By the way. What did you use for you metallics? They look great!
We're they brush painted or airbrushed?
Hey Chuck, the metallic paint colours came from various sources such as Alclad II and Citadel acrylics. Mostly they were sprayed on but the Citadel paints brush beautifully as long as you keep them well thinned with Tamiya's thinner.
HTH,
Cheers,
Wolf
I just love your paint jobs. Incredible!
Thank-you Sir, there's definitely a lot of paintwork involved in these WnW kits. ;)
Cheers,
Wolf
WOW! I'm blown away by your work. Great job on the interior.Rich
Thanks Rich, it's really hard to beat these WnW kits. You've got to give them a go.
Cheers,
Wolf
WOW.......... superb work sir. I'm impressed! I'll have to try your wash formula.
Will
Thank-you Will, the detailer washes are fool proof in my experience. Just remember to add a little dish washing liquid to help break down the surface tension and it also makes removing the excess wash easier. Thin the stuff with distilled water as well. For some reason the distilled water works better than plain tap water.
Cheers,
Wolf
Edited by Wolf Buddee
Thanks Wolfe. The metallics (well lets be honest here, all of it really) looks great as usual.
How's the spitfire coming along? Waiting for more reference materials?
Hi Chuck, the Spitfire is laying in wait at the moment. I just couldn't resist starting on the Fokker. As far as reference material is concerned, I've finally managed to accumulate everything I need to finish the Spitfire.
Cheers,
Wolf
Sounds good Wolfe. Looking forward to another spit fix once you get back at her.
Keep up the great work, Chuck.
Home sick again today, :( pumped up with medications, and just enough energy to get a low watt LED to glow faintly I decided to drag myself to the bench to do some more work on this build. Over the last few evenings I've managed to get the cockpit module all completed. The bracing wires are EZ Line and the turnbuckles from GasPatch. These are truly remarkable items, accurate in shape, easy to use, accept paint readily, and very affordable. Hard to beat all that eh?
The engine bearer assembly is also complete and with constant dry fitting of the various cowl panels, radiator, and engine block, everything lines up perfectly. The prop shaft protrudes directly through the centre of the front lower cowl as it's supposed to. :thumbsup: . Way to go WnWs!
If I can drum up the gumption I'll continue working on the engine today which should be a lot of fun as I have a bunch of Taurus Models details to add to it. Spark plugs, rocker boxes and rocker arms, valve spring assemblies, and of course, intake manifold locking rings. Very nice stuff indeed! I'm not planning on going hog wild with the engine on this one as only the top will show with the cowls in place and I'm not spending the next two years searching for enough reference material to put almost everything on :doh:.
Thanks for looking in and as always, comments and critique welcome!
Cheers,
Wolf
Looks fantastic Wolf! Your work is some of the cleanest and sharpest I've ever seen. Most impressive!
Kev
Thanks Kevin, sheeesh you guys are fast! I'm still typing and editing while you're already responding. Kind words indeed Kevin!
A question though and you might not have an answer for me but I've been having some difficulty posting. When I tried to post my first WIP on this build I wound up having my post badly broken up and only one of my pics posted. The rest of the pics were surrounded with some garbled computer language and it took about 5 edited posts to get everything up. Today the Pics posted perfectly but half the text was gone, broken up mid sentence too! Weird! Any idea what I might be doing wrong? :shrug:
Cheers,
Wolf
No idea on that one I'm afraid. The forums seem to a be a little unresponsive of late, so I can only imagine that this is affecting post submission on occasion. Perhaps if it happens again, leave the broken post as is and send me a PM so I can take a look. You can always just start another new post so you can keep going.
Kev
