Madelf75
310 -
Days Won
1
Posts posted by Madelf75
19 hours ago, Alain Gadbois said:
I am not too sure if how off the engine cowl are off they look about right on this drawing
I have built a few of them they will do the job at holding their own up
1 hour ago, Iain (32SIG) said:
Make it the 'LSP Fix' - *if* we manage to fix it!
Busy putting stickers on a Spitfire again - so not sure if there will be any more on the Lib today.
I *do* want to get this done and dusted as soon as I can - maybe over the next week - as I need to keep momentum/interest going...
Iain
I want to thank you for sharing your great work . You are really taking this on keep up the Good work I will be following for sure .
Steve
On 1/1/2019 at 1:33 PM, TimHepplestone said:
Very nice images on FB. Forgot to ask. Did you use the Brassin engine or cockpit. Or both. And if either are they worth the expense. I have the same kit and am looking at starting the inevitable am collection. lol
yes i use both sets they went together very well with no big issues
nice work
Thank you everyone for all the kind words
here is a great site i found with some good reference on the B-24 http://legendsintheirowntime.com/LiTOT/B24/B24_Av_4507_DA.html
8 minutes ago, 32scalelover said:
Not sure if this is the correct thread to post this, but I purchased the HB 1/32 B-24J and want to convert it to a B-24H that my Uncle flew in. He was the right waist gunner in the Ken-O-Kay from the 732nd Sq 453rd Bomb group. I have photos of the aircraft and will have to come up with a way (masks or decals) to replicate the markings. I am not sure how to post photos here or I would post the photos I have.
Hopefully the differences between the H and J are not to difficult for me to correct.
Greg
is this this AC that you are talking about
My Revell Fw 190A-8 added with Brissin resin and eduard's PE most of the marking are painted on the heart and nose art are from Eaglescals
here are some pics that i had taken at Eppley Airport back in 2015
- rafju, D.B. Andrus, nmayhew and 1 other
- 4
Looks really good nice job
Nice work love the colors
On 9/13/2018 at 12:41 AM, blackbetty said:
shows what is involved in the conversion
that is 12 takers as of yet.....
So where can I find a resin conversion for the corsair?
11 hours ago, Dandiego said:
Hello Madelf75, everyone has their little cheats for building models and this is one that I have used before. I have built other models using this technique and have had no bleed through after 3 years.
I did say that I use only Model Master paints and maybe that is the secret, who knows. Anyway this is a really fast way to do pre-shading and I thought I would share it with the group.
Dan
Cool i am sure when it is done it will look really good
On 8/28/2018 at 9:01 PM, Dandiego said:
A little progress....
I have put some dark Ghost Grey on the upper fuselage. I have preshaded the panel lines with a marker!! I know that some consider this as a bad move but it works for me. I was able to apply the shading over the entire airframe in only 20 minutes. The marker seems to soak in to the flat paint and does not present any problems on the color coats to follow. Anyway here are the photos.
Go ahead....Fire away.
Dan
I use to do my pre shading this way
This is a good way to find what works for you, one of the issues I had was the black would soak through the paint months after I painted it.
Just remember got to do what you like
On 9/4/2018 at 2:06 AM, Fooesboy said:
Go get a hypodermic needle, cut the tip off so that it is no longer sharp. The plastic end on the needle fits nice and tight onto the end of the Zap CA bottle.
When the needle gets blocked with glue simply take a lighter and heat the tip, the glue will burn out and leave a nice fresh fine hole to apply the glue with.
As an added benefit as the needle blocks it keeps the glue fresh!
You can buy hyperdurmic tubing any size you want on ebay .so no need for the needles
Nice work love the paint job
I was wondering didn't these plans fly out of Harrisburg PA?
I have their1/48 pby kits talk about great models lot of detail .
I remember my first kit was a 1/48 B-17 from Monogram this was back in 1987 for 14$
HK Models 1/32 Avro Lancaster
in Multi-Engine GB
Very nice I use a silhouette 3 cutter for my mask .Does the machine the machine you are using does it come with it's own drawing software to use?
