going. Mark Thanksa lot Mark. I'll try to keep going, well, ya know how it is... I love the amount of effort you are putting into this and I really hope you will reach the finish line with this. Did I tell you that I really like it when non-Swedes are into Swedish aircraft? I wish you all the best. /Stoffe Hi Stoffe, well, I always had a sweet spot for the Viggen. It was one of those aircraft of my youth I always liked for whatever reason... Lovely work Rainer I really like the frames that you have made. I know exactly what you mean about constant refinement of shape of the airframe, which is why, like you, I attempt to get the shape as accurate as I can before I start anything. However, as we both know too well, hardly any drawing in existence shows truly accurate cross sections, so we have no option but to correct and develop as we go along. Where you lead, I shall follow (unless it is a cliff edge of course)... Derek Thanks for your kind words, Derek. Not sure though, that I can lead here... I'm afraid, that I desperately need more information on this bird. So far quite a bit of what I'm doing is guess work... Cheers Rainer Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 22, 2013 Share Posted November 22, 2013 Excellent work Rainer! Most impressive. Your ability to visualise, and then map out what you're doing is awesome. Kev Derek B 1 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted November 29, 2013 Author Share Posted November 29, 2013 (edited) Excellent work Rainer! Most impressive. Your ability to visualise, and then map out what you're doing is awesome. Kev Thanks, Kev. I used to be an aerospace engineer in my former life, so it seems that at least some of my abilities are still tugged away somewhere in my old brain... I managed to do some work on the fuselage section. Here is what I have so far: This is the port side of the fuselage center section (the engine compartment). If you think it's a bit rough then that's because, ah... it's a bit rough. I'm not putting much effort in the structure (in terms of beauty) as nothing will be seen anyway once the skin panels are in place... But it is sturdy! Well, the best laid plans... yada yada yada. It turned out that some of the frames, to be honest, most actually, had to be modified to result in smooth transitions between them. You may or may not have noticed, that I have not yet taken care of the main u/c bay which will take up about three quarters of the lower part of this fuselage section. I first want to get the overall shape as correct as possible before I tackle the gear bay. However, that will require some serious surgery... The base plate on which the frames are mounted, has been pre-cut so I can break out the center part (with the red letters on it) to make room for the engine. But that will have to wait until the skin panels are on and sanded into shape and the starboard side of this section is in the same state of construction. Thanks for looking Rainer Edited November 29, 2013 by Rainer Hoffmann Doctorgaz, Azgaron, Christoffer Lindelav and 5 others 8 Link to comment Share on other sites More sharing options...
Derek B Posted November 29, 2013 Share Posted November 29, 2013 Great work Rainer. I am doing something similar with the Gripen - concentrate on getting the external shape correct first then cut it up and detail the insides. Derek Link to comment Share on other sites More sharing options...
Azgaron Posted November 30, 2013 Share Posted November 30, 2013 Looking very good Rainer! HÃ¥kan Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 30, 2013 Share Posted November 30, 2013 That looks amazing Rainer! So much work, but your results are so effective. Kev Link to comment Share on other sites More sharing options...
Ripaman Posted December 1, 2013 Share Posted December 1, 2013 This is very impressive workmanship Rainer , will be following your progress and will be taking notes. Regards Richard Link to comment Share on other sites More sharing options...
Loic Posted December 25, 2013 Share Posted December 25, 2013 Impressive stuff !! Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted December 28, 2013 Author Share Posted December 28, 2013 (edited) Hi fellow modellers, I hope you all had a merry Christmas with lots of turkey (allways remember: you don't gain weight between Christmas and New Year but between New Year and Christmas!) and even more styrene or resin under the tree (me, I got 2 square meters of styrene sheet and a nice selection of Evergreen rod, tubes and channels ) Derek, Hakan, Kev, Richard, Loic, Maru: Thank you very much for your kind comments and for your interest in this project. It's been a while since the last update but I didn't want to bother you with more frames and stringers. It gets a bit boring... But I did make some progress and here is where I am at the moment. Here is the aft section that will house the afterburner can. Next is the fwd mid section, the intake section: And here two views of the cockpit section: The hatched areas (cockpit tub and NLG well) have been pre-cut and some gentle persuasion with a knife should be enough to remove them once the skin panels are glued in place. Here is the complete structure of the port fuselage half: And just to show you how big that bird actually is I've included my clumsy hand in the next pic: I had to modify about half of the frames (as compared to my original drawings) to get the transitions between them as smoth as possible and to match the pictures I have. A kingdom for correct cross section drawings! But I think that I've captured the general shape of the Viggen reasonably well if not entirely correct. As long as it looks like a Viggen I'll be happy enough. Next is the intake. I've not yet made up my mind how to do it. Those suckers suck (pun intended)! Once I've found a solution for the intakes I'll just have to muster all the mojo I can to do it all over again for the starboard side of the fuselage . How I wish to do some details. That is so much more fun than frames and stringers... Thanks for looking Rainer Edited December 28, 2013 by Rainer Hoffmann Doctorgaz, Ripaman, Azgaron and 3 others 6 Link to comment Share on other sites More sharing options...
Christoffer Lindelav Posted December 28, 2013 Share Posted December 28, 2013 You certainly have been busy! I love this stuff, guess it´s gonna be hard to get the other fuse half symmetrical? Just keep it up, I will be watching. /Stoffe Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted December 28, 2013 Author Share Posted December 28, 2013 guess it´s gonna be hard to get the other fuse half symmetrical? /Stoffe Hi Stoffe, yes, that's a bit of a challenge. But I did all the frames for the starboard side already and took care, that they are symmetrical. And I took careful notes of the necessary modifications. So I'm confident, that both halves will be reasonably symmetrical. Cheers Rainer Link to comment Share on other sites More sharing options...
dodgem37 Posted December 28, 2013 Share Posted December 28, 2013 And it fits together, at that! Love what you're doing. Very fine work. Sincerely, Mark Link to comment Share on other sites More sharing options...
wunwinglow Posted December 28, 2013 Share Posted December 28, 2013 Phwooaaarrr!! Tim Link to comment Share on other sites More sharing options...
Derek B Posted December 28, 2013 Share Posted December 28, 2013 Fantastic Rainer It is only now that you can truly appreciate the shape and fruition of your hard work now that you have something physically tangible in your hands. Great work. Derek Link to comment Share on other sites More sharing options...
