MikeC Posted February 5, 2023 Share Posted February 5, 2023 2 minutes ago, mozart said: sadly I do plan and “think” about my models in my sleep! Doesn't everyone? mozart and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
mozart Posted February 5, 2023 Share Posted February 5, 2023 4 minutes ago, MikeC said: Doesn't everyone? So glad to hear that Mike, thought I may have needed a trick-cyclist! Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 5, 2023 Author Share Posted February 5, 2023 13 minutes ago, mozart said: Looks like it’s all going smoothly Tolga. I think I’ve read that the fuselage needs to be flatter immediately behind the cockpit rather than still a curved hump……but I could have dreamed that (sadly I do plan and “think” about my models in my sleep!) Thanks Max Yes I read the thread you mentioned somewhere. I'm going to do some work in this area without exaggerating. mozart 1 Link to comment Share on other sites More sharing options...
MikeC Posted February 5, 2023 Share Posted February 5, 2023 12 minutes ago, mozart said: So glad to hear that Mike, thought I may have needed a trick-cyclist! If you do, so do I. There's some impressive work going on here Tolga. Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 5, 2023 Author Share Posted February 5, 2023 22 minutes ago, mozart said: Looks like it’s all going smoothly Tolga. I guess Murphy doesn't know about this project yet. mozart and MikeC 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 5, 2023 Author Share Posted February 5, 2023 3 minutes ago, MikeC said: If you do, so do I. There's some impressive work going on here Tolga. Thanks Mike mozart 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 6, 2023 Author Share Posted February 6, 2023 Today's update. Some works on the fuselage dorsal area behind the cockpit . Hope that it's enough flat LSP_Kevin, denders, scvrobeson and 2 others 5 Link to comment Share on other sites More sharing options...
mozart Posted February 6, 2023 Share Posted February 6, 2023 (edited) This area behind the cockpit was often known as the "dog kennel". Brian Fawcett produced a correction set for the Revell Hurricane which included a replacement dog kennel which I have, and may use though I haven't checked how it will fit on the PCM models: Edited February 6, 2023 by mozart Tolga ULGUR, Landrotten Highlander, scvrobeson and 3 others 6 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 6, 2023 Author Share Posted February 6, 2023 1 hour ago, mozart said: This area behind the cockpit was often known as the "dog kennel". Brian Fawcett produced a correction set for the Revell Hurricane which included a replacement dog kennel which I have, and may use though I haven't checked how it will fit on the PCM models: Yes it seems that it may work with some surgery on PCM s kit. I will continue without touching this area further. I think it will not attract too much attention since the sliding canopy will be over here. mozart 1 Link to comment Share on other sites More sharing options...
dennismcc Posted February 6, 2023 Share Posted February 6, 2023 On the fabric wing PCM kit I did have to sand down the dog kennel quite a bit to get the sliding part of the canopy to fit, not just the height but the width as well. Cheers Dennis mozart and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
mozart Posted February 6, 2023 Share Posted February 6, 2023 59 minutes ago, dennismcc said: On the fabric wing PCM kit I did have to sand down the dog kennel quite a bit to get the sliding part of the canopy to fit, not just the height but the width as well. Cheers Dennis That’s good to know Dennis, I’m planning to have F/O Brooker getting into his Hurricane so the canopy needs to be open. Think I’ll need to do a few measurements to assess the fit of the Fawcett dog kennel. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 6, 2023 Share Posted February 6, 2023 Just now, mozart said: That’s good to know Dennis, I’m planning to have F/O Brooker getting into his Hurricane so the canopy needs to be open. Think I’ll need to do a few measurements to assess the fit of the Fawcett dog kennel. If you don't end up using it Max, send it my way! I've got several old Revell kits to contend with yet... Kev mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted February 6, 2023 Share Posted February 6, 2023 Funnily enough Kev, and I can’t explain why, I have two sets of the Fawcett correction set! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted February 7, 2023 Share Posted February 7, 2023 Doghouse pix ... hth Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 7, 2023 Author Share Posted February 7, 2023 I made some sand down on the dog kennel width as Dennis mentioned . You can see the test fitting of the canopy. Hope I can continue with this. It is not accurate 100% but I do not want to poke up more Thanks Dennis. dennismcc, Paul in Napier, mozart and 2 others 5 Link to comment Share on other sites More sharing options...
