mpk Posted February 27, 2017 Share Posted February 27, 2017 Hi guys. I am working on a radial for a Ki-44. There's a great build in the WIP section by Dave J. In it he does a great job of getting 2 wires into a space the looks suitable for only 1. I am wondering what is the best way to achieve this effect. Does one drill holes into the ring, glue them underneath...? How would you achieve this kind of result? Thanks guys. Link to comment Share on other sites More sharing options...
Bill_S Posted February 27, 2017 Share Posted February 27, 2017 One of the most difficult, yet most worthwhile things to add to radials. I'm curious to see if I can learn something here! mpk and CANicoll 2 Link to comment Share on other sites More sharing options...
mpk Posted February 27, 2017 Author Share Posted February 27, 2017 You and me both, Bill. All I know is I am heading off to the hardware store. I need to buy some wire. I'm going to get some fuse wire, copper wire and solder. Oh and some lunch. Link to comment Share on other sites More sharing options...
Theo Posted February 27, 2017 Share Posted February 27, 2017 (edited) Get Lunch at the hardwarestore? mmmm. Don't wan't to share Lunch with you. Glad to have some teeth left Edited February 27, 2017 by Theo mpk 1 Link to comment Share on other sites More sharing options...
Guest Posted February 27, 2017 Share Posted February 27, 2017 As you know Dale, I just wired mine. I did drill holes in the ring stand offs. Just deep enough to hold the wire. It has been suggested to paint my wires, but to be honest, I haven't figured out how to do it and what color........Harv Link to comment Share on other sites More sharing options...
Bill_S Posted February 27, 2017 Share Posted February 27, 2017 If you can't find wire small enough at the hardware store, go to the arts& crafts store and look for "beading wire" - it comes in very small diameters. Make sure you get copper, not steel. mpk and CANicoll 2 Link to comment Share on other sites More sharing options...
Joe66 Posted February 27, 2017 Share Posted February 27, 2017 When I have done mine, I cut off the stub ends flush to the ring surface and drill the holes into the ring itself. For the leads, I insert the two copper wires into a short section of brass or plastic tube of the appropriate diameter, glue the wires, then cut them off flush with the tube. Now take the tube with the wires, and insert into the holes in the ring. The rest needs no explaining. Btw- where the stubs were cut off from the ring, I use a sharp needle to create a starting dimple so the drill bit does not walk. Joe Bill_S, mpk and Shaka HI 3 Link to comment Share on other sites More sharing options...
Bill_S Posted February 27, 2017 Share Posted February 27, 2017 As you know Dale, I just wired mine. I did drill holes in the ring stand offs. Just deep enough to hold the wire. It has been suggested to paint my wires, but to be honest, I haven't figured out how to do it and what color........Harv I also use wrapping wire. The 30 AWG is 0.010 inch (.25 mm) diameter for the wire; the plastic coating you can get in just about any color you like. http://www.ebay.com/itm/30-AWG-KYNAR-wire-wrap-30-gauge-Kynar-100-FEET-Any-Color-/200406828204?_trksid=p2141725.m3641.l6368 I did my TBM engine in red. Tnarg, Shaka HI, Citadelgrad and 1 other 4 Link to comment Share on other sites More sharing options...
mpk Posted February 27, 2017 Author Share Posted February 27, 2017 Get Lunch at the hardwarestore? mmmm. Don't wan't to share Lunch with you. Glad to have some teeth left This explains where my teeth went. As you know Dale, I just wired mine. I did drill holes in the ring stand offs. Just deep enough to hold the wire. It has been suggested to paint my wires, but to be honest, I haven't figured out how to do it and what color........Harv Yeah you did a good job too. I'll have another look. When I have done mine, I cut off the stub ends flush to the ring surface and drill the holes into the ring itself. For the leads, I insert the two copper wires into a short section of brass or plastic tube of the appropriate diameter, glue the wires, then cut them off flush with the tube. Now take the tube with the wires, and insert into the holes in the ring. The rest needs no explaining. Btw- where the stubs were cut off from the ring, I use a sharp needle to create a starting dimple so the drill bit does not walk. Joe Thanks Joe. To be honest, this method may be beyond my meagre abilities at this time. However, I now know it. I can always try eh? Cheers mate. I also use wrapping wire. The 30 AWG is 0.010 inch (.25 mm) diameter for the wire; the plastic coating you can get in just about any color you like. http://www.ebay.com/itm/30-AWG-KYNAR-wire-wrap-30-gauge-Kynar-100-FEET-Any-Color-/200406828204?_trksid=p2141725.m3641.l6368 I did my TBM engine in red. That looks amazing Bill. Citadelgrad 1 Link to comment Share on other sites More sharing options...
dutik Posted February 27, 2017 Share Posted February 27, 2017 Engine looks great. But aren't the wires supposed to sit in the stubs of the brass ring instead somewhere behind? I feel confused. Regards - dutik mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted February 27, 2017 Author Share Posted February 27, 2017 Engine looks great. But aren't the wires supposed to sit in the stubs of the brass ring instead somewhere behind? I feel confused. Regards - dutik Mate, I'll be lucky if I can get glue on anything. Lothar 1 Link to comment Share on other sites More sharing options...
dutik Posted February 27, 2017 Share Posted February 27, 2017 Well, I have two ways to wire my radials: If the engine is only visible from the front I glue small sections of styrene at the back of the collector ring, invisible from the front, leaving free spaces between each to glue the ignition wires onto the back of the collector ring. If the engine is visible or the collector ring cast on I cut off the stubs and drill small holes in place of the stubs. Fiddly, but doable. If you want to go overboard with the detailling you may add some bare metal foil around the base or as "harness" to keep two wires together; insert short brass tubes as "plugs" (Albion Alloys f. e.) or use spark plugs from AM. Images at my Hellcat build (page 3+) linked down in the signature. Regards - dutik mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted February 27, 2017 Author Share Posted February 27, 2017 Well, I have two ways to wire my radials: If the engine is only visible from the front I glue small sections of styrene at the back of the collector ring, invisible from the front, leaving free spaces between each to glue the ignition wires onto the back of the collector ring. If the engine is visible or the collector ring cast on I cut off the stubs and drill small holes in place of the stubs. Fiddly, but doable. If you want to go overboard with the detailling you may add some bare metal foil around the base or as "harness" to keep two wires together; insert short brass tubes as "plugs" (Albion Alloys f. e.) or use spark plugs from AM. Images at my Hellcat build (page 3+) linked down in the signature. Regards - dutik Cheers mate! Link to comment Share on other sites More sharing options...
mark31 Posted February 27, 2017 Share Posted February 27, 2017 I have put small nuts on the ignition ring to put the wires in drild a small hole in the parts on the cilinders The colors off the wires is tan. I hope you have sommthing with this Mark dutik 1 Link to comment Share on other sites More sharing options...
Lothar Posted February 27, 2017 Share Posted February 27, 2017 Mate, I'll be lucky if I can get glue on anything. That makes two of us Cees Broere 1 Link to comment Share on other sites More sharing options...
