Ralph Riese Posted December 26, 2011 Author Share Posted December 26, 2011 Yep lazycat - got the shape thing. Only way I could see would be to thin the fuselage halves from the inside and make some bulkheads (like the new Hasegawa Raiden) to pull the shape in. I'm hopeless at anything much past OOB (as you'll see below) so will leave the corrections to the good guys. Fitting Master Model (AM-32-018) Hispane 20mm cannons.... Slight difference in size; nice improvement in the detail. Line drawings show a ring on the cannon near the wing leading edge - where the cannon fairing meets the wing stub (I think). The ring wasn't apparent on the metal parts. Without the ring the part was positioned by measuring wing edge-to-cannon muzzle on a 48th scale line drawing and scaling to 32nd. The mess I made when removing the kit cannon and drilling into the wing was covered with some 5 thou card once the metal parts had been glued in with 5-minute Araldite. Would have been sensible to sand off the "plate" rather than simply adding the card over it. "Next time..." Thanks for looking. Cheers, Ralph. tomv87 1 Link to comment Share on other sites More sharing options...
Ralph Riese Posted January 1, 2012 Author Share Posted January 1, 2012 Model primed with a 50:50 mix of Tamiya's acrylic XF-2 Flat White and XF-19 Sky Grey. The mix was thinned with Tamiya's lacquer thinner in the hope of avoiding the chalky, flat finish. In this case the finish is much less chalky and more durable, but still dead flat. Cockpit door hinge copied from the Tamiya Mk.IX part - added with bits of stretched sprue. Amazing how a little paint shows up misaligned parts and gaps... "Happy New Year" to all. Thanks for looking. Cheers, Ralph. tomv87 1 Link to comment Share on other sites More sharing options...
Guest Posted January 1, 2012 Share Posted January 1, 2012 Base coat looks good. I see a few small fixie spots, but overall a good start.....Harv Link to comment Share on other sites More sharing options...
Ralph Riese Posted January 2, 2012 Author Share Posted January 2, 2012 Cheers Harv - fixes done, and some underside colour applied. Basecoated with a 3:1 mix of Tamiya XF-2 Flat White and XF-23 Light Blue based on the "RAF Sky Blue" callout for afew Malta Defenders depicted on the Rising Decals "Mediterranean Spitfires" decal sheet (72037). Some Tamiya tape added here and there, and then some mottling with XF-82 Ocean Grey 2 (RAF), XF-68 NATO Brown, and XF-49 Khaki. Misting coats of Gunze Sangyo H314 Blue FS35622 to pull things together... Martinnfb and tomv87 2 Link to comment Share on other sites More sharing options...
Ralph Riese Posted January 2, 2012 Author Share Posted January 2, 2012 ... and then the Tamiya tape removed. Comments welcome. Thanks for looking. Cheers, Ralph. Martinnfb, alaninaustria and tomv87 3 Link to comment Share on other sites More sharing options...
zaxos345 Posted January 2, 2012 Share Posted January 2, 2012 Awesome painting, what else can i say? Happy to ''see'' you again Ralph, Happy new Year my friend!! John Link to comment Share on other sites More sharing options...
Macbain Posted January 10, 2012 Share Posted January 10, 2012 I am very interested in the weathering method you used, that is very realistic. Especially the non-weathered panels hidden by the tape, great idea. Thanks for the 'how to' process. This may be enough to force me to buy the Hobby Boss kit. Keep up the good work. Link to comment Share on other sites More sharing options...
Harold Posted January 10, 2012 Share Posted January 10, 2012 Love the paint... great job so far. Link to comment Share on other sites More sharing options...
eagledocf15 Posted January 11, 2012 Share Posted January 11, 2012 Fantastic Work!! Thanks for sharing Link to comment Share on other sites More sharing options...
dodgem37 Posted January 12, 2012 Share Posted January 12, 2012 You are just so damn creative, Ralph. Thanks a heap for the show & tell. Sincerely, Mark Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 30, 2012 Share Posted January 30, 2012 I just ordered this kit Ralph (actually the Vb, not the trop version), so I'll be eyeballing. Great job so far, as usual. Link to comment Share on other sites More sharing options...
Ralph Riese Posted May 2, 2013 Author Share Posted May 2, 2013 (edited) been a while... found a Malta Spitfire scheme, so preshading with XF-52 Flat Earth and XF-54 Dark Sea Grey... equal parts XF-52 and XF-79 Linoleum Deck Brown for the RAF Dark Earth, and equal parts XF-54 and XF-18 Medium Blue for the blue-grey... Edited May 2, 2013 by Ralph Riese tomv87 and Martinnfb 2 Link to comment Share on other sites More sharing options...
Ralph Riese Posted May 2, 2013 Author Share Posted May 2, 2013 (edited) markings painted using Mal Mayfield's Mircle Paint Masks... 3:1 mix of XF-69 NATO Black and XF-1 Flat Black for the modified black 3:1 mix of XF-3 Flat Yellow and XF-4 Yellow Green over straight XF-4 X-3 Royal Blue, and 1:1 mix of XF-7 Flat Red and XF-10 Flat Brown not sure about the code placement - the "GL" wouldn't fit between the roundel and the serilal number, so "say no more..." Edited May 2, 2013 by Ralph Riese Martinnfb and tomv87 2 Link to comment Share on other sites More sharing options...
Ralph Riese Posted May 2, 2013 Author Share Posted May 2, 2013 Comments/critisim welcomed. Thanks for looking. Cheers, Ralph. Martinnfb 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 2, 2013 Share Posted May 2, 2013 Excellent work as always Ralph. Thanks for the tip about Royal Blue for the roundel colour! Kev shepard 1 Link to comment Share on other sites More sharing options...
