CraigH Posted July 19, 2017 Share Posted July 19, 2017 Hi, I restarted in the modelling world after a 40 plus year layoff with the Airfix Junkers 87 in 1/24. I need to digout the photos to repost it after the photobucket ripoff. Next up here's my ongoing attempt at the next of the old 1/24 "superkits" The Bf 109E-4. I just need more time to post what I've been doing I've been on with the Bf 109E-4 for a couple of months and here's the progress so far. As suggested in the post title, I last built this model in the 70s and a lot has changed since thenI'm sure we all know the fit isn't great and the detail a little lacking but I've tried to scratch build some bits to compensate Engine first,not much to tell. It's not great detail but I Dremmelled off the moulded pipes etc and added some of my own. Due to the build a lot of the engine isn't visible so no point going too much to town. Painted in black with a little gunmetal added. Weathered with an oil wash and some oil stains etc added. Also I've added engine numbers to try and add a little realism I'll try and get an update on later with cockpit build etc. As ever any comments, advice are most welcome Regards Craig So, onto the cockpit. It's a bit sparse by todays' standards but I've tried to pep it up a bit First, before any huge debate I've used Humbrol RLM02 as my weapon of choice. This will be painted as a BoB from Aug 1940 so I'm happy that the interior should be RLM02. As I said it's a bit bare in there so I've made a seat back from Milliput and distressed it up a bit. Also used the RB seat harness which I think is brilliant and forms a little project all its own (especially at 54 YoA and with dodgy eyes close up) I got all the parts in. This pic shows the rudder pedals with the addition of the red hydraulic brake lines and the foot holders made from lead wire. It also show the full metal replacement instrument panel from Airscale. Pricey but worth it. If anyone has any opinions on the Yahu ready made ones I'd be grateful as next up for me is the 1:24 Hurricane Left side wall I've added various pipes etc and lots of decals from Airscales Luftwaffe placards set. Also managed an attempt at the harness tensioning device from behind the seat Right side wall saw me remove the moulded wiring and replace it with red telephone wire. The oxygen regulator got a new coiled pipe from copper wire and some decals on the valves. A blue oxygen pipe was added running up the side wall to the pilots connection. The map was downloaded from an original Luftwaffe one and shrunk and printed(I've since taken the bottom off at an angle to make it sit right in the pocket as you can see in the later pic) Top view shows a bit of weathering and staining etc. Next chapter to follow I've decided to do a bit of a detour and get the wings sorted before looking at the fuselage. The wings were a terrible fit so I had to kidnap the wife's nail sanding sponge block and work it to death to get a decent fit. Wheel wells were blocked in with plastic sheet and a bit of strip for the formers along the floor of the wells Bit of an oil wash and they don't look too bad. I've tried using some masking tape cut to size, painted and stitching pencilled in to represent the canvas cover that protects the wheel well surround. Still a bit of sanding etc needed round here. The guns were painted with a mix of gunmetal with a touch of black then dry brushed silver and a silver crayon used to add some wear and tear. The wing radiators were again a poor fit. I ditched the horrid plastic kit grilles and fitted some fine wire mesh instead. Even though the grilles sit quite deep in the housing so aren't that prominent, it still adds a more realistic touch....or at least I think so. BiggTim, Martinnfb, airscale and 6 others 9 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 19, 2017 Share Posted July 19, 2017 Welcome aboard, Craig! Good work so far - looking forward to more! Kev Martinnfb 1 Link to comment Share on other sites More sharing options...
CraigH Posted July 23, 2017 Author Share Posted July 23, 2017 Thanks Kev. The 109 is finished now. Just need to update my post then get it in the ready for inspection forum.😊 Martinnfb 1 Link to comment Share on other sites More sharing options...
CraigH Posted August 4, 2017 Author Share Posted August 4, 2017 First, before any huge debate I've used Humbrol RLM02 as my weapon of choice. This will be painted as a BoB from Aug 1940 so I'm happy that the interior should be RLM02. As I said it's a bit bare in there so I've made a seat back from Milliput and distressed it up a bit. Also used the RB seat harness which I think is brilliant and forms a little project all its own (especially at 54 YoA and with dodgy eyes close up) I got all the parts in. This pic shows the rudder pedals with the addition of the red hydraulic brake lines and the foot holders made from lead wire. It also show the full metal replacement instrument panel from Airscale. Pricey but worth it. If anyone has any opinions on the Yahu ready made ones I'd be grateful as next up for me is the 1:24 Hurricane Left side wall I've added various pipes etc and lots of decals from Airscales Luftwaffe placards set. Also managed an attempt at the harness tensioning device from behind the seat Right side wall saw me remove the moulded wiring and replace it with red telephone wire. The oxygen regulator got a new coiled pipe from copper wire and some decals on the valves. A blue oxygen pipe was added running up the side wall to the pilots connection. The map was downloaded from an original Luftwaffe one and shrunk and printed(I've since taken the bottom off at an angle to make it sit right in the pocket as you can see in the later pic) Top view shows a bit of weathering and staining etc. Next chapter to follow I've decided to do a bit of a detour and get the wings sorted before looking at the fuselage. The wings were a terrible fit so I had to kidnap the wife's nail sanding sponge block and work it to death to get a decent fit. Wheel wells were blocked in with plastic sheet and a bit of strip for the formers along the floor of the wells Bit of an oil wash and they don't look too bad. I've tried using some masking tape cut to size, painted and stitching pencilled in to represent the canvas cover that protects the wheel well surround. Still a bit of sanding etc needed round here. The guns were painted with a mix of gunmetal with a touch of black then dry brushed silver and a silver crayon used to add some wear and tear. The wing radiators were again a poor fit. I ditched the horrid plastic kit grilles and fitted some fine wire mesh instead. Even though the grilles sit quite deep in the housing so aren't that prominent, it still adds a more realistic touch....or at least I think so. Girlscanplay2 and 109 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 4, 2017 Share Posted August 4, 2017 Welcome aboard, Craig! Very nice work so far. Kev Link to comment Share on other sites More sharing options...
AlexM Posted August 4, 2017 Share Posted August 4, 2017 Hi Craig, looks very good! And Cheers Alex Link to comment Share on other sites More sharing options...
Shawn M Posted August 4, 2017 Share Posted August 4, 2017 oh I like where this is going Link to comment Share on other sites More sharing options...
CraigH Posted August 4, 2017 Author Share Posted August 4, 2017 Hi Craig, looks very good! And Cheers Alex Thanks Alex. It's finished now so hope to get the rest of the build uploaded this weekend Link to comment Share on other sites More sharing options...
CraigH Posted August 4, 2017 Author Share Posted August 4, 2017 oh I like where this is going Hope the end results is as pleasing for you Shawn Link to comment Share on other sites More sharing options...
CraigH Posted August 4, 2017 Author Share Posted August 4, 2017 (edited) Wings done and as you'll see from the earlier fuselage pics, I did manage to finally get the two halves together. Obviously the engine went inbetween and I added some wiring etc to the cowling gun platform Wings on, canopy masked and she was ready for painting I did the standard RLM02 grey/RLM71 green camo on the uppers and RLM65 blue underneath and well up the sides. This, I believe was the factory default for the E-4 in 1940. Wicks plane ws, at some point, a yellow nosed b****** so I went for this. Decals came next and I used the Techmod ones for the E-4. They are very thin and fiddly, especially the small ones for the fuel filler instructions etc. But finally done. Micro sol and set used to conform them to the contours. Here's some overview pics. I decided to add the stab markings first then the dappled camo over the RLM 65 sides that characterised JG2 aircraft. I'm sure you'll let me know if it looks OK As far as the dappled effect goes, I first tried the cut of stubbly brush but didn't like it so I ended up with small pieces of a 50p Wilkinsons bath sponge (the rougher section) and this seemed to work well. I built it up in layers over several days to try and achieve the desired effect Canopy masks off and weathering here we come Edited August 4, 2017 by CraigH Martinnfb, Girlscanplay2 and JMason5067 3 Link to comment Share on other sites More sharing options...
CraigH Posted August 6, 2017 Author Share Posted August 6, 2017 Pin wash for all the panel lines first Underneath, I just added some subtle shading to represent muck and dust Some spots of paint added to the crosses to represent a hasty repaint in the field and a spray with a dilute black/grey mixture to try and give a bit of ageing. I've also added some wire at the back to represent the rudder linkage assembly. Oil and fuel stains, not my strong point :-) sprung wire line for the canopy Black pastels used for the gun staining both cowl guns and wing guns I've looked hard and come to the conclusion that exhaust staining wasn't too marked on the 109 so I've kept it rather subtle Martinnfb and Jim Barry 2 Link to comment Share on other sites More sharing options...
airscale Posted August 6, 2017 Share Posted August 6, 2017 welcome back to the fold (and to the forum) the 109 looks fantastic - I love the IP you did a fabulous job on it - I find it exceptionally rewarding to see our stuff 'in action' Peter Link to comment Share on other sites More sharing options...
CraigH Posted August 6, 2017 Author Share Posted August 6, 2017 welcome back to the fold (and to the forum) the 109 looks fantastic - I love the IP you did a fabulous job on it - I find it exceptionally rewarding to see our stuff 'in action' Peter Hi Peter Thanks very much. Your IPs are brilliant. Link to comment Share on other sites More sharing options...
Joel_W Posted August 6, 2017 Share Posted August 6, 2017 Craig, As you've discovered, more has changed then stayed the same over that 40 years. When I returned to the hobby after 35 years, my learning curve was really steep. Come to think of it, I'm still on that curve. Very nice effort on the Me 109E-4. Joel CraigH 1 Link to comment Share on other sites More sharing options...
CraigH Posted August 6, 2017 Author Share Posted August 6, 2017 Craig, As you've discovered, more has changed then stayed the same over that 40 years. When I returned to the hobby after 35 years, my learning curve was really steep. Come to think of it, I'm still on that curve. Very nice effort on the Me 109E-4. Joel Hi Joel Thanks for the reply. It's really nice to think your peers think you're doing an OK job on the builds I've just started the Airfix 1:24 Hurricane Mk1 and I'm documenting this build much better than I did the 109. Also I need to read a few posts on taking better photos of my work. I'm not really happy with how these turned out. Might be taking a few more snaps over the next week. Link to comment Share on other sites More sharing options...
