LSP_Kevin Posted November 23, 2017 Share Posted November 23, 2017 That cockpit looks superb! Kev Link to comment Share on other sites More sharing options...
Martinnfb Posted November 23, 2017 Share Posted November 23, 2017 One day, when I grow up, I will be building cockpits like that ! Cheers M. Link to comment Share on other sites More sharing options...
1to1scale Posted November 23, 2017 Author Share Posted November 23, 2017 Thanks, this plane is my extreme weathering project, the cockpit will be grubby, and. The outside will be really beat and worn. Link to comment Share on other sites More sharing options...
Kagemusha Posted November 23, 2017 Share Posted November 23, 2017 Lovely work. Link to comment Share on other sites More sharing options...
Daniel460 Posted November 25, 2017 Share Posted November 25, 2017 Excellent work in the pit! Dan Link to comment Share on other sites More sharing options...
1to1scale Posted December 7, 2017 Author Share Posted December 7, 2017 (edited) I neglected to take pictures after I put it all together and primered it. Today I was able to get an hour and a half and shoot the base coat, I'll let it dry for a day and then I spray on a coat of chipping medium, then I will start masking and spraying the paint layers. Edit: I lied, I found a few pics during assembly. In this pic, test fit of the wing, it just shows the little corner that needed sanding down to get a perfect wing root. This side needed nothing I lost the little instrument cowl, so I had to scratch build one from sheet styrene, I lost some detail, but I didn't want to stop the build. I am just lightly sanding the fuselage seam. Edited December 7, 2017 by 1to1scale sandokan and mpk 2 Link to comment Share on other sites More sharing options...
1to1scale Posted December 7, 2017 Author Share Posted December 7, 2017 (edited) I sprayed a coat of Vallejo Metal Air Aluminum in a splotchy irregular pattern, then a spayed various panels in Duraluminum. This will all be hidden under IJA Green and IJA Gray, until chipping uncovers it. Edited December 7, 2017 by 1to1scale MikeMaben, leoasman, LSP_Paul and 4 others 7 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 7, 2017 Share Posted December 7, 2017 Nice contrast on the base coat. Keep up the good work! Paul Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 7, 2017 Share Posted December 7, 2017 Looks great! Kev Link to comment Share on other sites More sharing options...
1to1scale Posted December 7, 2017 Author Share Posted December 7, 2017 This is a beautiful kit, fits like a Tamiya almost. The wingroots to fuselage have zero filler until the little section at the very front forward of the wing fillet. All I did was add a spreader bar below the cockpit to get zero gap. Vandy 1 VX 4, sandokan and mpk 3 Link to comment Share on other sites More sharing options...
1to1scale Posted December 10, 2017 Author Share Posted December 10, 2017 (edited) Made a little more progress today, sprayed down the chipping medium and let it dry. I then did a bunch of masking, finally I sprayed a light mottled coat of IJA gray on the bottom. I plan to paint the wells the same color as the interior. IJA dark green will go topside, followed by white for the markings, following up with a custom orange yellow mix, red, and finally NATO Black for the anti glare panels. Edited December 10, 2017 by 1to1scale LSP_Kevin, mpk, MikeMaben and 4 others 7 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted December 10, 2017 Share Posted December 10, 2017 looking great Link to comment Share on other sites More sharing options...
1to1scale Posted December 11, 2017 Author Share Posted December 11, 2017 (edited) More paint work on the Frank. I'm trying to go for a slightly mottled look, but not quite transparent like on the Ki-61. A lot of the paint will be chipped off later. Edited December 11, 2017 by 1to1scale Gazzas, LSP_Kevin, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
mpk Posted December 11, 2017 Share Posted December 11, 2017 Oh man, I have two of these, both with Eduard PE and Aires interior etc. I love this aeroplane and am looking forward to the day I can do them justice. As such I found this thread with glee. I have a few questions, if you don't mind? I gather you use PE tools for straight bends and curves? If not, I'd love to hear what else you do. How do you get such pristine results in bending and affixing the PE? How do you secure PE parts when gluing them or simply working in general? (For example, I accidentally bend them at times) What do you use for the coat upon which you are to chip? (I've seen hair spray mentioned, but know nothing of it) When you spread the wing roots, was there any fit issue with the cockpit? Is that the kit IP, and you painted it? Something else? How do you approach painting the IP so well? Are you using any special brush, a tooth pick etc? Great work. I am absolutely thrilled. Well done! Link to comment Share on other sites More sharing options...
1to1scale Posted December 11, 2017 Author Share Posted December 11, 2017 (edited) No problem, glad to help. I gather you use PE tools for straight bends and curves? I have a PE bending jig, but I only used it for a few pieces, the Eduard PE was so well engineered, you could bend it by hand. I used a small set of PE bending pliers and tweezers. I also cut a piece of sprue for the curves in the seat. the dimpled slots were done wit a ball point pen (Eduard has instructions for this). The little parts were all hand bent by tweezers. Did I mention I hate bending PE? I do, its so stressful, but the effect for small scale parts are beautiful. If it wasnt for the IP and the seat, I would not have used the PE at all. The seat is worth the price of the set, but if Yahu made a IP for it, I would have bought a resin seat. How do you get such pristine results in bending and affixing the PE? I bent by hand and used medium thick CA glue How do you secure PE parts when gluing them or simply working in general? (For example, I accidentally bend them at times), I pre-fit the parts, but didnt glue them in until the very last step before priming. Then I used CA glue with a glue looper tool for applying a precision amount of glue. What do you use for the coat upon which you are to chip? (I've seen hair spray mentioned, but know nothing of it). I used Vallejo's chipping fluid mixed 50/50% with their Acrylic thinner, then it sprays very smooth and shiny like a gloss coat. From what I understand, once it gets another coat of acrylic on top, it mixes with the new paint, then you can chip the top coat, but the bottom is undisturbed. When you spread the wing roots, was there any fit issue with the cockpit? None, but I only spread it maybe 0.5-1mm with plastic card, so it was not a large spread. I actually planned on putting a little filler down the gap, but it was so tight, i completely forgot about it, and it ended up not needing it at all. Is that the kit IP, and you painted it? No, i shaved the kit dials off with a knife and used the Eduard IP. if I did it again, I would have painted the top panel with the bezels, as I am not happy with Eduard's color choices. Edited December 11, 2017 by 1to1scale Fooesboy, sandokan and Vandy 1 VX 4 3 Link to comment Share on other sites More sharing options...
