mozart Posted March 10, 2016 Share Posted March 10, 2016 So the IP is coloured PE supplied with the kit David? It's all looking rather splendid so far, looking forward to seeing more! Max Link to comment Share on other sites More sharing options...
dennismcc Posted March 10, 2016 Share Posted March 10, 2016 That looks very nice indeed, and OOB, which bodes well for the rest of the kit. Cheers Dennis Link to comment Share on other sites More sharing options...
Dukie99 Posted March 11, 2016 Author Share Posted March 11, 2016 The colored IP is indeed provided in the box, it is made of three pieces glued on top of each other which gives it a nice 3D effect. I checked tonight the PCM website (www.pacmodels.com) and this kit appears to be still in stock and is sold for USD 70. David mozart 1 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 11, 2016 Share Posted March 11, 2016 Nice start David and a hearty welcome. I suspect that this kit will take alot more work than the Tamiya kits but you'll end up with a great Spitfire at the end of it. Keep at it. Cheers. Link to comment Share on other sites More sharing options...
MikeC Posted March 12, 2016 Share Posted March 12, 2016 Looking good so far, and following ... Link to comment Share on other sites More sharing options...
monthebiff Posted March 12, 2016 Share Posted March 12, 2016 Very nice work, I'm currently building a PCM Hurricane and its a really nice kit, I'm sure the Spit will build up just as nicely. Regards. Andy geedubelyer 1 Link to comment Share on other sites More sharing options...
Dukie99 Posted March 29, 2016 Author Share Posted March 29, 2016 Hi everyone. Maru Thank you for encouraging me to post. I made some progress but there is not a ton to see for now because it has been a lot of sanding, puttying and resanding. The fit of this kit is not bad at all but by all means it does not fall together without effort. Here are two in progress shots: Since these two shots, I have finished sanding, rescribed some of the lost panel lines and rivets and primed the kit. I have applied the sky color on the tail and the yellow on the front of the wings. Once I have masked these I will start the camo. I have also done the prop and wheels and will post some pictures tonight. Thanks for following this build, this is a fun GB and I am very much looking forward to the Eric Brown GB starting as we should see an amazing range of airframes (I am thinking of building a HS-123...). David geedubelyer and SciFi58 2 Link to comment Share on other sites More sharing options...
mozart Posted March 29, 2016 Share Posted March 29, 2016 Well done David, looks like a lot of hard work there but I'm sure the end result will be worth it. Looking forward to more progress shots soon. Max Link to comment Share on other sites More sharing options...
MikeC Posted March 29, 2016 Share Posted March 29, 2016 Clearly not a "shake and bake", but looking good so far. Link to comment Share on other sites More sharing options...
Dukie99 Posted March 29, 2016 Author Share Posted March 29, 2016 Thank you guys for the encouragement- As promised some more progress pics: The spinner Preshading with Tamiya German Grey: and the bottom colors, using Gunze paint. Looking forward to do the camo in the coming days. Cheers, David geedubelyer and SciFi58 2 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 29, 2016 Share Posted March 29, 2016 Super looking Spitfire David. You've made a good fist of things so far, well done. The spinner and blades look particularly good. Cheers. Link to comment Share on other sites More sharing options...
SciFi58 Posted March 30, 2016 Share Posted March 30, 2016 Looking great, David. Hope mine turns out as good as yours is looking. Nice to know you're having fit problems too just to know its not me. Link to comment Share on other sites More sharing options...
Collin Posted March 30, 2016 Share Posted March 30, 2016 Awesome....love seeing these kit's being built. Not the easiest of builds...but if you are careful they turn out very very nice. As I type this, I'm looking at mine on the shelf. http://forum.largescaleplanes.com/index.php?showtopic=58155&hl=%2Bcollin+%2Bspitfire&do=findComment&comment=713547 Cheers Collin Link to comment Share on other sites More sharing options...
dennismcc Posted March 30, 2016 Share Posted March 30, 2016 It's looking good, that big spinner, 5 blades and the Griffon nose really gave an aggressive look to this Mark of Spitfire. Cheers Dennis Link to comment Share on other sites More sharing options...
Dukie99 Posted March 31, 2016 Author Share Posted March 31, 2016 Collin, your spit looks amazing! I very much doubt will be looking as good, but I will try my best. I have done the camo. It looks pretty harsh right now but I will tone it done with a blue-grey filter. To mask the camo, I used Panzer putty: Pretty amazing stuff, it warps around details very gently and is a breeze to remove and reusable too. On the home stretch now. Thanks for watching. David Kagemusha, dmthamade, mozart and 3 others 6 Link to comment Share on other sites More sharing options...
