Sparzanza Posted December 9, 2017 Author Share Posted December 9, 2017 I thank you sir! BiggTim 1 Link to comment Share on other sites More sharing options...
Sparzanza Posted December 10, 2017 Author Share Posted December 10, 2017 Wish me luck fellas. Here goes. BiggTim, sandokan and Victor K2 3 Link to comment Share on other sites More sharing options...
Sparzanza Posted December 10, 2017 Author Share Posted December 10, 2017 (edited) Glosscoat applied over all decals except for the ones underneath, which I will be able to spray in a couple of days. It went fairly smooth with the odd spit here and there from my Badger 150. The blobs were erased by brushing them flat and respraying over them. I am 99% sure I have escaped any and all silvering at least! Edited December 10, 2017 by Sparzanza R Palimaka, Gazzas, Shawn M and 2 others 5 Link to comment Share on other sites More sharing options...
DonH Posted December 11, 2017 Share Posted December 11, 2017 Nice job! Gloss coat looks like glass and the decals really make the whole colour scheme pop! Sparzanza 1 Link to comment Share on other sites More sharing options...
Sparzanza Posted December 11, 2017 Author Share Posted December 11, 2017 Nice job! Gloss coat looks like glass and the decals really make the whole colour scheme pop! Thanks! Yes, once you get a hold of a good tin of Humbrol 35 gloss varnish, you're in for a treat. It dries to a high gloss and a rock solid finish. It's almost a shame that I will spray satin over it once I'm done with the pinwashing... Link to comment Share on other sites More sharing options...
Sparzanza Posted December 15, 2017 Author Share Posted December 15, 2017 (edited) Oh sorry, ladies and gentlemen! I have forgotten to take pictures of my pinwash. It's going forward. I am using MIG's dark wash, along with Tamiya's black panel liner. I realise these are both enamel products... on top of an enamel varnish. That sits on top of enamel paint. So far it's going well though; as long as I am careful there's no drama in removing excess wash with cottonbuds and some enamel thinner. I'm feeling a bit torn as to whether to apply this pinwash around certain protruding areas though, or just keep it in the panel lines. Edited December 15, 2017 by Sparzanza sandokan and Shawn M 2 Link to comment Share on other sites More sharing options...
Sparzanza Posted December 16, 2017 Author Share Posted December 16, 2017 Some progress pictures of my pin wash. Droptanks: Lefthand side: Overview: Close up of the engine cowlings - I put the wash around these protruding hatches. Maybe I shouldn't have? I think it looks good, though... I also did this around the many edges of the tail: Underneath: And now all I need to do is clean it up and spray a satin varnish over everything, and prepare for the final weathering. Wish me luck! R Palimaka, BiggTim, sandokan and 5 others 8 Link to comment Share on other sites More sharing options...
Sparzanza Posted December 17, 2017 Author Share Posted December 17, 2017 This Mustang of yours is looking mighty fine. So great to see it in another camouflage rather than NMF. You are going great guns and the Spitfire looks a treat too. Good luck with the satin finish! Dan Thank you Dan! With any luck she'll be done before christmas! Link to comment Share on other sites More sharing options...
Gazzas Posted December 17, 2017 Share Posted December 17, 2017 The pin-wash looks great! Yellow and white are two colors I hate to pin-wash, but they look worse without it. Gaz Sparzanza 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 18, 2017 Share Posted December 18, 2017 wash looks great, whole build does Sparzanza 1 Link to comment Share on other sites More sharing options...
Sparzanza Posted December 18, 2017 Author Share Posted December 18, 2017 The pin-wash looks great! Yellow and white are two colors I hate to pin-wash, but they look worse without it. Gaz wash looks great, whole build does Thank you fellas! Link to comment Share on other sites More sharing options...
Sparzanza Posted January 2, 2018 Author Share Posted January 2, 2018 I owe you guys an update. Basically I had sprayed the top of the plane with Humbrol's satin cote product. No issues there at all. It sprayed smoothly and was touch-dry within minutes. Two days later I could wetsand it because I spotted some imperfections. Seeing as I wouldn't shoot more around the cockpit, I decided to remove the Maskol from the windscreen. And... well. As you can see, it looks awful. It was glued on with Micro Kristal Klear. I guess I should have put some more effort into it. So I decided I will try to mend it. With Tamiya white putty. First I needed to decide how much of the bottom I needed to sacrifice to make it look ok once painted. I did this with Tamiya's bendy tape. Then it was just a matter of masking off its surrounding areas to avoid getting filler in unwanted places. Added filler. How this little surgery will go I do not yet know, fairly unknown territory for me. I hope it will go well. LSP_Kevin, Shawn M, sandokan and 2 others 5 Link to comment Share on other sites More sharing options...
Sparzanza Posted January 5, 2018 Author Share Posted January 5, 2018 While the filling and sanding process is moving forward in a pretty ok fashion - I've gone and done another mistake. Apparently I hadn't sprayed enough varnish on the lefthand side of the fuselage, so after I pulled off the tape covering the letter "B" - most of it went right along with the tape. This is even after taping it on my pants first to rid the tape of some of the adhesive. Fingers crossed that Airfix supplies spare decals as well, otherwise it'll be the shelf of doom for this one... R Palimaka and sandokan 2 Link to comment Share on other sites More sharing options...
R Palimaka Posted January 5, 2018 Share Posted January 5, 2018 That's frustrating! You've invested so much time and effort so far, and you're so close, don't let it go back on the Shelf of Doom. It's beautiful. Someone must have a set they can spare. I have a couple of earlier versions of the Airfix kit with 442 Squadron markings, but not sure if it's this particular aircraft. I'll check tonight. Richard Link to comment Share on other sites More sharing options...
Sparzanza Posted January 5, 2018 Author Share Posted January 5, 2018 That's frustrating! You've invested so much time and effort so far, and you're so close, don't let it go back on the Shelf of Doom. It's beautiful. Someone must have a set they can spare. I have a couple of earlier versions of the Airfix kit with 442 Squadron markings, but not sure if it's this particular aircraft. I'll check tonight. Richard Thanks Richard. I've already emailed Airfix about a new "B" decal, but chances are they will be unable to help. Worst case scenario would be that they only sell spare parts, not decals... Link to comment Share on other sites More sharing options...
