frogman13 Posted June 16, 2014 Share Posted June 16, 2014 Here's my latest effort using the only 32nd MiG-17 on the market from Trumpeter. I started it back in March and worked with the base kit and some aftermarket improvements to get this result. I wish......That there will be a more modern release of a MiG-17 in the future. If not, this is going to be my last. I love the way it turned out, but modeling shouldn't need to be self abuse anymore.. :-) The model is marked as Egyptian MiG-17 #2975. This plane was photographed from a few different angles in the 1981 "Bright Star" joint Egy-Amer. maneuvers. It would have looked pretty much the same in the 1973 Yom Kippur war. The topside in-flight views of the aircraft were the deciding factor in my building this particular plane. I scratch built the Egyptian style bomb pylons and rocket rails under the wings. The bombs are 1/48 FAB-500s from "Aerobonus" (which look like the FAB-250 in 32nd scale). The rockets are 48th scale HVAR 5"in. which look alot like SAKR 3" in 32nd scale. The cockpit is from "AMS Resin", the canopy is from "Squadron". The pitot tubes and cannon barrels from "Master model", the metal landing gear from "G-Factor", the afterburner and alot of small details are photo-etch stes from "Eduard" and "Profimodeler" So i hope you like my final result and Thanks for your comments. Ed Okun/ Frogman Bill Cross, Lud13, Harold and 8 others 11 Link to comment Share on other sites More sharing options...
Martinnfb Posted June 16, 2014 Share Posted June 16, 2014 One of the nicest Mig-17 in this scale to date, Bravo! Link to comment Share on other sites More sharing options...
alain11 Posted June 16, 2014 Share Posted June 16, 2014 Hi very nice result , I like this original paint scheme . could you give us the paint ref you used Link to comment Share on other sites More sharing options...
frogman13 Posted June 16, 2014 Author Share Posted June 16, 2014 Hi Alan, Here are the paints I used: The colors used are "Testors Modelmaster" enamels as follows: Sand # FS 33531 Grun RLM 62 Black and Schokoladenbraun 50/50 mix Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2014 Share Posted June 16, 2014 I agree with Martin ! Very well done..........Harv Link to comment Share on other sites More sharing options...
Babs Posted June 16, 2014 Share Posted June 16, 2014 Very beautiful, well done. Link to comment Share on other sites More sharing options...
seiran01 Posted June 16, 2014 Share Posted June 16, 2014 absolutely gorgeous! Link to comment Share on other sites More sharing options...
alain11 Posted June 16, 2014 Share Posted June 16, 2014 Hi Alan, Here are the paints I used: The colors used are "Testors Modelmaster" enamels as follows:Sand # FS 33531 Grun RLM 62 Black and Schokoladenbraun 50/50 mix Thank you , this will be useful ....once again , great job bye Alain Link to comment Share on other sites More sharing options...
wunwinglow Posted June 16, 2014 Share Posted June 16, 2014 Very striking! Good job! Tim Link to comment Share on other sites More sharing options...
Plasticsurgeon Posted June 16, 2014 Share Posted June 16, 2014 Nice paint job! Did you use masks for it? Link to comment Share on other sites More sharing options...
frogman13 Posted June 16, 2014 Author Share Posted June 16, 2014 (edited) Hi guys, The camouflage pattern was sprayed freehand with a small exception: After I have the pattern established, I use a "0" round sable paint brush to cut the outside line of the pattern with thinned paint of that color. To blend the hand painted line, I spray again carefully up to and over that demarcation line on the edge of the pattern. Following that, I used a slightly lightened tone of the paint to shade along panels and "cloud" the color inside the pattern. I only use this technique when the pattern in very tightly sprayed on the original 1/1 subject with hard edges. This can replicate hand painted camouflage on vehicles and aircraft avoiding brush strokes and variation in paint thickness. Here is a link to the build: http://edokunscalemodelingpage.blogspot.com/ BRgds, ED Okun Edited June 16, 2014 by frogman13 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 16, 2014 Share Posted June 16, 2014 That looks great Ed! Terrific result from a not-so-terrific kit. May I publish it on the website? Kev Link to comment Share on other sites More sharing options...
frogman13 Posted June 16, 2014 Author Share Posted June 16, 2014 Hi Kev, Of course you can Best Regards, ED Link to comment Share on other sites More sharing options...
mywifehatesmodels Posted June 17, 2014 Share Posted June 17, 2014 That's a spectacular Mig 17, Ed! It looks like your patience paid off, but by looking at the pics, you would never know there was any trouble (at least, not to my eye). Great details, finish and weathering, also. John Link to comment Share on other sites More sharing options...
frogman13 Posted June 17, 2014 Author Share Posted June 17, 2014 Here are some topside views. BiggTim and Bill Cross 2 Link to comment Share on other sites More sharing options...
