David Hansen Posted December 12, 2016 Share Posted December 12, 2016 I wonder if subsequent clear and flat coats will tone it down sufficiently.... -d- Shaka HI 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted December 13, 2016 Author Share Posted December 13, 2016 Interesting observation Kurok about silver being too bright. It's actually a bit full on the wing do I think I'll be OK. I think if you add grey to it, it'll end up more of a silver dope look. Shaka HI 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted December 13, 2016 Share Posted December 13, 2016 Nah, I agree with KUROK. The silver's too bright and subsequent flat coats do not seem to tone this down. This is the exact reason, why come back with washes and/or post shade of the area with a variation of the color (very diluted) of the AC. KUROK 1 Link to comment Share on other sites More sharing options...
KUROK Posted December 13, 2016 Share Posted December 13, 2016 I would recommend a specific mix but have to shamefully admit I have not figured it out. My model production rate is not great but I will do a 1:32 soon, I promise! Anyway, all I know is I used silver paint to do very light chipping on a 1:72 P-40 and it just seemed crazy bright. I would think larger scales would be less like this so my advice is to experiment on an old "paint horse" model. Shaka HI 1 Link to comment Share on other sites More sharing options...
David Hansen Posted December 14, 2016 Share Posted December 14, 2016 Steel is a little bit darker.... maybe that would be a good substitute? -d- Link to comment Share on other sites More sharing options...
Uncarina Posted December 14, 2016 Share Posted December 14, 2016 (edited) Carl, I'm just getting caught up with your build, and love your work and the intel! Right now I'm a fan of Tamiya AS-12 as a base coat. It's aggressive/durable, and you can have a measure of control over how much you expose. I'm also a fan of the Prismacolor colored pencils. I also like "Reluctant Dragon" as a subject, but just have one photo. Cheers, Tom Edited December 14, 2016 by Uncarina Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 14, 2016 Share Posted December 14, 2016 Right now I'm a fan of Tamiya AS-12 as a base coat. That would be my default recommendation for this application, too. Terrific and highly versatile paint. Kev Uncarina 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted December 14, 2016 Share Posted December 14, 2016 So you guys are applying this straight from the rattle can and it sticks to the plastic like a primer? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 14, 2016 Share Posted December 14, 2016 So you guys are applying this straight from the rattle can and it sticks to the plastic like a primer? You can do it that way, but I prefer to decant it and treat it like normal paint. I prime everything, and avoid putting paint down over bare plastic under most circumstances, especially since I mostly use acrylics. Kev Uncarina and Shaka HI 2 Link to comment Share on other sites More sharing options...
Uncarina Posted December 14, 2016 Share Posted December 14, 2016 So you guys are applying this straight from the rattle can and it sticks to the plastic like a primer? I'm applying it directly to clean bare plastic/resin. It has enough bite that I haven't encountered any adhesion issues. Cheers, Tom Shaka HI 1 Link to comment Share on other sites More sharing options...
David Hansen Posted December 14, 2016 Share Posted December 14, 2016 Yeah the consensus seems to be people decant this stuff, and spray it thru an airbrush. On a side note, i took some old Model Master silver or aluminium in a spray can, decanted it, and it too sprayed beautifully. It was a lacquer, not an enamel and i'll bet its a lot like Tamiya AS-12. But it was years ago. -d- Uncarina and Shaka HI 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted December 14, 2016 Author Share Posted December 14, 2016 I haven't tried decanting spray paints before so might give it a shot in the future. In the meantime, i airbrushed some yellow onto the wing: Once that's dry, I'll do the top colour and finally the weathering. Carl Shaka HI and Whitey 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 15, 2016 Share Posted December 15, 2016 Hi Carl The yellow chromate looks nice and smooth. having played around over the past few years with lots of NMF, most gloss coats kill the metallic shine and depending on the degree of flat at the finish, it will surely dull down and darken the aluminum quite a bit. I'm in your corner and following with notebook in hand Keep 'em coming Peter Link to comment Share on other sites More sharing options...
BloorwestSiR Posted December 15, 2016 Author Share Posted December 15, 2016 Hi Carl The yellow chromate looks nice and smooth. having played around over the past few years with lots of NMF, most gloss coats kill the metallic shine and depending on the degree of flat at the finish, it will surely dull down and darken the aluminum quite a bit. I'm in your corner and following with notebook in hand Keep 'em coming Peter Thanks Peter. One thing I realized is that with this focus on the inner wing section, I had better do the outer wings in a similar Gavin or there would be a disconnect between them. So I've started on those now and hope to have them ready to spray the grey at the same time. Carl Link to comment Share on other sites More sharing options...
Shaka HI Posted December 15, 2016 Share Posted December 15, 2016 Is there some definitive thread to what that green/yellow chromate is suppose to look like or if it is different how/what/when/where it was applied? I have a Corsair on order -- not the "Bird Cage", but the 1A (why so many Bird Cage builds?), but I wanna weather this sucker to abandon! BloorwestSiR and tomv87 2 Link to comment Share on other sites More sharing options...
