I'm working on an early D9, with the 5 piece cowling. J Crandall indicates serial block 210... as having the early, 5 piece cowl, ergo...the early flat canopy/ armor/support. Got it.
 In going through my copy of
Green Hearts by Urbanke, I find profiles of serial block 210... with late bulged canopies. Retrofit?  Field mod? I found a few profiles I really liked in Green Hearts, but want to try to get it right.
Hi Mike, I'm not sure if I understood your question correctly, but very often abandoned FW 190 D-9s were photographed without a canopy.
It's possible that, when in doubt, the designer of the color profile chose to randomly place a bulged canopy.
If you're sure that the D-9s with the 210xxx serial block had a flat canopy, then leave it as it is and ignore the color profile.
This color profile is certainly wrong.
Edited by Furie
Good point. The early D9s had the 5 piece gun cowl; sources indicate within 210xxx werk number range. I was assuming flat canopy, but wonder about the exceptions. Your response certaily makes sense. I had not considered that.
Right, the bulged canopies didn't have one. The bulged canopies also had a quite noticeable bulkhead
behind the armor headrest too.
Not sure about this one ...
... looks like it could be a replacement as Thierry described. ???
According to my ref's, that is an early D9, with the 5 piece gun cowl, and early, flat sided canopy.
It would make sense that some may have been replaced in the field for various reasons.
Mike, from what I've read, the early style has the simplified armor/ support, which this has. I think canopy styles could be switched, plane to plane, but not canopy types from early to late, if that makes sense.
Thanks Kage, appreciated.
Martin, I'm thinking of a JG 26 machine. The were the first to fly the D9. A Lt. Soffing possibly.
Could use some help: trying to find info on Lt. waldemar Soffing of
I/JG 26  late '44- early '45. A profile of his D9 would be fantastic, even a description would help.
