Tolga ULGUR Posted August 10, 2017 Author Share Posted August 10, 2017 Seat with British harness is ready. MikeC and 109 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted August 11, 2017 Author Share Posted August 11, 2017 Kits exhaust stacks are not enough good. So decided to use Mastercasters P-39 Mk.1 Fish tail exhaust Each piece removed and glued on a plastic floor MikeC, Out2gtcha and Kagemusha 3 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted August 12, 2017 Author Share Posted August 12, 2017 (edited) Exhausts painted. Edited August 12, 2017 by Tolga ULGUR Whitey, rafju, MikeC and 2 others 5 Link to comment Share on other sites More sharing options...
GMK Posted August 12, 2017 Share Posted August 12, 2017 I'm really enjoying this! Lovely work! Link to comment Share on other sites More sharing options...
Joel_W Posted August 13, 2017 Share Posted August 13, 2017 Tolga, The British harness looks outstanding. Just love the realistic weathering. And those Mastercaster's Exhausts are exquisitely mastered. Joel Link to comment Share on other sites More sharing options...
Winnie Posted August 13, 2017 Share Posted August 13, 2017 Simply outstanding! Very nice, and I applaud your skill and speed! Have the P-51A Kit on the bench, but I'm not doing it the justice you are giving your kit! Link to comment Share on other sites More sharing options...
r0t0rdr1ver Posted August 13, 2017 Share Posted August 13, 2017 Awesome! Exhausts really look the part! Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted August 14, 2017 Author Share Posted August 14, 2017 I'm really enjoying this! Lovely work! Tolga, The British harness looks outstanding. Just love the realistic weathering. And those Mastercaster's Exhausts are exquisitely mastered. Joel Awesome! Exhausts really look the part! Thank you.. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted August 14, 2017 Author Share Posted August 14, 2017 Simply outstanding! Very nice, and I applaud your skill and speed! Have the P-51A Kit on the bench, but I'm not doing it the justice you are giving your kit! Thanks. Good luck on your P-51A Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted August 14, 2017 Author Share Posted August 14, 2017 Barracudacast wheels painted. And the propeller ready for installing. Gigant and MikeC 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 14, 2017 Share Posted August 14, 2017 Well to reply to the question about the Aires well. It asks for a lot of sanding to fit and finally cannot be correctly positioned at the front, close to the plane axis. However, as the main landing gear doors were normally closed, this is not a major issue. The gap can be filled in with epoxy putty and/or plastic strips. When painted this will be virtually invisible. rafju 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 14, 2017 Share Posted August 14, 2017 And for those who want to replace the too pointy spinner, Greymatter has a correctly sized one that may be reworked. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted August 14, 2017 Author Share Posted August 14, 2017 Well to reply to the question about the Aires well. It asks for a lot of sanding to fit and finally cannot be correctly positioned at the front, close to the plane axis. However, as the main landing gear doors were normally closed, this is not a major issue. The gap can be filled in with epoxy putty and/or plastic strips. When painted this will be virtually invisible. I am planning some fixings for the next time. I have a few more of these kits. Using the Aires set does not sound good for me. I used it on my Trumpeter P-51B project last year and It was not so comfortable http://forum.largescaleplanes.com/index.php?showtopic=63148&hl= Trying to extend backward whell well by cutting rear sidewall and add some details maybe a solution.. Link to comment Share on other sites More sharing options...
thierry laurent Posted August 14, 2017 Share Posted August 14, 2017 Possibly. Using the Aires well is doable but asks for serious work. Seeing your build gives me again the desire to end my A-36. I solved most of the kit major problems except the radiator. Link to comment Share on other sites More sharing options...
Joel_W Posted August 15, 2017 Share Posted August 15, 2017 Tolga, Your continued attention to every detail is certainly resulting in an extrodinary build. Just one question. Your tires look so much better then mine which are usually done in a very dark German Gray or Nato Black, but don't close to looking like real tires as your do. I would really appreciate knowing what color paint you used? And I'm assuming that you used pigments on the treads not a wash which usually leaves an unnatural ring around the side walls. Joel Link to comment Share on other sites More sharing options...
