Ralph Riese
1:32 Hobby Boss Spitfire Mk.Vb Trop
Airframe assembly... Kit went together pretty well. Rivets added to the engine cowl panel parts using the Tamiya kit parts as a guide. Fabric detail removed from upper tailplane parts and rivets copied from the underside parts. Fictional rivets added to the Vokes filter to tie it into the rest of the model.
Cheers, and thanks again for looking. Ralph.
Ok Ralph, that's just nuts! Where do you find the time for goodness sake. I'm still working on the one and only model I've started this year. Yes, I admit I'm slow but sheeeesh, this has to be your eleventeenth model this year alone!ohmy.gif
Cheers,
Wolf
Guest
I have one on the way, so very interested in this build. Although its not the Trop, it is interesting to see what probs you come up with. Please explain any you find.....Harv :speak_cool:
Thanks for the interest so far Gents. Wolf - this is my version of a cheap holiday. Grabbing some time off and sppending it quite self-indulgently.
As noted in reviews, the HB windshield is not suitable for the Vb Trop. Have tried to replace it with the windshield from Tamiya's Mk.VIII kit.
The Tamiya part before the carving...
Removed all plastic up to the instrument panel, the small locating pin on the Tamiya part, and the raised detail forward of the windshield.
The Tamiya gun sight was installed after a small adjustment to the mounting peg.
After checking that the gun sight didn't interfere with the windshield fit Tamiya thin glue was applied wher the parts touched.
The HB fuselage is wider than the Tamiya part so there's some reshaping to be done yet.
Gaps have since been filled with Revell Contacta glue. Will let it all set up before trying to fill/reshape. I usually stay well-away from anything like this - am sure that those comfortable with doing modifications would be able to get a much better result first up. Cheers, Ralph.
Guest
Ralph, good job and a good update. I know it isn't the right windshield in the kit, but how is the fit of the kit part to kit body, know what I mean? Just trying to sort out probs before hand....harv :speak_cool:
Fasinating - great work Ralph - The VB trop wil be my next one the line once the Sufa is out of the way , I planning the same trick with the caponies, except I'll be using a spare Hasagawa one ..
Superb work
Canopy "fix" pics. harv: can't comment on the fit of the kit windshield as I did not try it.
The joins were filled with a couple of applications of Mr Surfacer which was then wet-sanded.
The hard edges were returned with the Tamiya scriber. The lower windshield-to-fuselage join line missing - plan to add that once everything has had time to really harden up.
The HB fuselage is much wider than Tamiya's, so the Tamiya canopy won't sit down in either the open or the closed position.
The Tamiya windshield and HB canopy don't fit together in the closed position.
Windshield masked and sprayed with Tamiya's XF-1 Flat Black acrylic.
And a couple of pics taken in full sunlight to "bare all". Shows the slight misalignment between the front of the windshield and the corresponding vertical panel line.
If anyone is comtemplating the modification and would like larger size images to zoom in and study for themselves, shoot me an email at rriese@optusnet.com.au
Thanks for looking. Cheers, Ralph.
Great work so far !
Any updates ? I'm very interested how it turns out, as I have Mk V and I want to turn it into Mk Vb using some Hasegawa parts. Did you try to correct the "too wide behind the cockpit" problem ? Besides the problem with the fabric wings, it is poking my eyes the most...
Hello lazycat: no further updates - waiting on Master Model metal barrels to arrive.
There are numerous pics of early Vb's with the externally-armoured windshield so if you have the straight Vb kit, it can be built as an early Vb using the canopy parts supplied in the pit.
No - didn't try to correct the "too wide behind the cockpit" problem as I don't know enough about Spitfires to know what needs to be done.
The fabric surfaces on the upper tailplane parts took me about 40 minutes to sand and rivet.
Have a close look at the kit spinner and propeller blades. You might want to have a think about replacements - especially if you decide to model an early Vb.
Cheers, Ralph.
