dutik Posted February 24, 2014 Share Posted February 24, 2014 Part 3: - dutik Link to comment Share on other sites More sharing options...
dutik Posted February 24, 2014 Share Posted February 24, 2014 Part 4: - dutik Azgaron 1 Link to comment Share on other sites More sharing options...
dutik Posted February 24, 2014 Share Posted February 24, 2014 (edited) Part 5: - dutik Edited February 24, 2014 by dutik Azgaron 1 Link to comment Share on other sites More sharing options...
dutik Posted February 24, 2014 Share Posted February 24, 2014 Part 4 could be a recce Lansen, not a Viggen. Took the images just while walking around the displays, with no particular order. - dutik Link to comment Share on other sites More sharing options...
dutik Posted February 24, 2014 Share Posted February 24, 2014 Part 6: Thats it! - dutik Rainer Hoffmann and Derek B 2 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted February 24, 2014 Author Share Posted February 24, 2014 (edited) Hallo dutik, super, danke für die Fotos. Alles hilft!! Thanks for those pics, dutik. It's very much appreciated. Great pictures of the RAT!. As far as I know the RAT was always extended during take off, landing, taxiing and probably while the aircraft was parked, The last picture is most certainly a Draken, judging by the intakes. Cheers Rainer Edited February 24, 2014 by Rainer Hoffmann Link to comment Share on other sites More sharing options...
dutik Posted February 24, 2014 Share Posted February 24, 2014 Its a pleasure. Yes, it is a Draken. These are old images recovered from a back-up, without names and descriptions. Anything that was at the exhibition of the recce unit, and any type of airplane. I have also some Spitfire images therefrom. So please check your references carefully for what is what to avoid the non-Viggen detail images lurking in between. Regards - dutik Derek B and Rainer Hoffmann 2 Link to comment Share on other sites More sharing options...
Derek B Posted February 28, 2014 Share Posted February 28, 2014 Hallo dutik, super, danke für die Fotos. Alles hilft!! Thanks for those pics, dutik. It's very much appreciated. Great pictures of the RAT!. As far as I know the RAT was always extended during take off, landing, taxiing and probably while the aircraft was parked, The last picture is most certainly a Draken, judging by the intakes. Cheers Rainer Seconded from me also dutik; superb photographs and invaluable to me as well as Rainer - Thank you. Derek Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 28, 2014 Share Posted February 28, 2014 If any of you guys care to bundle these photos up and send them to me, I can publish them as a Walkaround on the website. Kev Rainer Hoffmann and Derek B 2 Link to comment Share on other sites More sharing options...
Fabster Posted March 1, 2014 Share Posted March 1, 2014 Wow! One heck of a detailed walkaround! This Viggen project is going to get even better! Thanks for sharing both with the forum. Fab Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted March 2, 2014 Author Share Posted March 2, 2014 If any of you guys care to bundle these photos up and send them to me, I can publish them as a Walkaround on the website. Kev Hi Kev, since these are dutik's photos I think it would be best if he would do that himself, right? Cheers Rainer Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 2, 2014 Share Posted March 2, 2014 Hi Kev, since these are dutik's photos I think it would be best if he would do that himself, right? Cheers Rainer Yes, true! Dutik? Kev Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) G'day fellow modellers, I was able to do some more work on the intakes. With all the new information thanks to dutik, Derek, Hubert and Lars I will have to modify the intakes a bit: But it is nothing too serious as my first assumptions were not too far off. I have covered the cardboard structure of the port intake with styrene strips, filled the gaps with liquid styrene and roughly sanded it into shape. I also started to cover the starboard intake with styrene strips: I have roughly sketched in the position of the fuselage frames. The material of the intakes is just 1 mm thick. After I'll have cut them lengthwise into two halves the parts will be all but impossible to properly align. So I will beef up the areas between the frames to about 3 mm. That will allow me to insert small styrene tubes perpendicular to and across the line where I will cut the intakes apart. These then will serve as holes for locating pins. If this is unintelligible then please wait for the next update. It will become clear what the basic idea is. Thanks for looking Rainer Edit: It's march already, so it's clear that I won't make it to the finish line of this GB. Well, I never expected to make it. But the GB provided the incentive I needed to get me going. Thanks again for your continued interest and your support. Edited March 2, 2014 by Rainer Hoffmann Ripaman, Lee White, Derek B and 2 others 5 Link to comment Share on other sites More sharing options...
Ripaman Posted March 3, 2014 Share Posted March 3, 2014 Does look very good Rainer, I see why you are doing this because as you said you are going to foil the inside, right. Also dont think I will finish before the dead line, no worries eh. Regards Richard Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted March 3, 2014 Author Share Posted March 3, 2014 Does look very good Rainer, I see why you are doing this because as you said you are going to foil the inside, right. Also dont think I will finish before the dead line, no worries eh. Regards Richard Hi Richard, yes, I will foil the insides of the intakes. At least I'll try to do that... Cheers Rainer Link to comment Share on other sites More sharing options...
