kopterdoctor Posted January 19, 2020 Posted January 19, 2020 I thought this would be a little helpful tip. I sure didn't know this. Out2gtcha and Landrotten Highlander 2
RLWP Posted January 19, 2020 Posted January 19, 2020 I would like to see more shots of filled parts once they had got a coat of primer. My experience is, that's when you can tell if the filler is right or not* It's an interesting product Richard *If you are really unlucky, after a couple of layers of top coat
Shawn M Posted January 20, 2020 Posted January 20, 2020 i had terrible shrinkage using it, will watch the vid to see if it was user error
LSP_Kevin Posted January 20, 2020 Posted January 20, 2020 5 hours ago, Shawn M said: i had terrible shrinkage using it, will watch the vid to see if it was user error You have to use it in the smallest amounts possible to avoid this. It's also not particularly strong compared to many other fillers, so you can't really use it for larger gaps anyway. I find it great for hairline cracks and gaps (like those shown in the video thumbnail above), where you can smear it in, and then remove the excess with a moistened cotton bud. Kev Shawn M 1
blackbetty Posted January 21, 2020 Posted January 21, 2020 is that the same stuff as "perfct plastic putty"?
LSP_Kevin Posted January 21, 2020 Posted January 21, 2020 17 minutes ago, blackbetty said: is that the same stuff as "perfct plastic putty"? It's very similar, but I prefer PPP - it seems to have a less grainy consistency, and is a little easier to work with. Kev blackbetty 1
LSP_Kevin Posted January 21, 2020 Posted January 21, 2020 20 minutes ago, blackbetty said: if you keep it moist in the tube... If you're not a fan of Perfect Plastic Putty, you probably won't like the Vallejo stuff either. Kev
quang Posted January 21, 2020 Posted January 21, 2020 In the typewriter years, modellers used TIPP-EX correction fluid to fill small cracks on models. The Vallejo Putty and PPP are basically the same stuff re-directed to the modelling market. The filled seams look good when new but the putty crumbles with time. mozart 1
blackbetty Posted January 21, 2020 Posted January 21, 2020 i use PPP all the time to fill seams and cracks. with (car) primer on top i have yet to have something crack or crumble
quang Posted January 21, 2020 Posted January 21, 2020 I'm just speaking from my experience. Of course YMMV
Out2gtcha Posted January 21, 2020 Posted January 21, 2020 I think these reasons are just some of the reasons I've never trusted air-dry type putty filler for anything other than a whisper of a crack. I much prefer CA mixed with a portion of Micro-balloons (some sub talc, but I find the MB easier to work with and highly controllable and sandable) as it makes for a stable base to re-scribe on, and unlike pure CA, its not harder than the surrounding plastic, therefor sands at about the same rate depending on what you are doing, and how much of the MB are added. quang and Woody V 2
blackbetty Posted January 21, 2020 Posted January 21, 2020 yeah, scribing is another story Out2gtcha 1
Greif8 Posted January 22, 2020 Posted January 22, 2020 (edited) Like others have said, I find the putty useful for filling tiny gaps and cracks. It certainly is not as tough as two part epoxy type fillers, but does work well when used for really small jobs. The tube tip makes it easy to apply accurately and allows one to reach tough locations such as a wheel well corner or edge so that is an advantage. The video shows a couple of good uses for the putty like filling the tiny gap where fins join the fuselage or bomb body. Edited January 22, 2020 by Greif8 Word Selection
blackbetty Posted January 22, 2020 Posted January 22, 2020 if you wipe it off wet with a q-tip you may not have to sand it at all Woody V 1
