Gazzas Posted October 27, 2022 Share Posted October 27, 2022 Very nice little details. Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 I am not sure if you are interested, but knowing the serial number and model of the subject you are doing I think I can determine the engine details you need (distributors, mags, wire harness, etc). Alot of great Thunderbolt models have the wrong engine stuff. Link to comment Share on other sites More sharing options...
petrov27 Posted October 27, 2022 Author Share Posted October 27, 2022 Hi Jay W - certainly - I have done some investigations but not 100 percent on what would be correct. The Barracuda-Cals instructions say that "Sleepy Jean III" is P-47D-28-RA serial number 42-28641. I had assumed the R-2800 in this would have the "turtleback" distributer/magnetos on each side so no mag on the center top of the front housing of the engine. Just a prop governor though in between the distributer/mags - on the smaller front plate top of the front housing like in the linked photo. The harness/injection ring I am unsure of. I had thought that earlier engines would typically have the "tubular" ring and later engines would have the "flat" ring like I 3D printed above but not sure. Any input is most appreciated! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 27, 2022 Share Posted October 27, 2022 Awesome details! I purchased those ANYZ files too, but have yet to print them. FANCHERELLO is actually Fanch Lubin, who is a member here. Kev Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 (edited) Patrick - this photo tells all WRT the power plant: I can tell easily by the propeller, hub, and that skinny dome that this is a Curtiss Electric equipped aircraft - electrically powered prop pitch controls, "turtleback" style mags, where the magneto and distributors are all in the same housing. The ignition harness is completely different from any of the arrangements meant for the Hamilton Standard props (you have modeled one of them - the pressurized one I believe). Here is a picture taken from a R-2800 parts catalogue of the GE ignition system: Per my voluminous book on the R-2800 ("R-2800 Pratt & Whitney's Dependable masterpiece" by Graham White), the P-47D-28RE/RA models all got the R-2800-59 engine which is equipped with the GE ignition system. It is a "B" series, with the single stage turbocharger and down draft Bendix/Stromberg carb. No P-47 aftermarket kit does the GE ignition system justice. This is partly because, I believe, it is not normally seen on today's flying Thunderbolts. You are correct that this engine has a prop governor on the smaller forward mounting flat on the front gearbox case. And the larger aft flat is unoccupied except by a cover plate. But the engine also has a brush assembly and a round housing directly behind the propeller hub, with a visible thick wire harness between the brush box and an electrical box attached to the engine along the RH side sharing fasteners with the forward gearbox casing and the engine block. I have not seen any R-2800 kit that has these details even though plainly visible. I spent several years building a 1/18 scale P-47D-30 which has the same engine (or nearly so). The build is on LSP. I made all those details and am glad I did. I think they can be scratch made in 1/32 without much problem if you want to. I have tons and tons of data on all this, and I also made good use of the "Allied Fighters" Facebook page which chronicles in great detail the restoration of P-47D "Dottie Mae" which I seem to recall is a -28. Great pics of the GE ignition system, although it has a HS prop with hydraulic prop pitch for some reason. I also subscribe to "Aircorps Library" where drawings and technical manuals can be seen for various airplanes and engines. The Republic engineering drawings and maintenance manuals of the P-47 show quite clearly all the details of the engine's electrical system. I can provide pictures for you if you like. Let me know. Edited October 27, 2022 by JayW TAG, Landrotten Highlander, Rockie Yarwood and 1 other 4 Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 Just looked over the Vector aftermarket 1/32 kit ("early" version) - it has the turtleback mags but it doesn't have the GE ignition harness or any of the other equipment for the GE ignition system - instead it merely has two versions of the P&W harness associated with the Hamilton Standard props (one an early unpressurized one, and the other the pressurized one). Both are incompatible with the turtleback mags, although by hook or by crook the kit can still be built up. Nice going Vector... I don't know if there are better kits out there. Contact Resine appears to be worse, not better. Link to comment Share on other sites More sharing options...
petrov27 Posted October 27, 2022 Author Share Posted October 27, 2022 Hi Jay - that is some fantastic information there! I think I will attempt to replicate the ignition system you show there! If you had any more pics of that from the Dotte Mae restoration or their facebook page you mention (sadly I do not Face book) that would be great. Regarding the brush housing and prop gov - I believe this pic I found shows those components? Rockie Yarwood, D.B. Andrus and JayW 3 Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 (edited) Great pic Patrick! Oh yes that is the brush housing in all its glory. Any more pics (like side views)? Give me a few days to collect up some pictures for you. I can PM them, or put them up on this thread, your choice. It's interesting stuff. Edited October 27, 2022 by JayW Link to comment Share on other sites More sharing options...
petrov27 Posted October 27, 2022 Author Share Posted October 27, 2022 On a Wildcat but I think the same unit? Sure wish had bluprint or plan drawings for it and also the CE Prop Gov as most of that bit in 1/32 seems to be the type used with Ham Standard props (has a disk on the side) Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 1 hour ago, petrov27 said: On a Wildcat but I think the same unit? Highly doubt the same unit. It's a smaller engine. But similar. I'll need to dredge up my old pics. Link to comment Share on other sites More sharing options...
Jim Barry Posted October 27, 2022 Share Posted October 27, 2022 Replicating the exactness of the radial engines in our hobby is thankfully a voluntary thing! Good work with your challenge. Love the print success you are having. LSP_Kevin and Citadelgrad 2 Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 (edited) Here is what I could find on the engine electrical stuff on the front (visible) end of the engine. The P-47 Erection & Maintenance Manual (Document number AN 01-65BC-2) is immensely useful, but of course will not provide dimensions. You'd benefit from having that document but i don't know how to easily get it without a subscription to Aircorps Library. Most of the pics come from that document: Hub and brush housing: This view is taken from Republic engineering drawing 93P82225 Elect. Install. - Engine Compartment - you can use it to scale the brush housing (I provided some real-size dimensions that I am aware of): Some useful pics of the ignition harness (I dimensioned the engine forward case diameter at the attach flange for scaling purposes), from the same drawing and also the E & M manual: By my own scaling it appears to me the basic diameter of the harness is about 1.0 inch diameter (or 1/32 inch in 1/32 scale). The upper portion is much larger than that (where the distributor/mags attach). That's the challenge - making that upper part). I just hogged it out of a chunk of plastic when I did it in 1/18 scale. Note the turtlebacks are attached via those funny looking chambers on each side of them. You can see there is a junction box that has a wire bundle between it and the the brush box. This junction box attaches to the engine via a bracket. Some pics: Here is the box detail (some dimensions are provided - scale for any others, divide by 32): And the mounting bracket for what it's worth: Note the small box mounting holes (three) that match those on the box detail. Lastly a shot of the prop governor. Some of the above pictures show it, and it can be scaled: It would be exceedingly difficult to scratch build a 1/32 scale prop governor! Was hard enough at 1/18. This will all probably give you as many questions as answers. Let me know what else you might want; perhaps I can help further. Good luck with the P-47 build! Edited October 27, 2022 by JayW scvrobeson, D.B. Andrus, TAG and 1 other 3 1 Link to comment Share on other sites More sharing options...
petrov27 Posted October 27, 2022 Author Share Posted October 27, 2022 (edited) holy smokes that is some great info there - thanks will be reviewing! Question - when I click to make the images bigger I get an imgur error though - is there some way to link to your imgur gallery maybe? Edited October 27, 2022 by petrov27 JayW 1 Link to comment Share on other sites More sharing options...
JayW Posted October 27, 2022 Share Posted October 27, 2022 The pictures are not large files at all. I can e-mail them to you easily enough. Maybe PM me with your e-mail address? Link to comment Share on other sites More sharing options...
petrov27 Posted October 29, 2022 Author Share Posted October 29, 2022 (edited) Well again not a lot of plastic being touched but I am trying a different kind of model - trying to make the Curtiss Electric prop system as from the drawings/pics - not done a whole lot of 3D modelling at least not in many years - mostly just chopping or slightly modifying models from others. But I guess I will see how it goes! The Brush Housing is started. Not sure how much detail to put on this as the whole thing will be like 10mm wide in 1/32.... Edited October 29, 2022 by petrov27 LSP_Kevin, Rockie Yarwood, Jim Barry and 5 others 8 Link to comment Share on other sites More sharing options...
