Juggernut Posted April 30, 2023 Share Posted April 30, 2023 (edited) It may not be standard in military versions. I’ve never used a Learjet 35/36 TM. I used an official Bombardier issued maintenance manual which may or may not be the same as a military issued TM. It may have been installed via an STC, I can’t remember as I don’t remember doing the conformity inspection on the jet when it was added to our operator certificate. It may have been done by my predecessor as head of the QA department. I just remember having to remove it when we had trouble with the right fuselage tank collapsing when it was emptied (which should not happen). Edited April 30, 2023 by Juggernut Link to comment Share on other sites More sharing options...
Herbert SF Posted May 7, 2023 Share Posted May 7, 2023 (edited) I received my Learjet kit this week. 8 days for shipping after announcement is OK. Ricardo has already shown lot of pics. I am also satisfied with the surface of resin parts. Let´s see how this works during assembly and painting. Edited May 7, 2023 by Herbert SF corr pix Landrotten Highlander, Zola25, Dennis7423 and 1 other 4 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 7, 2023 Share Posted May 7, 2023 2 hours ago, Herbert SF said: I received my Learjet kit this week. 8 days for shipping after announcement is OK. Ricardo has already shown lot of pics. I am also satisfied with the surface of resin parts. Let´s see how this works during assembly and painting. Unfortunately, there are some weird assembly challenges/issues such as positioning the IP and its coaming or the cabin seats. It is also a pity the Japanese version is an afterthought with none of the internal features and no load under the pylons. Actually, I would recommend building the US version as that one will be FAR easier to reproduce! For the Japanese version you need to remove the two front bulkheads and if you're not brave close all the cabin window shutters and the entry door. However, if you rather want to open them, be prepared to modify and detail the rear of the pilot and co-pilot seats, remove the foldable table structures out of the cabin floor sides, remove some seats including the rear double one, recreate fully the cabin rear and pressurized bulkhead, add the three black boxes big racks in the cabin, etc, etc... In comparison, the US interior can simply be built OOTB! Stefano and Landrotten Highlander 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 9, 2023 Share Posted May 9, 2023 Hi again, I'm still going progressively though the kit contents. If they are generally very good, two parts are unfortunately totally inaccurate! The pilot and co-pilot seats are really horrendous. They are massive single parts whereas the actual seats are complex systems with fully hollow bases and many movable parts. Hopefully, for the US version most of the seat is hidden. However, at least two missing features will be visible: the movable side arms and the head cushions that are separated from the back. They are actually mounted on a plate fixed to the seat rear and there is a large slot in the plate (between the back and head cushions). This is used for the shoulder belts that are going through to be fixed on the rear of the seat, behind a polygon-shaped plate. Useless to say this is even worse if you want to make a version without the cockpit bulkhead. Hopefully it looks it is possible to modify the kit parts to get something that will look acceptable even if not fully accurate. Globally, this asks for removing most of the rear section (following a line parallel to the back cushion edge) to add the rear details and the missing arm. This also asks for replacing the head cushion with its support plate. I also recommend sawing the lower front edge of the seat bottom from the front cushion edge to the center of the seat depth. Not sure this will be very visible but this is easy to do and may be helpful. The other solution is a full scratchbuilding process. The TM are giving very good views of such seats but take care as they are showing them fully extended in the 'up' position. Hth Thierry Stefano, Landrotten Highlander and Jan_G 1 2 Link to comment Share on other sites More sharing options...
Sabrejet Posted May 9, 2023 Share Posted May 9, 2023 On 3/1/2023 at 10:04 PM, LSP_Kevin said: Whoever thought we'd get Cartograf decals in a resin kit? Kev A bit late but did make me laugh: Provence Moulage included Cartograf decals in their kits back in the 1980s! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Dennis Stronks Posted May 23, 2023 Share Posted May 23, 2023 Hello Thierry, do you have a source for the interior of the U-36A, I can't find any pictures on the net? best regards, Dennis Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 23, 2023 Share Posted May 23, 2023 18 minutes ago, Dennis Stronks said: Hello Thierry, do you have a source for the interior of the U-36A, I can't find any pictures on the net? best regards, Dennis Yes and it looks I was probably one of the first lucky modellers who found some on the web. I found some pictures when I had the idea to make some searches in Japanese on Google Japan because all my prior searches in English led to nothing. Go back to the links I published in the thread some weeks ago (around page 10). Landrotten Highlander and Dennis Stronks 1 1 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted May 23, 2023 Share Posted May 23, 2023 This link does not work for me: http://harukaze.tokyo/2018/11/25/u36a/ says connection refused Link to comment Share on other sites More sharing options...
thierry laurent Posted May 23, 2023 Share Posted May 23, 2023 2 minutes ago, Landrotten Highlander said: This link does not work for me: http://harukaze.tokyo/2018/11/25/u36a/ says connection refused Very probably because this is an http connection. Unfortunately browsers refuse more and more often to give access to web pages not requiring an encrypted connection. Possibly try with other browser software. Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted May 24, 2023 Share Posted May 24, 2023 Actually the main challenge to build the interior of the U-36 will not be the addition of the three racks of electronic warfare components or the correction of the front seats. This is the correction of the cabin tub part where you have to remove the side table boxes and add the correct rear bulkhead. This is the number one issue to solve as that printed resin is hard and very brittle. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 25 Share Posted March 25 There's a nice build of this kit just posted on YouTube: It's in Spanish, but there are English subtitles. Kev Jan_G, Violator1991, thierry laurent and 7 others 9 1 Link to comment Share on other sites More sharing options...
