Chris Wimmer Posted December 30, 2016 Share Posted December 30, 2016 Hi Everybody! Having been nothing but a lurker during the past months, so I think it's time to return with a new entry. Jurassic Plastic- what a great idea to me as I looove old kits! Decided to lay my hands on the lovely Airfix Emil that I have in mind for quite a long time. By the way, I will do an E-3 with the rounded canopy, which fortunately comes with the kit. Before purchasing I desperately searched the web for comparison pics to get an idea of its actual size. Couldn't find any, so I did some for the community: I started with the engine, which is molded onto the ammo boxes. I like the detailing level, but on the other hand this kind of mold is a no-go nowadays and especially in this scale. I seperated the engine from the firewall and removed all the wiring. So this should be my base for detailing work, later, when the fuselage is completed. Unfortunately the cylinder banks are bare of any engine outlet. The exhaust stacks not connecting to the engine block, to me, is the only remarkable issue with this nice and well detailed kit. The exhaust stacks from inside and outside. The good thing is they should be easy to remove. So this is the view with the engine in place. A resin exhaust set would be a real benefit to this kit! Thanks for looking in! Chris mgbooyv8, Derek B, Wurzacher and 5 others 8 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted December 30, 2016 Author Share Posted December 30, 2016 The E-4 canopy. No problem here: Not so with the early version. There's a disturbing line crossing the lower windows, which is caused by a step in the mold. So a reasonable amount of TLC will be needed here... Chris mgbooyv8, BradG, Wurzacher and 3 others 6 Link to comment Share on other sites More sharing options...
dodgem37 Posted December 30, 2016 Share Posted December 30, 2016 Welcome back, Chris. Did you change your Avatar? Sincerely, Mark Chris Wimmer 1 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted December 30, 2016 Author Share Posted December 30, 2016 Welcome back, Chris. Did you change your Avatar? Sincerely, Mark Yes Mark, you're right. I did when the Munich Oktoberfest was taking place. Hmm, think this is over now... cheers Chris Link to comment Share on other sites More sharing options...
Sparzanza Posted December 30, 2016 Share Posted December 30, 2016 I love this kit. I had the same problem with the canopy for my 1/24 P-51 by Airfix... had to send both pieces off to Boris for some polishing. Chris Wimmer 1 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted December 30, 2016 Author Share Posted December 30, 2016 I love this kit. I had the same problem with the canopy for my 1/24 P-51 by Airfix... had to send both pieces off to Boris for some polishing. Wow, that's a cool idea! You did a very good job on your Mustang, also like your Emil, very inspiring! cheers Chris Link to comment Share on other sites More sharing options...
mgbooyv8 Posted December 30, 2016 Share Posted December 30, 2016 Me too! Cheers, Peter Chris Wimmer 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 30, 2016 Share Posted December 30, 2016 Great choice, Chris! I'll be following. Kev Chris Wimmer 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted December 31, 2016 Share Posted December 31, 2016 Great choice, great start! I like this kit a lot, it is an excellent model for its age! I actually like the rivet detail as it can be sanded down very gently and looks good under a coat of paint. I will be following with interest. Alain Chris Wimmer 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted December 31, 2016 Share Posted December 31, 2016 I like it! Chris Wimmer 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted December 31, 2016 Share Posted December 31, 2016 Great choice! I've never seen the kit parts, but I've heard it's quite accurate in shape. Certainly going to follow this one. Chris Wimmer 1 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted January 1, 2017 Author Share Posted January 1, 2017 Thank you for the kind words and of course: Happy New Year Everybody! Ouch, I had a quite long night and may be not entirely sober at the moment, however... When I said this is a well detailed kit I meant it is well detailed for its age. In my opinion all important parts are present and can be used as they are or modified at taste. The starboard sidewall. I cut it into pieces and used all parts except the crank for the wing radiator flaps. A first "cockpit-testshot". I received the kit about three weeks ago and started immediately and very enhusiastic: Breathing apparatus and rudder pedals, both with minor modifications and still unfinished: My first effort with the cockpit, almost OOB: Port sidewall in the works: Made the lever-ball from UV hardening glue: The re-worked cockpit section. I didn't share this build from the start because I'm still not very confident with my paintjobs, which are nothing but crapshoot most of the time Here's one interesting pic from the munich museum's 109: It shows the headset connector (wrong word for sure) and the chain tensioner below. This aircraft with serial 790 is on display as an E-3 version, but was initially delivered as an E-1 in 1939. Don't get confused by the colors, the entire cockpit was fantasy-painted for display purposes many years ago: So this is my future-glossy cockpit as it looks today, not glued yet. I think placard decals would look nice. Thanks for looking in Chris Sparzanza, Shaka HI, Hubert Boillot and 8 others 11 Link to comment Share on other sites More sharing options...
Shaka HI Posted January 2, 2017 Share Posted January 2, 2017 Wow..Just Fantastic! Awesome detail! Chris Wimmer 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted January 2, 2017 Share Posted January 2, 2017 Excellent work! I am saving these build photos as reference! Thanks! Alain Chris Wimmer 1 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted January 2, 2017 Author Share Posted January 2, 2017 Thank you, Shaka HI and Alan! Wow, saving as reference, I really feel honoured... Today I tried to make some placards on my PC, just to see what I can do in 1:24 scale. Port sidewall: the upper one is printed on white decal sheet. The lower one is printed on clear decal sheet, applied to a piece of kitchen aluminium foil and then applied to the model with a drop of clear laquer: Starboard sidewall is still in the works. Only added my decal to the switchbox today: Thanks for looking in Chris Derek B, r0t0rdr1ver, Shaka HI and 4 others 7 Link to comment Share on other sites More sharing options...
