OldTroll Posted May 20, 2015 Share Posted May 20, 2015 (edited) For those of you who want a better vehicle to make your wants known to Silver Wings, may I suggest using their survey form at http://www.silverwings.pl/survey.html ? Edited May 20, 2015 by OldTroll Alburymodeler 1 Link to comment Share on other sites More sharing options...
Silver Wings Posted May 20, 2015 Author Share Posted May 20, 2015 OldTroll - definitely a good idea to do so ! Alburymodeler 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 21, 2015 Share Posted May 21, 2015 I agree with Mike, the Bf108 and Pete and Willow upgrades would be great, but to be truthful, all the aircraft you have produced so far have been great choices, so whatever you choose will probably be fine with me! I would love to do a Romanian He112, but I don't know how many would buy it! I will get to the website and put in a couple choices just to help with the process. Thanks for your continued production of great subjects Tnarg and Zero77 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 21, 2015 Share Posted May 21, 2015 I recently purchased the SW P6-E from our very own Barry (Thanks Barry!) and i MUST say, it has some of the straightest, most lovely molding Ive seen on a resin kit. Really looking forward to building it! Link to comment Share on other sites More sharing options...
DeanKB Posted May 21, 2015 Share Posted May 21, 2015 I recently purchased the SW P6-E from our very own Barry (Thanks Barry!) and i MUST say, it has some of the straightest, most lovely molding Ive seen on a resin kit. Really looking forward to building it! The problem is, all of their kits are that good - you'll be hooked before you know what's happened! The way the wing struts are reinforced with metal is genius. Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 21, 2015 Share Posted May 21, 2015 The problem is, all of their kits are that good - you'll be hooked before you know what's happened! The way the wing struts are reinforced with metal is genius. Oh yeah...................Ive got Simon's He-51 on wheels, an He-51 on floats, Sea-Gladdie, as well as one of his beautiful Stearmans. However for as awesome as those others are indeed molded, for whatever reason, the P6-E molding quality seems to even be step up from those. Link to comment Share on other sites More sharing options...
Zero77 Posted May 22, 2015 Share Posted May 22, 2015 (edited) The way the wing struts are reinforced with metal is genius. I have started to build the P-6E. The fuselage is glued, sanded clean, with lower wings glued and a coat of white primer on it. I can start the painting very soon (but many other builds at the same time...). But the wingstruts are not the best parts of the kit in my opinion. The downside of the metal reinforcement is that they are pretty difficult to set up on the wing, and the angles of the steel wire makes difficult to set the upper wing once the struts are glued as they are very stiff. Actually i had to make pretty bigger holes, and i think i will remake the ends of the struts with putty in order to get a good fitting with the less seams possible. However, that's only a very small criticism, i love Silver Wings kits, and they are on the top of the resin kits market. Edited May 22, 2015 by Zero77 Link to comment Share on other sites More sharing options...
DeanKB Posted May 22, 2015 Share Posted May 22, 2015 The strut holes do need some work. I've found matching up the angle of the brass rod with the enlarged hole makes a big difference. A bit of filler tidies up the join. Doing the cabane struts first helps, as they support the weight of the upper wing. This makes placing the outer struts easier. Link to comment Share on other sites More sharing options...
Artful69 Posted January 5, 2016 Share Posted January 5, 2016 Hmmmm ... How about a He.59b floatplane ... seems right up the Silver Wings alley? Rog Link to comment Share on other sites More sharing options...
alberto49 Posted January 5, 2016 Share Posted January 5, 2016 Hi, could we be confident that 2016 will see the birth of your Reggiane 2000 model? Happy New Year Alberto Link to comment Share on other sites More sharing options...
Silver Wings Posted January 5, 2016 Author Share Posted January 5, 2016 (edited) Alberto, yes. We have been working on the Re-2000 and Yak-9 at the same time for over 2 months. So pretty soon they will be released as announced Edited January 5, 2016 by Silver Wings wrbrdmech, Iain, Zero77 and 1 other 4 Link to comment Share on other sites More sharing options...
Zero77 Posted January 5, 2016 Share Posted January 5, 2016 (edited) Re-2000 = yummy ! I'd buy it in the second it would be available ! Simon, did you ever plan to make a He-70? It's a bit bigger than most of the other Silver Wings models, but it's still reasonnable (about 15m wingspan x 12m lenght, only 1 engine and monoplane). If i remember correctly, you planned to make a Val, and the Val is the japanese cousin of the He-70, their dimensions are quite similar. I dont know if it would be a seller, though, but i'd buy it without any doubt ! Edited January 5, 2016 by Zero77 Tnarg 1 Link to comment Share on other sites More sharing options...
Iain Posted January 5, 2016 Share Posted January 5, 2016 Re2000 - gorgeous!! And would love an He 70 - have a thing about Spanish Civil War period aeroplanes Iain Zero77 and Tnarg 2 Link to comment Share on other sites More sharing options...
Silver Wings Posted January 6, 2016 Author Share Posted January 6, 2016 I wonder if He-70 is so historically significant that makes it worth releasing as a model kit... To be honest, we prefer fighters Zero77 1 Link to comment Share on other sites More sharing options...
Zero77 Posted January 6, 2016 Share Posted January 6, 2016 (edited) I wonder if He-70 is so historically significant that makes it worth releasing as a model kit... To be honest, we prefer fighters I respect that. Of course the main point is to make kits that may sell, that's the only thing that can finance next kits. But i'm not sure it would be a no-seller, though. Compared to Siskins or the Hawker Hart familly, i'm pretty sure it would sell better. (and i LOVE british aircraft of the 20/30's !) Maybe someday one may be released.... Maybe HPH or Special Hobby? Edited January 6, 2016 by Zero77 Link to comment Share on other sites More sharing options...
