spyrosjzmichos Posted July 26, 2017 Posted July 26, 2017 (edited) Hi all! One reason why my Corsair build has slowed down is that I have taken part in a Facebook group build. The subject is the world famous F-4 Phantom II. For my build I decided to use Revell's 1/32 F-4F kit to depict a worn out Greek F-4E SRA with I will also be using the following aftermarket detail sets: Legend's resin F-4E cockpit Real Model's resin slatted stabilizers GT Resin's exhausts DEF Model's resin wheels and FOD covers Eduard's placards Airscale's dataplates and instruments Edited July 26, 2017 by spyrosjzmichos Kagemusha, Derek B, Starfighter Jock and 1 other 4
spyrosjzmichos Posted July 26, 2017 Author Posted July 26, 2017 And the build begins! Although Legend's cockpit set isn't very detailed I decided to use it as it also provides side wall panels and of course ejection seats. Preparing the plastic fuselage parts wasn't too complicated and only involved the removal of plastic from the rear and the coaming itself. I realised the resin front instrument panel and coaming would need some support so I build up the sides with plastic strips. The resin cockpit tub was quite a large piece but only needed just a bit of sanding to make it seat correctly in the fuselage. I also build up the front wheel well in order to test fit everything. Some injection holes were covered with plastic discs made with a punch n' die set. Everything went in place with little fuss! The rear instrument panel was detailed up with some lead wire. Next step, painting! F`s are my favs, Martinnfb and Derek B 3
spyrosjzmichos Posted July 26, 2017 Author Posted July 26, 2017 All parts were initially primed and then sprayed with Ammo cockpit grey. To paint the different panels some tedious masking was required. But the result was nice and sharp! Detail painting of the switches and instrument gauges followed next. More updates to come soon! F`s are my favs, Derek B, Gazzas and 6 others 9
F`s are my favs Posted July 26, 2017 Posted July 26, 2017 Yeah it's good! Very nice upgrades! Happy building! One small hint - weather the IPs good if you gonna turn it into a heavily weathered Phantom... spyrosjzmichos 1
spyrosjzmichos Posted July 26, 2017 Author Posted July 26, 2017 Love it !! Great start.....Harv Thank you Harv! agreed harv! keep at it Thanks Shawn!
spyrosjzmichos Posted July 26, 2017 Author Posted July 26, 2017 Yeah it's good! Very nice upgrades! Happy building! One small hint - weather the IPs good if you gonna turn it into a heavily weathered Phantom... Thank you Milan! I'll be posting some more pics soon and will be counting on your feedback! F`s are my favs 1
ClumsyDude Posted July 26, 2017 Posted July 26, 2017 Looks really nice Spyros. If it's not too late, I'll suggest some Airscale cockpit decals - they add a level of awesome that it's hard to get any other way. Cheers Jim spyrosjzmichos 1
spyrosjzmichos Posted July 27, 2017 Author Posted July 27, 2017 Looks really nice Spyros. If it's not too late, I'll suggest some Airscale cockpit decals - they add a level of awesome that it's hard to get any other way. Cheers Jim Thanks Jim! Great minds think alike! I have an Airscale sheet so managed to incorporate a few instrument gauges into the front and rear panels. So now it's a mix of hand painting and decals. Will be uploading an update shortly.
spyrosjzmichos Posted July 28, 2017 Author Posted July 28, 2017 Hi all! The cockpit is finally ready following some basic weathering and further detail painting! Thanks for checking! F`s are my favs, blackbetty, Seversky and 3 others 6
spyrosjzmichos Posted July 28, 2017 Author Posted July 28, 2017 Ejection seats done minus the ejection chords. With them in place I think the cockpit is starting to look nice! Now to put everything together and close the front fuselage! Doctorgaz, F`s are my favs, Martinnfb and 3 others 6
ClumsyDude Posted July 28, 2017 Posted July 28, 2017 Hey Spyros, that's a really super effect. Cockpit looks great - I love the edges you've done on the seat belts. Jim spyrosjzmichos 1
