b757captain Posted July 28, 2015 Author Share Posted July 28, 2015 I still have one of these kits in original shrink wrap, both bought in or around 1996 or so. Someday I might unwrap it and see if it has rubber tires That's after I complete all the Trumpter 262 variants and have nothing else to build On to the cockpit. The theory - fitting into the alternate history timeline - is that over time aspects of the original aircraft will be improved, modified and upgraded. So I robbed parts from a CZ T-33 kit since I have a resin set for it. Seems like it could be modified to fit and give the cockpit a more modern US look. First up was to measure for length and depth. I kept the kit cockpit bulkheads in place to start: Then cut the T-33 front pit to the proper length, test fit and check for depth. To do this I fitted the seat in relation to the canopy to set its height, then fit the cockpit tub with seat and raised the floor until it looked right. I cut about 3/16" out of the sidewalls to raise the floor: Several more test fits and everything looking good, so off to the paint shop: Last was to modify the F-100 instrument panel to fit. I used the measure once, cut twice method here! Mark Girlscanplay2, Lars Befring, Uilleann and 1 other 4 Link to comment Share on other sites More sharing options...
b757captain Posted July 28, 2015 Author Share Posted July 28, 2015 New updated cockpit installed: Next up, major component assembly and filler! Mark Lars Befring, Menelaos, Girlscanplay2 and 1 other 4 Link to comment Share on other sites More sharing options...
Hardcore Posted July 29, 2015 Share Posted July 29, 2015 Really cool with ejector seats Link to comment Share on other sites More sharing options...
b757captain Posted August 12, 2015 Author Share Posted August 12, 2015 Been plugging away on the -262 between other projects, plus had to get current on the 767 again for a new job. Here's the progress: Joined the wing and fuselage. Lots of test-fitting made gluing anti-climatic: Add some weight before closing the nose up: And then - fill the gaps! Mark Uilleann, Menelaos and Lars Befring 3 Link to comment Share on other sites More sharing options...
b757captain Posted August 12, 2015 Author Share Posted August 12, 2015 After sanding and primer on the filler spots, the first color is on! My plan for paint is the blue first, mask that, add the white scallops plus the tail surfaces, mask that, red next, then leave all that masked and hit the airframe with silver. I'll probably use the AKI Extreme aluminum for that without any prep, not planning on doing any shaded panels. It worked pretty well on the F-86D I just finished so long as I don't have to mask any of the AKI. All the paints are MM enamel flats - I like them for durability and quick drying. I can usually mask over them after a few hours with no lifting. They gloss up really nice with 5 or 6 coats of Future. I stopped spraying gloss paints cuz I don't like to wait! Mark Girlscanplay2, Leaning_Dog, Uilleann and 2 others 5 Link to comment Share on other sites More sharing options...
Hardcore Posted August 12, 2015 Share Posted August 12, 2015 you will only ever mask once! Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 12, 2015 Share Posted August 12, 2015 Looks great! This is SO off the wall its really a treat to observe coming together...................but that IS what the What if? is all about! I wasn't sure if you were going with the white T-birds scheme or the NMF. I have to say, I like the idea of the R, W & B WITH the natural metal myself. Looking forward to some more paint! Link to comment Share on other sites More sharing options...
Aluxe Posted August 16, 2015 Share Posted August 16, 2015 It goes very well --- Link to comment Share on other sites More sharing options...
BloorwestSiR Posted August 18, 2015 Share Posted August 18, 2015 Looks great Mark. The T-bird translates really well onto the 262's shape. Carl Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2015 Share Posted August 18, 2015 I love it!!....Harv Link to comment Share on other sites More sharing options...
b757captain Posted August 22, 2015 Author Share Posted August 22, 2015 Short update tonite: The last few days have been masking, painting, re-masking, painting, then re-masking again. Red, white and blue on: Tomorrow I'll mask the rest and spray the silver. No differentiation of panels, just single color. I haven't had time yet to experiment much with the AKI Extreme Aluminum but it worked well enough on my F-86D that I'll go with it here since there should not be any masking over the aluminum. Cheers, Mark Lee White, Lars Befring, Girlscanplay2 and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Posted August 22, 2015 Share Posted August 22, 2015 Good show Mark !.......Harv Link to comment Share on other sites More sharing options...
b757captain Posted August 22, 2015 Author Share Posted August 22, 2015 you will only ever mask once! Oh, if only!! Looks great! This is SO off the wall its really a treat to observe coming together...................but that IS what the What if? is all about! I wasn't sure if you were going with the white T-birds scheme or the NMF. I have to say, I like the idea of the R, W & B WITH the natural metal myself. Looking forward to some more paint! Definitely NMF instead of overall white. I never thought a NMF 262 (or any NMF Luftwaffe a/c) looked good - to my eye it just has to be RLM, but the T-bird scheme does fit pretty well. Link to comment Share on other sites More sharing options...
b757captain Posted August 23, 2015 Author Share Posted August 23, 2015 Good show Mark !.......Harv Thanks Harv! WOW ! That is very impressive work Mark, and having seen your recent model that you finished , this will also turn out SUPERBLY.. Keep on Rocking :punk: Thanks Maru! Link to comment Share on other sites More sharing options...
b757captain Posted August 23, 2015 Author Share Posted August 23, 2015 Progress continues: NMF on and unmasked. I didn't have as much edge chipping and bleed-under as I thought so about an hour fixing a few spots and here she is: I tried masking the stars on the tail - failed! Gotta go to plan B for them. My decal stash leftovers so far have come up empty, only some small white stars. I do have a complete set in blue but they are earmarked for the eventual F-84G T-bird. Tomorrow will be clear-coat to get ready for decals, and gear and gear doors. I do have enough leftovers to do everything but the T-bird emblem. I might have to sacrifice the F-84 sheet for the -262! Mark dmthamade, Lars Befring, Uilleann and 1 other 4 Link to comment Share on other sites More sharing options...
