hello hello, going to be making the Meng Monster D9R
I have Eduard interior and exterior sets
This will be a present for my niece who works in the mines
Box just fits on my work table
Ive started with the tracks which are a 3 part process and ok once you get going
I have read every build thread on the internet so i knew the tracks are to long, so i plan to extend the track tensioner to take up slack
more later
:ph34r:
I loved building this beast! And yes, extend the track tensioner, it really helps.
Cheers,  Tom
Edited by Uncarina
cool subject! I've often been tempted to get one of these. Are you going to make this a civilian one then as mines don't generally need armour?
Just on the tracks, are they individually linked? If so, couldn't you save yourself the work of extending the tensioner and just not use a couple of links? I don't know how the tracks are for this kit. If not, then I'll take notes if I decide to buy one for myself :)
Looking forward to seeing what you do with this one Rob
Si
Si, the links are individual, but shortening by one makes them too tight. I replaced the tube section with my own tubing so the distance could be adjusted by sliding.
Cheers,  Tom
Si
As tom says, the tracks are too short with one less link and too long as instructions say.
This is the fix i found on the internet, which i really like because it uses the model track tensioner mechanism.
1. Cut the wheel assembly
2. Drill out 8mm hole in each half, insert 8mm rod tube, I considered using 8mm stainless rod or acrylic rod, then i saw a papermate pen it measured at 8mm. So i cut a small section and glued it to a piece of Meng sprue and it was fine, so i added a section in one half
3. Before modification with sag
4 After pushing the tensioner out
I looked at the conversion for a civilian one and decided just to do military one, my niece wont mind, I'll tell her the machine gun is for the site managers and engineers
I love this kit and the detail, i'll probably get another with slats for myself
Thanks for the reference pics Tom
