tomprobert Posted October 5, 2015 Author Share Posted October 5, 2015 Really fantastic result, Tom! I'd love to publish it on the website if you'd permit me. What's next, by the way? Kev Thanks, Kev and yes no problem! Next up is a 1/24th Spey powered F-4M! TaffyMan 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 5, 2015 Share Posted October 5, 2015 Next up is a 1/24th Spey powered F-4M! Scratch-built? Kev Link to comment Share on other sites More sharing options...
tomprobert Posted October 5, 2015 Author Share Posted October 5, 2015 Scratch-built? Kev As good as. I'll be using the Combat Models vac as a base, but needless to say it'll need a whole lot of work. The base kit is a GE powered F-4E so I'm going to have my work cut out. I'm just waiting for it to arrive from the U.S. and then I'll start a thread. Girlscanplay2 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 5, 2015 Share Posted October 5, 2015 I'm just waiting for it to arrive from the U.S. and then I'll start a thread. Now that will be worth watching! Kev Link to comment Share on other sites More sharing options...
Fredouille Posted October 5, 2015 Share Posted October 5, 2015 Wow! What a big beautiful beast ! Incredible job. I love this bomber. Fred Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted October 5, 2015 Share Posted October 5, 2015 Hi Tom- Awesome! Love it! ...Looks like you added the forward nose section halves to each fuselage half before you closed both fuselage sides. Was thinking the same for my build, as my dry fit following the kit instruction sequence created a huge step between the forward section and the rest of the fuselage. Looks like you licked that problem..am I correct, or did you go down a different path? Cheers Pete Link to comment Share on other sites More sharing options...
Rod Bettencourt Posted October 5, 2015 Share Posted October 5, 2015 Too cool! thanks for posting these pics. Rod Link to comment Share on other sites More sharing options...
tomprobert Posted October 5, 2015 Author Share Posted October 5, 2015 Many thanks for the kind words everyone. Excellent work Tom! Great to see this one finished. Looking again at the overall model, your landing gear mod was certainly the way to go and makes a huge difference. Thanks for the motivation to keep mine going too. Cheers mate, Craig Many thanks, Craig. It's only a relatively small mod but it does make a lot of difference to the 'sit' of the model. It was just too 'stalky' to my eyes before, and now it takes on the heavy look of the real aircraft. Hi Tom- Awesome! Love it! ...Looks like you added the forward nose section halves to each fuselage half before you closed both fuselage sides. Was thinking the same for my build, as my dry fit following the kit instruction sequence created a huge step between the forward section and the rest of the fuselage. Looks like you licked that problem..am I correct, or did you go down a different path? Cheers Pete Thanks Pete, and yes the nose sections were added to the fuselage halves before joining. When I built my first one there was quite a pronounced step which took a lot of getting rid of; this way with the nose sections perfectly aligned with the cockpit area I was only left with very small gaps on the top and bottom of the fuselage at the join line which were easily filled with a small plastic shim and a lick of filler - much more effective! Tom Link to comment Share on other sites More sharing options...
RNoAF Posted October 5, 2015 Share Posted October 5, 2015 A crisp and clear build!! Love it Link to comment Share on other sites More sharing options...
Durangokid Posted October 6, 2015 Share Posted October 6, 2015 That is insane! Link to comment Share on other sites More sharing options...
Girlscanplay2 Posted October 6, 2015 Share Posted October 6, 2015 BEAUTIFUL!!! That is one pretty, and clean aircraft! Great job! Teresa Link to comment Share on other sites More sharing options...
Tony T Posted October 6, 2015 Share Posted October 6, 2015 Another stunner from Tom's aircraft depot Tony Link to comment Share on other sites More sharing options...
TaffyMan Posted October 6, 2015 Share Posted October 6, 2015 Hi Tom - Lovely job mate and can't wait to see how you get on with that next build....... should be an interesting project I'll pull up a chair for that one Taff - Link to comment Share on other sites More sharing options...
ScottsGT Posted October 7, 2015 Share Posted October 7, 2015 Well done, Sir! Link to comment Share on other sites More sharing options...
Tango1 Posted October 8, 2015 Share Posted October 8, 2015 Tom, I take my hat off to you, this build is awesome! Seriously top notch work there! Love it!! Link to comment Share on other sites More sharing options...
