419 -
Days Won
2
Everything posted by aircare84
Red Fox Studios make a set for the Me-262 B; Red Fox Studio (rfstudio.hu)
Impressive John! The finish & wash are just first class. Your attention to detail is what sets you above mere mortals such as myself. Larry
Wow! What an impressive build. Thanks for posting.
AIMS 1/32 Bf 110 G-2/R1 conversion for Dragon/Revell C-7 kit
aircare84 replied to Pastor John's topic in Vendors Board
Does this come with a resin clear canopy and a vac canopy? -
Mike, Thanks for the tips. Will keep in mind when I get to my build. I also remember one build where he used Uschi plank strips. It turned out well also. Many more pieces to cut & apply, but may eliminate the issues using the large 1 piece decals. Larry
Thanks Mike. I do have the Proper Plane decals. Will be aware of the issues you mentioned. Any trouble cutting or applying the 'saw tooth' strips? They also looked like might be a chore. Yours turned out great. Already downloaded your PDF as well. Don't know when I'll get to one of the Roland's, in the middle of a WNW LVG build at this time. Larry
Great build Mike! Been watching this one. Have the same Roland decals, hope mine turns out half this nice. Larry
1/32 Special Hobby Hawker Tempest V - Fairbanks JJ+F
aircare84 replied to Thunnus's topic in Works in Progress
John, That was the issue I had mentioned about getting the engine to fit Barracuda's nose. Have to reduce the diameter of the front engine 'frame' ring & radiator to fit the smaller nose. I don't think a bothered to add the raised rivets afterwards. Larry -
John, Here's 1 in the US: 1/32 P47D Engine for HSG 8110789006710 8110789006710 | eBay
RB Productions are supposedly just on a temporarily hold due to COVID. Was indicated they will be able to ship after the crisis. Hope so, as I am wanting their TA-152 etch set. Am aware Radu has sold the business. Like their belts as well, just installed a set in a WNW LVG I'm working on. Wolf, if you get in a pinch, let me know, as I have a few WW2 Luftwaffe sets tucked away.
Looking forward to you build John. It is a great kit & I'm sure you will turn out another stunner as usual. I used the Barracuda nose on mine with the half engine in the Hi-tech kit, as Chuck had linked to. I had to do alot of fitting, sanding, grinding to get it all together. Also, the oil or coolant tank (?) on the front of the engine casting will be wider than the Barracuda nose & will need sanded down to match the new nose. I was happy with the grafting & believe it was worth the extra effort. Other areas I had issues with, was the cockpit was too wide, would spread the fuse out, causing negative dihedral & also caused fit issues with the LG wells. Landing gear wells were a PITA to assemble & fit correctly & the wing inserts fit poorly. Hope it helps you on your build. Larry -
1/32 Revell Me262B-1/U-1 Nachtjager Red 10
aircare84 replied to Thunnus's topic in Ready for Inspection
Excellent as usual John. The details you put into a build are amazing. Your paint, finish & weathering are second to none. Thanks for posting & looking forward to your next one. Larry -
Here is my Revell 1/32 Me-262 A1a in the markings of Heinz Bar's Rote 13, III/EJG 2 in 3/1945. This is a great kit, builds up nice. Overall detail & fit are excellent. Highly recommend the kit. The only issues I had was the fit of the optional opened panels, engine & gun bays, which I modeled as closed. Used the following aftermarket; Eduard 'Look' instrument panel, Quickboost Revi 16 gunsight, Eagle editions decals for the '13' & S/N, HGW stencils & some photo etch seat belt buckles. Added the following; Wiring, piping , hoses & brake lines to the landing gear & bays; seat belts from lead foil; wiring to the back of instrument panel, levers & other misc. details to the cockpit; replaced the plastic antennas with wire & aluminum strip; plastic pitot tube replaced with tubing; added details inside the canopy; added reflectors to the gunsight & added the antenna. Painted with Xtracolor enamels, weathered with pastels & a silver pencil. Weathering was kept light. Thanks for looking & all comments welcome.
Getting ready to start revell early mustang any tips?
aircare84 replied to dashotgun's topic in LSP Discussion
I made a mix up starting on the Eagle Editions suggested mix. Don't remember exactly, just remember it included Model Master Chrysler Engine Blue & maybe Model Master Blue Angles blue (enamels)??? Thought it was too dark, so I adjusted the mix. -
Great kit! Builds up nice. Couple of issues I had & will need attention; Fit of the wing guns insert, fit of the windshield piece & I replaced the canopy with one from the Tamiya kit due to distortion. Other than that, no issues. -
You can usually buy separate sprues at ebay.
1:32 Heinkel 111 P-1 An Oldie but a Goodie!
aircare84 replied to CraigH's topic in Ready for Inspection
Great build! Thanks for posting. -
I am currently building the Revell single seater. I closed the gun bays & engines. It did take some work to get a good fit on both if you close up. Great kit though. The details are well done, shape appears to have no issues. Besides the closed panel fit issues, it builds up very well. I am not going to rivet mine, but I did go over the panel lines with my scriber, as they are a little 'soft'. Also, my windshield has some serious distortion, similar to their P-51 canopy issues. Luckily I have a two seater in the stash, windshield sprue is the same. It was fine & I'm using it. Contacted Revell.de & they will send a replacement. I have some in progress photos on 1/32 scale aircraft on Facebook. I also have the Trumpeter in the stash & believe they both have their pluses, but can't comment on how it build up yet.
Here, WW1aircraftmodels & lately FB. Only posting on FB since covid, primarily to keep up with our local IPMS club. Can't visit there in person, so gives me my local modeling fix.
Very Nice!
A6M5c Model 52 Hei Takeo Tanimizu 1/32 Hasegawa
aircare84 replied to Miloslav1956's topic in Ready for Inspection
Outstanding as usual Miloslav! Thanks for posting. You always give us a standard to strive for. -
Outstanding! Love it.
Well done. Thanks for the comments about the decals, will keep in mind as I have 1 in the stash. Thanks for posting.
- 36 replies
