SciFi58 Posted December 27, 2015 Posted December 27, 2015 The kind folks have allowed me to join with a started Spit. As the title says, this is the PCM IXc. I started it a long time ago, like so many models. I hope to finish this one as I work in tandem on my first wooden ship. Here are all the started assemblies, a few pieces assembled and some base color on some. Now I just need to clear a path to my disaster area model bench and get some color on the cockpit. geedubelyer 1
Iain Posted December 27, 2015 Posted December 27, 2015 Welcome to the group build - look forward to seeing what you make of the kit! Iain
artoor_k Posted December 27, 2015 Posted December 27, 2015 I have the same set. Look forward to see your build and what's waiting for me
dennismcc Posted December 28, 2015 Posted December 28, 2015 Should be interesting, I've got a couple of those lurking in the loft, though I think the title needs a slight mod (Mk IVc) Cheers Dennis
geedubelyer Posted January 8, 2016 Posted January 8, 2016 Hello SciFi58, how are you getting on with your PCM Spitfire? My cousin built their Mk IX and found it to be quite a challenge but then it was his first multi-media short run kit. I hope you're getting to grips with your project. Cheers.
SciFi58 Posted January 14, 2016 Author Posted January 14, 2016 Thanks gang! Geedubelyer, it is proving to be a character builder. The resin cockpit is nice as is the PE (if I didn't keep loosing seat belt parts and placards). I finished the cockpit, as seen below, but getting the wing into place after I got the fuselage halves together was a challenge. As it was there are gaps at the root. I always have gaps at the root. I have gaps at the root even with Hasegawa kits. There's something wrong with me. I have four Tamiya kits in the wings, both Zeroes and both Corsairs, and if those wings don't just slide into place perfectly I'll know it's me. At least my plank on frame HMS Bounty Launch is going perfectly. I can give up plastic and build wood. But I digress. I finally got the wing on a filled the canyons with some card only to realize, I forgot to install the exhausts. Off with its wing! Now I can't find the exhausts I wanted to use (used the last of my Metalizer burnt iron on 'em too) so I may have to use the round ones. The wood kit is really going so much better. I can even bend frames successfully and that scared the poop outta me. Well.... here is the cockpit. The only other thing that is done is the fuselage halves are together. geedubelyer 1
mozart Posted January 14, 2016 Posted January 14, 2016 (edited) Perhaps you should build a Mosquito, they're made of wood! Nils desperandum!!! Max Edited January 15, 2016 by mozart
SciFi58 Posted January 14, 2016 Author Posted January 14, 2016 I have a Revell Mosquito in my collection, Max. But it's plastic. I need to find a wood model of a wood Mosquito!
geedubelyer Posted January 15, 2016 Posted January 15, 2016 Well it may be a challenge but it looks as though you are well up to the task. Neat work on that cockpit. Cheers.
SciFi58 Posted March 30, 2016 Author Posted March 30, 2016 I've been struggling with this monster, although I strongly suspect I am the monster. Still, the wing to tail panel fit seems beyond any error I made. The big issues that I have been sanding and filling on are the wingroots, where the lower wing meets the nose and that darn aft wing insert. Almost done and the rest should fall together. Two general looks: Here is that aft wing insert: And the cockpit in place: Shaka HI 1
mozart Posted March 30, 2016 Posted March 30, 2016 Well done you for sticking with those fit issues, they look pretty serious.....certainly enough to dissuade me from ever trying a PCM Spitfire, though I do have their Hurricane! Max
Dukie99 Posted March 30, 2016 Posted March 30, 2016 Hi Sci-fi, I had the same issue on my PCM MkXIV, used a lot of putty to fill the gap. it did not turn out perfect but goog enough, definitely the low point of my build too. Keep it up, once I paint and decals my model I tend to forget about these little blemishes and all I see is a perfectly good looking model:)
dennismcc Posted March 30, 2016 Posted March 30, 2016 I usually just insert a piece of scrap plastic card in gaps like that and fill with CA, usually works a treat, the PCM and SH short run kits do tend to have character building fit issues but it is normally worth dealing with them for the range of subjects that you can get from them. If I remember correctly the Spitfire IX from PCM was the first IM kit of the IX and was much anticipated at the time of it's release. Cheers Dennis
Shoggz Posted March 30, 2016 Posted March 30, 2016 Hi Sci-fi, I had the same issue on my PCM MkXIV, used a lot of putty to fill the gap. it did not turn out perfect but goog enough, definitely the low point of my build too. Keep it up, once I paint and decals my model I tend to forget about these little blemishes and all I see is a perfectly good looking model:) My sentiments exactly! And we'll done SciFi for persevering with a challenging build. If it's any consolation I can never seem to get things to fit either.. geedubelyer 1
