1,813 -
Everything posted by Alain Gadbois
Large Scale Aircraft 'in flight' - how ?
Alain Gadbois replied to Chris Ward's topic in LSP Discussion
Wow! Great bases (the bridge and sea flashing by) and incredible paint job on the models! Alain -
It’s the « any version » that triggered my facetious response! Still, so many interwar design deserve to be kitted! Alain
So would I!
Trumpeter 1/32 Mig 3 "White 21"
Alain Gadbois replied to mywifehatesmodels's topic in Works in Progress
What a great looking MiG! I really like the camo and markings. The scratched paint is also well done! Alain -
Max, Another interesting detail present on this plan that can be verified by some photos posted here: The large radiator under the right wing has its opening parallel to the wheel well, so shows a distinct angle when viewed from below. Alain
Hi Max! I have this book with these drawings. I can scan and email them to you if they may help you. Also in the book some pictures of K5054, including one side view when unpainted, taken just a bit higher up than the one posted here, the fuselage not hidden by the left wing. Alain
Sukhoi Su-24M "Stormbringer UAF" [Trumpeter 1:48] - RFI
Alain Gadbois replied to Alex's topic in Non-LSP Works
What a beauty! Great work all around! Alain -
Good assessment of the HB kit. I would add the the bump on the left side of the top cowl should blend into it softly rather than the hard angle as molded. Also the cowl louvres are completely wrong as they should trapezoidal in shape. Really nice model, well done! If you have a D-11, D-16 or Ta152 intake, you could modify the kit to make one of the few short wing, Jumo engined recon version built. Alain
Yes, some progress in details, and it is really time for an update. Alain
Focke-Wulf FW 190 F-8 - 6./SG 10 - Revell 1/32
Alain Gadbois replied to Furie's topic in Works in Progress
My quick observation: The front of the yellow band is the panel line and this is correct on the model. The back of the line is halfway between latches on your model, but more forward on the photo. Probably simplest to completely repaint the sides panels and just move by the correct amount the yellow on top and bottom cowls. Alain -
Nice cockpit! The kit panel is usable, if you find instrument decals it should look ok! In reality there is a cover over the central instruments (useless weight, no?), but this would be a pain to make and not very noticeable. The windscreen is a three part, glued together unit. Maybe just delicately scrape the raised details a bit then a touch of repolishing. Should look very similar to the photos we see. Alain -
Hope this helps! Two different crashed MiG-3s, plus parts of one captured by Finland, kept in a museum there. Alain -
Beautiful work on the flaps, and what a perfect fit! I am still impressed by the massive bomb bay, stretching along almost the whole fuselage! Alain
In the Monogram Japanese Cockpit Interiors book, there is a side view of the aircraft showing a fixed, rearward extension of the spinner all the way back to the pushrods. From this I think only the cylinders will be visible from the front. Alain
For all of you lucky owners of a MkI Spitfire, here’s all you need to know about the daily inspection of your prized aircraft! For all the others, you may console yourself by using this great reference for your Kotare or Revell build. By the way, who can spot rivets on that beauty? Alain
Revell 1/32 F-4E (from F-4G kit) 32nd TFS - The paint is on!
Alain Gadbois replied to Grunticus's topic in Works in Progress
Excellent progress! I like the choices you made regarding perfect accuracy vs build time. Also thanks to all members for their great help with the particulars of the Revell kit and photos of the 1:1 subject! Alain- 218 replies
- 32nd tfs
- revell f-4
(and 2 more)
Tagged with:
Fun idea! I’d like to see the installation of the motor and electrical system. Now that I think of it, the Bf 109 E had the option of an engine, so I guess the Hurricane also has that. Alain
Hasegawa F-86F-40 "Blue Impulse" Finished
Alain Gadbois replied to Ayovan's topic in Hasegawa Builders
Great job! Colorful and eye catching paint finish! Alain -
Hasegawa: Me 262 " What if ? " FINISHED !
Alain Gadbois replied to Erwin's topic in Hasegawa Builders
Excellent! The Kaiser would approve! Alain -
Looks great! You can’t tell the assembly was so problematic. Your fine tuning the parts gave an excellent result. I have one, and all those separate wing parts for no clear reason and complex assembly makes me put back starting it. Alain
Azur Bloch MB 152C.1 - Zdzislaw Henneberg, France 1940
Alain Gadbois replied to R Palimaka's topic in Works in Progress
Great project! Nice to have a French aircraft in this GB. The Bloch 152 wasn’t the best performer, but was sturdy enough and really has an interesting look! Alain -
1/32 De Havilland DH-100 Vampire Mk.6 J-1200
Alain Gadbois replied to CarstenB's topic in Works in Progress
The long intake fairing on the right side has to do with an air conditioning system and this would the found on the FB 9 version. Alain- 121 replies
- swiss air force
- dh-100
(and 3 more)
Tagged with:
Brilliant! So well integrated, it looks like the RAF had a supersonic Bucc in its inventory! Alain
The Finnish sniper one made me laugh too much! Alain
